Old 01-30-2015, 09:52 PM   #351
AlwaysSideways
Drives: 2013 WRB Subaru BRZ
Congrats! You should post a video of your setup! I was told I was going to get tracking today, but I didn't :'( sad day for me
AlwaysSideways is offline   Reply With Quote
Old 02-01-2015, 12:51 PM   #352
jvincent
jvincent's Avatar
Looks good. I'm getting mine this week and will also be getting it coated. It's not going on until spring though.
Old 02-01-2015, 02:20 PM   #353
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
Looks great. You're going to really enjoy the effects of those 3 mods!
Shiv@Openflash is offline   Reply With Quote
Old 02-01-2015, 03:40 PM   #354
j_Zer0
Drives: Asphalt FRS 2014
Could I get a bit of diagnostic help please?
I've been hearing an unpleasant sound coming from my engine bay during acceleration. The sound coming out of my tailpipes is nice: deep, growly, etc. But the sound coming from my engine bay under moderate acceleration is higher frequency -- I'd call it tinny. It's a bit like what raindrops rapidly falling on aluminum foil might sound like.
I'm thinking the sound is being caused by some kind of exhaust leak. I spent about an hour today checking my exhaust system for leaks but found nothing. I'm still thinking I have a leak though because I'm seeing LTFTs of 10% at idle (as soon as I give any throttle LTFTs drop below 5%).
A sound clip is attached. Thanks.
ESC+OFH | Borla Axleback | Helix clear side markers | Opti-coat | Beatsonic v2 Sharkfin antenna | TRD lowering springs | TRD sway bars | 18" Enkei Kojins + PSSs
j_Zer0 is offline   Reply With Quote
Old 02-01-2015, 08:36 PM   #355
JB86'd
JB86'd's Avatar
Drives: JAWS
@j Zer0 Did this just start happening or was it happening when you first installed your header? Did you replace all gaskets when you installed it and make sure they were torqued to correct spec?
JB86'd is offline   Reply With Quote
Old 02-01-2015, 08:51 PM   #356
steve99
Drives: FT86
as per what previous guy said if your fuel trims are less than 10% and your afr and commanded afr are close under load then its unlikely you have exhaust gasket leak.
you do get a bit of a tinny sound at lower rpms with ofh as possibly most other aftermarket catless header due removal of cat ,cats cut down a lot of noise esecially higher frequencys, also aftermarket header generally lighter due thinner walled tube and no heat shielding all that cuts noise as well.
sounded ok to me , the crackling noise in clip sounds like some ssue with recording or compression algorythm.
Old 02-01-2015, 10:28 PM   #357
JB86'd
JB86'd's Avatar
Drives: JAWS
@JMPeach How much did your ceramic job cost?
Looking forward to your feedback on the header..I'm still debating on whether the performance benefits are going to be worth the approx. $900 all said and done, coming from the OFT stg 1 tune.
Old 02-01-2015, 10:40 PM   #358
j_Zer0
@steve99 @JB86'd
Thanks for the feedback guys. I think I started noticing the different sound when I changed to the new header. I did replace the gaskets and torque to specs, so like Steve said it may just be a case of this is what a lightweight catless header sounds like. As long as nothing is wrong I'm ok with a bit of tinny -- it's not obtrusively loud and it's only noticeable 2k - 3k rpm. And it comes with some decent performance gains.
Old 02-02-2015, 12:01 AM   #359
JB86'd
JB86'd's Avatar
Drives: JAWS
@J Zer0 I've heard it's a good idea to retorque the header bolts after putting some miles on it, have you tried that?
Old 02-02-2015, 12:48 PM   #360
ap5512
ap5512's Avatar
Drives: 2013 SWP BRZ
I just got done installing the OFH+OFT yesterday and also got the"tinny" sound you're talking about but I only notice it on start up and once the RPMs drop the noise goes away. I would definitely say it's only present in lower RPMs though.
I was also scared that I didn't tighten up the bolts enough or that there is a leak but I have yet to log any data so won't be able to tell if I do have any issues.
"Don't be a don'ter, do be a doer" - Johnny Wu
ap5512 is offline   Reply With Quote
Old 02-02-2015, 12:48 PM   #361
ap5512
ap5512's Avatar
Old 02-02-2015, 07:38 PM   #362
j_Zer0
I did re tighten the bolts after running the header for a few weeks. I can say for sure that it's definitely a good idea because I got a good half-turn on a few of the bolts the second time. It didn't do much for the sound though. Since I can't find an exhaust leak I'm gonna live with it for now. Tired of taking the underplate off.
Old 02-02-2015, 08:16 PM   #363
sixthree
Drives: 14BRZ
Noob here with no experience in tuning.
Do you have to have the OFT attached everytime or can you flash, unplug and the car will run under that tune until you switch it?
Also, I have an automatic frs, will the improvements be seen only in the automatic manual mode or also in the full auto mode?
sixthree is offline   Reply With Quote
Old 02-02-2015, 08:18 PM   #364
AlwaysSideways
You can tune and then unplug. I also have an auto and will be getting the header on Wednesday with OFT tune. I'll update you
The Following User Says Thank You to AlwaysSideways For This Useful Post:
sixthree (02-02-2015)
Open Flash Header - Sound and Performance Comparison nlowell Engine, Exhaust, Transmission 41 05-19-2014 07:29 PM
FS: Open Flash Header - SoCal Pickup nlowell Engine, Exhaust, Bolt-Ons 9 05-12-2014 07:29 PM
Open Flash Tablet Andrew025 Engine, Exhaust, Bolt-Ons 3 04-26-2014 06:03 PM
Open Flash Header Catless Clip Vmax911 Engine, Exhaust, Transmission 25 03-08-2014 07:51 AM
Open flash tablet. cooldandani Scion FR-S / Toyota 86 GT86 General Forum 1 02-22-2014 08:14 PM
