Old 02-02-2015, 01:56 PM   #15
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Don't let these guys scare you. Get a clutch and a boost/afr gauge and make sure that you datalog your car with EcuTek to make sure the tune is working properly and you will be good to go. I would never touch a perfectly working engine. Set aside money should something go wrong.
Celigts (02-02-2015)
Old 02-02-2015, 01:58 PM   #16
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
Do some searching and find a thread called "best gauges, pick two" or three i couldnt remember if it was two or three...im too lazy to give you the URL anyway.
The Following User Says Thank You to cdrazic93 For This Useful Post:
Reaper (02-02-2015)
Old 02-02-2015, 04:05 PM   #17
CSG Mike
CSG Mike's Avatar
Originally Posted by Reaper View Post
450+ daily driven here. On my 3rd transmission in a year. Stock engine on e85. If you don't have e85 you'll need a gtx30 and a built short block. You're looking at 4k for a built shortblock not including the turbo kit or install. Then you'll need a transmission shortly after. V160 swaps are around 8k $ then depending on how much you're lowered you'll need axles after that. DSS 600s are 900$? I think. Don't remember I'm blowing through transmissions right now.
Gotta cut down that torque!
Old 02-02-2015, 04:37 PM   #18
fang_gt86
FR Noob
fang_gt86's Avatar
With great hp comes great responsibility. Have you push that stock 200hp to its limit? Do you really need more?
"I'm having too much fun to care about horsepower" - Unknown
6MT FR-S Whiteout:OFT- OTS V2 Stage 2 (93oct & E85), Tomei UEL, Invidia OP, JDL UltraQuiet FP, Ark Grip catback, GS hood struts, Perrin Inlet & K&N drop-in
fang_gt86 is offline   Reply With Quote
Old 02-02-2015, 04:38 PM   #19
Reaper
in orbe terrum non visi
Reaper's Avatar
Drives: violent
Maxed out gtx28 is a torque monster.
The Following User Says Thank You to Reaper For This Useful Post:
CSG Mike (02-02-2015)
Old 02-02-2015, 06:55 PM   #20
Whatabouteggs
[Citation Needed]
Drives: 2014 WR Blue Subaru BRZ Premium
Originally Posted by Celigts View Post
I'm looking to push 450ish HP. The Ptuning kit will obviously be fine for that.
Get a different car.
Whatabouteggs is offline   Reply With Quote
The Following User Says Thank You to Whatabouteggs For This Useful Post:
cdrazic93 (02-02-2015)
Old 02-02-2015, 07:59 PM   #21
Celigts
Celigts's Avatar
Drives: 2014 Toyota FRS
This is excellent advice. I've been told to build internals but I don't want to mess with a proper working engine. E85 is around my area....by around I mean a 15 min drive to the nearest station...so if that's required then ok...I want to buy the kit....have it professionally installed and tuned and yes drive it daily w.o issue. I drive like a retard with the stock 200 hp engine and it's no where near enough. I can live with 350 hp to the wheels but want to push every "safe" ounce of hp I can get.
What about ptuning meth Kit? I need to research it more but is it a pain in the ass? Worth the hassel? I'm not going to track the car....at least not for now. I just want to have a car with something other than just a turbo kit slapped on it under the bonnet. Being able to push a bit more than the guy who bought his kit and did nothing else...etc.
Thanks for the advice...I'll post build pics soon as I'll be ordering the kit at the end of the month.
Celigts is offline   Reply With Quote
Old 02-02-2015, 09:52 PM   #22
Reaper
Reaper's Avatar
Drives: violent
If you're paying someone else to do everything you're going to end up with a 45,000$ car real quick. C7 vettes don't cost much more than that used.
Celigts (02-12-2015)
Old 02-02-2015, 10:29 PM   #23
Teseo
Drives: frs
Rougesquadron thread?
Old 02-02-2015, 11:02 PM   #24
Cop
Cop's Avatar
Drives: 2013 FRS
I'm not hating but this thread doesn't make a whole lot of sense to me. The FA20 is a perfectly good, working engine. By virtue of adding FORCED induction, you are introducing complexity to the engine that it wasn't intended to handle.
Why? If you're asking people on this forum for a list of parts to buy, that makes you the same as the guy you're trying to "one-up" except you have deeper pockets.
Back on topic, I'm not an expert but you will at least want an oil cooler, radiator, and clutch, to handle the power. Not to mention the brakes that you will 100% need to upgrade in order to stop the car and wider wheels / stickier tires to keep your car on the road. On top of the base cost for just the turbo kit ($6k) you will need the accompanying tune and the rest of what I listed above (IMO). It's your money it's up to you what you want to do with it but you're looking at a huge investment to reach your magic number. Hope this was helpful (sorry if I sounded like a ****) and looking forward to your build thread.
Cop is offline   Reply With Quote
Old 02-03-2015, 11:14 AM   #25
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Running a tune that requires meth or is setup to use the advantages of meth which is running more timing is going to be a huge risk should anything go wrong with your meth system. Sure there are failsafes that can be installed, but they won't catch everything that can happen. If you just want a better look under the bonnet, then start removing things and have them painted/powdercoated and go for a nice wire tuck.
Old 02-03-2015, 11:40 AM   #26
Jyn
Noob
Jyn's Avatar
Drives: FR-S Mammogram
I ran water/meth mixture in my last car.
Not worth the hassle. Not worth the hassle.
(Said it twice so you know I meant it.)
Jyn is offline   Reply With Quote
ignore! deadwolfbones Cosmetic Modification (Interior/Exterior/Lighting) 1 03-23-2014 06:28 PM
test.. ignore.. Mikem53 Off-Topic Lounge [WARNING: NO POLITICS] 3 12-04-2013 08:55 AM
FOUND! Ignore thread Tdot Canada Classifieds 0 11-28-2013 10:33 AM
Testing, please ignore Priapus Off-Topic Lounge [WARNING: NO POLITICS] 58 10-28-2013 07:07 PM
