Old 05-28-2013, 11:14 AM   #99
SmsAlSuwaidi
Boosted
SmsAlSuwaidi's Avatar
Drives: Not a supra....yet
Originally Posted by hunter3232792 View Post
im sorry to hear you have that issue i have the j2 front pipe and 0 issues so far
Do you have the j2 catback ?
Old 05-28-2013, 04:02 PM   #100
hunter3232792
hunter3232792's Avatar
Drives: FRS
nope i am running the invidia q 300 catback with the j2 front pipe
hunter3232792 is offline   Reply With Quote
Old 06-24-2013, 07:27 PM   #101
NYCsubaruBRZ
Drives: 2013 Subaru BRZ & 99' Ford Explorer
Just to give you guys a heads up, I've been running their front pipe with my buddy club for a month now and it does have multiple issues
It does not mount with most cat backs properly because the dount gasket would not properly insert into the front pipe !. I do have a really minimal amount of leaking between the two parts but I'm going to suck it up considering its a cheap part. In addition to the fitment issues the material it's made out of is not that great too. The last issue was it moving around the frame and that was because the bolt that would hold the front pipe (the stock one ) was insufficient to do the job because of the way the J2 front pipe was designed, and I ended up using a longer bolt with a nut.
I only stated the negative issues just so you guys know what's up with it, but never the less it is a cheap investment thats worth the money
that donut gasket comes off... remove it and you can bolt it up with no leaks... good luck
NYCsubaruBRZ is offline   Reply With Quote
Old 06-24-2013, 07:30 PM   #102
NYCsubaruBRZ
i got a few down pipes if any one wants
Old 07-22-2013, 02:51 AM   #103
kristo naibaho
kristo naibaho's Avatar
Drives: ft 86
Thanks all of guys
kristo naibaho is offline   Reply With Quote
Old 01-09-2015, 12:42 PM   #104
mid_life_crisis
Drives: FR-S 10 #103 AT
Necroing a thread with a relevant question.
Has anyone ever tried this J2 exhaust?
http://www.protuninglab.com/j2du20scfrs8.html
Edit: Corrected the link. Sorry about that.
“Sex is like Bridge. If you don't have a good partner, you'd better have a good hand.” - Mae West
Papa said, "son there's a lot of evil temptations out there. Best to try 'em all so you know which ones to avoid."
mid_life_crisis is offline   Reply With Quote
Old 01-28-2015, 11:08 AM   #105
mid_life_crisis
Bump. Still looking for help. I'm pretty sure this is a knockoff of an Ark Grip. Anyone ever heard one of these?
Edit: Never mind. The near useless search engine on the forum failed me but when I went out into the internet in general and searched it brought me back here to a review on exactly what I was looking for.
Old 01-28-2015, 07:44 PM   #106
jarednoel
Drives: Asphalt
I have that exhaust. It sounds great but the fitting is slightly off. You can make it work but it isn't as easy as say the invidia n1
jarednoel is offline   Reply With Quote
Old 01-30-2015, 09:07 AM   #107
mid_life_crisis
My two concerns are:
1) How loud is it when cruising through the neighborhood?
2) Drone on the highway? Do those Helmholtz resonators actually do anything?
I don't care if it gets loud when I stand on it, that's the price you pay.
Old 01-31-2015, 03:32 AM   #108
jarednoel
Drives: Asphalt
It's loud but not as loud as the N1 and Berk muffler delete that I've had before. I also have the J2 front pipe which may contribute to how loud it is. The drone is still there, I don't think the hemholtz actually do anything. And if they do, there must be a lot of initial drone without em.
The Following User Says Thank You to jarednoel For This Useful Post:
mid_life_crisis (02-19-2015)
Exhaust System/Exhaust Manifold Removal and Replacement GrimmSpeed DIY (Do-It-Yourself) Guides 52 11-11-2015 09:30 PM
Perrin Catback Exhaust vs Nameless Performance Exhaust. vignesh Engine, Exhaust, Transmission 201 06-05-2013 09:47 PM
HKS Catback Exhaust Group Buy - Legamax Premium Exhaust & Hi-Power Spec L Catback FT-86 SpeedFactory Groupbuys 11 10-21-2012 08:59 PM
Can someone explain the diffrence between catback exhaust and axleback exhaust? speedy racer Engine, Exhaust, Transmission 12 09-23-2012 12:24 PM
Catback Exhaust vs Axleback Exhaust – What’s the difference? phenom86 Engine, Exhaust, Transmission 10 07-28-2012 09:08 AM
