Old 11-12-2014, 12:34 PM   #547
buddy32
Drives: WRB Subaru BRZ Limited
Did you get the Raceseng plates WITH Raceseng Spring Perch, or the ones W/O Spring Perch (keeps T2s spring perch)?
Did you reuse the Subaru washer?
@Racecomp Engineering do you guys know if getting Raceseng Spring Perch or keeping T0s spring perch will change the need for the Subaru Washer?
@Raceseng may know too....
Thanks.
I got the front raceseng plates with the perch and did not use the original ones. I also re-used rear top mounts.
buddy32 is offline   Reply With Quote
The Following User Says Thank You to buddy32 For This Useful Post:
Sportsguy83 (11-12-2014)
Old 12-01-2014, 12:05 PM   #548
smbstyle
smbstyle's Avatar
Drives: 2013 SWP BRZ
For anyone else on the fence about the T2's...
Randy Pobst drove our BRZ at Road Atlanta this past weekend (RCE T2s, 400lb springs, 215 NT01s) and said it was "one of the best handling cars I've ever driven".
https://www.facebook.com/randy.pobst..._comment_reply
2013 SWP BRZ
Build Thread: http://www.ft86club.com/forums/showthread.php?t=38781
smbstyle is offline   Reply With Quote
The Following 5 Users Say Thank You to smbstyle For This Useful Post:
CSG David (12-01-2014), DarkSunrise (12-03-2014), normancw (12-01-2014), Racecomp Engineering (12-01-2014), Wepeel (12-01-2014)
Old 12-01-2014, 05:53 PM   #549
Mad_Mike
Mad_Mike's Avatar
Drives: 2013 Scion FRS firestorm
Ordered a set of T2s during the black Friday sale. So excite!
Mad_Mike is offline   Reply With Quote
The Following User Says Thank You to Mad_Mike For This Useful Post:
Old 12-01-2014, 11:14 PM   #550
That's awesome!
- Andy
Old 12-03-2014, 09:59 AM   #551
DarkSunrise
DarkSunrise's Avatar
That's a hell of an endorsement, considering who it's coming from and how many different cars he's driven on track.
2022 BRZ Build
2013 FR-S Build
The Following User Says Thank You to DarkSunrise For This Useful Post:
smbstyle (12-03-2014)
Old 12-03-2014, 02:08 PM   #552
Calum
That Guy
Drives: 2013 asphalt FRS MT
What's the heightest ride height possible with the zeros?
Old 12-03-2014, 02:18 PM   #553
jvincent
jvincent's Avatar
IIRC from earlier, the highest they can go is 15mm drop.
The Following User Says Thank You to jvincent For This Useful Post:
Calum (12-04-2014)
Old 12-16-2014, 10:36 AM   #554
Mad_Mike
Mad_Mike's Avatar
Look what came in the mail yesterday. They look so pretty.
Racecomp Engineering (12-16-2014)
Old 12-20-2014, 12:16 PM   #555
Mad_Mike
Mad_Mike's Avatar
I have to say those settings rce provides for the T2's are spot on. The car feels great. These coilovers are everything I expected (really more) and nothing I was worried about.
The Following 3 Users Say Thank You to Mad_Mike For This Useful Post:
M23 (01-29-2015), Racecomp Engineering (12-21-2014), smg1138 (01-28-2015)
Old 12-21-2014, 10:20 PM   #556
Looks good!
- Andy
Old 01-28-2015, 03:12 PM   #557
smg1138
smg1138's Avatar
Drives: 2013 Raven FR-S
Other than the springs, what are the other differences between the RCE T0's and the KW V1's? I was about to pull the trigger on some ST's, but I'm thinking the stainless body may be a better idea in the long run.
smg1138 is offline   Reply With Quote
Old 02-24-2015, 05:12 PM   #558
M23
Drives: 86
@Racecomp Engineering:
What is the length and the ID of the front and rear springs of the T0??
For those that cannot afford the $350 spring rate option, or would just like to save money; I noticed you can easily find a used set/pair (or discounted new set/pair), of Hyperco/Eibach coilover springs for very cheap - around $60/pair or $120/set (if not better).
This would be a great alternative/option, rather than spending $350 on Swift springs.
350 or 400 springs sound delicious
M23 is offline   Reply With Quote
Old 02-24-2015, 09:06 PM   #559
The valving is substantially different. Our RCE T0's are much more at home on the track.
- Andy
smg1138 (02-25-2015)
Old 02-24-2015, 09:09 PM   #560
ID is 60mm and I need to double check length (at home now). I will talk to Myles about making 350 lbs/in springs the default.
- Andy
finch1750 (02-24-2015), M23 (02-24-2015)
Racecomp Tarmac II Clubsport coilover JoeBoxer Suspension | Chassis | Brakes -- Sponsored by 949 Racing 47 11-17-2013 12:02 AM
Tarmac Zero Coilovers Specs? tintumz22 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 18 06-14-2013 12:26 AM
KW CLUBSPORT COILOVERS W/ FREE SHIPPING FOR THE SCION FR-S/SUBARU BRZ!!! NJA Brakes, Suspension, Chassis 7 03-30-2013 09:26 PM
Wheel Directory: Enkei ES-Tarmac 16x7.0 +45 quik1987 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 09-12-2012 01:24 PM
Toyota 86 Tears Up Tarmac at 2012 TAS (TRD, N1, HKS, Up Garage Models) + LFA Roadster knoxviue FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 35 01-20-2012 02:44 AM
