Old 01-28-2015, 03:19 AM   #1
mrmatteo
Drives: Scion Fr-S
Painting Interior Trim
I recently became interested in changing the color of the interior trim on the frs. I haven't been able to find a thread of one so I just wanted to ask for a detailed instruction on how to do it. I want to make it look professional with a glossy finish and I'm not trying to use something like plastidip. Can anyone help?
mrmatteo is offline   Reply With Quote
Old 01-28-2015, 03:53 AM   #2
swimfest
Drives: Whiteout '13 FR-S
I too am interested in this. I feel like if you just spray them, it would eventually peel or chip.
swimfest is offline   Reply With Quote
Old 01-28-2015, 04:03 AM   #3
WesleyG
Drives: 2014 Satin White Pearl GTS auto
As nice as that may look, given the interior plastics experience a fair amount of wear and tear, it maybe a short time before unsightly scratches and chips appear? I dont know, just a thought?
2002 MR2 Spyder 2zz-GE Apexi PFC PPE Race header 8500 RPM of FUN
2014 37J 86 Auto
WesleyG is offline   Reply With Quote
Old 01-28-2015, 04:12 AM   #4
Manic
Is not fast.
Manic's Avatar
Drives: 2014 Whiteout M/T
Honestly, looking up any plastic painting guide should give you a rough idea of how to do it properly.
I'm not an expert, but I've painted a few things in/on my car and the most important thing is prep work. I.e., sanding, sanding, more sanding, base coats, etc. Just doing a cursory search on google for "painting plastic" should throw up a handful of guides. Also, unless you have some painting experience already, it's gonna be a bit difficult to get it down perfectly on your first attempt. You're gonna want to have extra spray paint when you inevitably have to redo a piece or two.
Also, be mindful that spray paint behaves differently based on the external temperature. When I was trying to paint my tail lights, I ended up with a very rough and gritty coat instead of a smooth one all because I held the can slightly further way than I should have. It was a hot dry day so the paint was drying in the air before it was hitting my tail lights. Moving the can a couple inches closer fixed all of this. Without experience or proper training, little minutiae like that just won't be obvious so be prepared to start over every time you start spraying.
Aside from that, make sure you have a clean area that you can seal off to let paint dry like in a garage or spare room. You don't want to leave pieces out in the open to dry because bugs and other debris floating around can mess up the paint as it dries.
Gratuitous shots of my painting work.
Honestly, just study up on basic painting techniques and have a lot of patience and you'll do fine.
Here are some guides I pulled up searching for "painting interior car trim".
http://www.dsmtuners.com/threads/the...-diyer.365304/
http://www.pugaddicts.co.uk/2012/06/...astic-car.html
http://www.turbo-mopar.com/forums/sh...-interior-trim
Manic is offline   Reply With Quote
Old 01-28-2015, 04:25 AM   #5
chubky
chubky's Avatar
Drives: 2014 Scion FR-S Monogram
Better off vinyl wrapping them
chubky is offline   Reply With Quote
Old 01-28-2015, 09:11 AM   #6
WhiteFRS69
WhiteFRS69's Avatar
Drives: 2014 Scion FRS
try using plasti dip if you want to give it a try, atleast when its done if you dont like the finish or want to go a different route, you can just peel it off
Old 01-28-2015, 09:35 AM   #7
Rabbit of Caerbonnog
Run Away!
Rabbit of Caerbonnog's Avatar
Drives: 2015 Subaru BRZ Limited
Plasti Dip is always a good option. Application is straight forward, drying time is great, and easily removable. Also there is a lot of additional options with Plasti Dip, you can have matte, glossy, sparkle, etc.
Rabbit of Caerbonnog is offline   Reply With Quote
Old 01-28-2015, 10:00 AM   #8
FRSTRM
Baby LFA
FRSTRM's Avatar
Drives: Baby LFA
http://instagram.com/p/yQwWrDjAYO/?modal=true
http://instagram.com/p/yPtBFBjAfo/?modal=true
http://instagram.com/p/yQI6NHDAbP/?modal=true
Hydrodip
FRSTRM is offline   Reply With Quote
Old 01-28-2015, 01:02 PM   #9
swimfest
They dont do hydrodip in solid colors though I dont think....
Old 01-28-2015, 01:05 PM   #10
FRSTRM
Baby LFA
FRSTRM's Avatar
Drives: Baby LFA
Yeah, I mean there is no point if you're trying to so solid. I wasn't sure if that was the desired result. Cheers
Old 01-28-2015, 01:36 PM   #11
swimfest
Sorry that was more of a question lol
Old 01-28-2015, 01:52 PM   #12
FRSTRM
Baby LFA
FRSTRM's Avatar
Drives: Baby LFA
Not that I am aware. Usually just predetermined patterns. That's the point of hydrodip, if you want solid, straight up paint would be more reasonable.
Old 01-28-2015, 02:03 PM   #13
Midarete
Midarete's Avatar
Drives: Whiteout FRS
Painted my Door handle and Vent trims Satin Black
Midarete is offline   Reply With Quote
The Following User Says Thank You to Midarete For This Useful Post:
Drambeenie (02-06-2017)
Old 01-28-2015, 02:20 PM   #14
Red FRS
Red FRS's Avatar
Drives: 2014 Subaru BRZ
What did you use? Is it prone to scratches?
Red FRS is offline   Reply With Quote
Interior trim trim clips (Dash Trim Panel) ubersoph Cosmetic Modification (Interior/Exterior/Lighting) 4 08-11-2022 07:47 AM
GTS interior trim for GT owners Fizz AUSTRALIA 25 02-07-2017 08:03 PM
SoCal:Headlight/interior painting, custom towhook license plate mounts & shift knobs! BMHumanic Exterior Parts (Aero, Lighting, Etc.) 4 10-30-2013 04:39 AM
WTT interior silver FR-S trim for black trim. Panda Grahams Interior Parts (Incl. Lighting) 7 10-11-2013 07:35 PM
Painting black trim on the rear bumper MindtheGap Scion FR-S / Toyota 86 GT86 General Forum 8 06-09-2012 10:39 PM
