Old 01-29-2015, 03:43 PM   #1
HerrFunf
Drives: 2014 FR-S
Touch Screen is Tweaking!
Anyone else have this?
My '14 FRS base touchscreen started flashing back and forth between EQ screen and Bluetooth screen. It'll do it a few times then stop or just keep flashing and beeping at me for a couple minutes before it stops on its own. If I push a button, it registers and pauses for a second, but then starts tweaking again. So far, it's only happened on very cold mornings under 25 degrees F. The music keeps playing but the flashing screen and beeping is annoying and definitely not right.
HerrFunf is offline   Reply With Quote
Old 01-29-2015, 04:12 PM   #2
It's possible there is a defect or contamination in the screen so that below a certain temp it thinks its being "touched". I would try cleaning the screen (properly) first if it looks like there is anything on it. If that doesn't work I'd take it in for a warranty check.
I'm guessing it stops when the inside temperature rises with the heat on.
iOS 8 w/ 2014+ Touch Screen Head Issues? LALFAN Electronics | Audio | NAV | Infotainment 15 06-11-2015 05:28 AM
Scion touch screen head unit from FR-S geezer86 Audio/Visual, Electronics, Infotainment, NAV 9 10-03-2014 11:28 PM
WTB: 2014 Scion Frs Touch Screen Head Unit 86 FRS Want-To-Buy Requests 1 07-28-2014 03:42 PM
FS: 2014 Scion Frs Touch Screen Head Unit morphius88 Audio/Visual, Electronics, Infotainment, NAV 6 05-26-2014 01:45 PM
!!!!!!WTB the 2014 fr-s new touch screen radio!!!!! That86mikeyb NY / NJ / CT / PA 3 02-26-2014 11:53 AM
