Old 01-28-2015, 03:27 PM   #15
Midarete
Midarete's Avatar
Drives: Whiteout FRS
Originally Posted by Red FRS View Post
What did you use? Is it prone to scratches?
Wetsanded the Trim, then applied a coat of Adhesion Promoter, followed by 3 coats of Valspar Satin Black Spray paint. Yesterday while shoveling my car I managed to scrape it slightly and left a scuff but rubbing it made it go away. So as of right now there hasn't been any damage to it at all, actually holding up quite well.
Midarete is offline   Reply With Quote
The Following User Says Thank You to Midarete For This Useful Post:
Red FRS (01-28-2015)
Old 01-28-2015, 03:52 PM   #16
wootwoot
Drives: FRS
Originally Posted by chubky View Post
Better off vinyl wrapping them
Yup.
Old 01-28-2015, 06:36 PM   #17
8R6
8R6's Avatar
Drives: FRS
if youre looking for one solid color, gloss finish, and interior plastic, just vinyl wrap it.
8R6 is offline   Reply With Quote
Old 01-28-2015, 09:23 PM   #18
djliquidsteele
Drives: Scion FR-S
I sprayed mine with Krylon matte black and it matches the matte black around the instrument cluster perfectly. As others have said, prep work is key. You don't have to do a ton of sanding. You just want to use like 400 grit and rough up the surface so the paint sticks well. Use many light coats and let t dry completely in between. Gloss typically takes longer to dry than matte. I have had 0 issues with scratches or chipping and it's been about a year.
Nice thing is if you get a chip, just sand it smooth, repaint and fixed. Super easy.
djliquidsteele is offline   Reply With Quote
Old 01-28-2015, 09:46 PM   #19
mrmatteo
Drives: Scion Fr-S
what kind of sand paper did you use?
mrmatteo is offline   Reply With Quote
Old 01-28-2015, 10:42 PM   #20
Midarete
Midarete's Avatar
2500 grit wetsand
Old 01-29-2015, 03:41 PM   #21
UnOvertime
UnOvertime's Avatar
Drives: Firestorm FR-S AT
I had my interior pieces hydrodipped and I really like it. No chips or cracks in the pieces almost a year later.
I did not want a solid color and unless I told you they were dipped you would probably never know the difference just by looking at them.
UnOvertime is offline   Reply With Quote
Old 01-29-2015, 04:23 PM   #22
dubbrand
I took my parts to a body shop and had them color match it to the color of my car.
dubbrand is offline   Reply With Quote
The Following 4 Users Say Thank You to dubbrand For This Useful Post:
axelo (01-30-2015), Grymm86 (01-30-2015), Kiske (01-30-2015), NWFRS (01-29-2015)
Old 01-29-2015, 04:26 PM   #23
dubbrand
Also the only annoying thing about it is now I have to wax my interior.
Old 01-29-2015, 04:53 PM   #24
BlueDubbinTDI
BlueDubbinTDI's Avatar
Drives: 2013 FR-S, 2012 MCS
While that looks great, I don't see that holding up very long
Old 01-30-2015, 12:12 PM   #25
dubbrand
Been 8 months so far without a problem. I don't know why it wouldn't hold up. Its painted as well as anything else. The front bumper takes more debris than anything in my interior.
Old 01-30-2015, 05:30 PM   #26
BlueDubbinTDI
I just feel like high gloss interior trim would show every fingerprint, smudge ect as well as potentially reflecting sunlight right in your face
Old 01-30-2015, 07:32 PM   #27
dubbrand
It would but how often are you touching that stuff? The only thing I really touch is the door handle to close the door and even then I'm mostly grabbing the back side that isn't painted. The sun hasn't been an issue. I think that comes when people fiberglass their interior and paint everything.
Old 01-31-2015, 09:37 AM   #28
BlueDubbinTDI
I've grabbed stuff off the passenger floor on many occasion that rubbed up against that general area. I'd like to see something like yours in person. I'm sure I'd want it after I saw it.
Interior trim trim clips (Dash Trim Panel) ubersoph Cosmetic Modification (Interior/Exterior/Lighting) 4 08-11-2022 08:47 AM
GTS interior trim for GT owners Fizz AUSTRALIA 25 02-07-2017 09:03 PM
SoCal:Headlight/interior painting, custom towhook license plate mounts & shift knobs! BMHumanic Exterior Parts (Aero, Lighting, Etc.) 4 10-30-2013 05:39 AM
WTT interior silver FR-S trim for black trim. Panda Grahams Interior Parts (Incl. Lighting) 7 10-11-2013 08:35 PM
Painting black trim on the rear bumper MindtheGap Scion FR-S / Toyota 86 GT86 General Forum 8 06-09-2012 11:39 PM
