Old 01-21-2015, 03:49 AM   #295
Kodename47
Kodename47's Avatar
Drives: UK GT86
Originally Posted by dave- View Post
Did the tables you were after get added to ProECU ? Do you still feel like the package is missing something now?
Am considering going this route instead. Assume I buy licence + racerom + programming kit from one of the forum sponsors and download appropriate software? To do a mates car, just need a second licence correct?
To do a car in basic form you need:
- License for the ECU
- Cable and Dongle (come as one)
You can then add on the Racerom upgrade for access to custom maps and modes 2-4. The 2nd car will just require them to purchase a license for their ECU which can be added to your dongle through the master tuner.
It depends on how much you're into your tuning, I doubt many would think there are tables worth using that are missing and TBH if you're just trying to do a basic tune then it's all there.
If you want a bit more then the way around this is to use Romraider on a base stock ROM, which can be easily found on here or romraider forums, and then transfer the file into ECUtek and then utilise it's advance features. It's long winded if you need to keep going back and forth but gives us end users the extra access you may want.
.: Stealth 86 :.
Kodename 47 DJ:
Old 01-23-2015, 11:53 AM   #296
The_Understated
Hooner in training... eh?
The_Understated's Avatar
Drives: 2013 Scion FRS
Wow just got through this entire thread and what a wealth of information. Honestly I'm back on the fence between OFT and ECUTek since I plan on FI next year (maybe even later this year) and honestly need map switching since it's a DD. Gotta save fuel where ever I can but be able to switch to POWAR map when I go to a track or want to have fun. Just the price point is keeping me away, especially for us Canadians with 1.23 exchange rate...
**Dunno what to put here yet... Imagine something witty...**
The_Understated is offline   Reply With Quote
Old 01-26-2015, 05:28 PM   #297
Skorov
Skorov's Avatar
Drives: 86 GTS White
Anyone know if ZA1JE00I is compatible with 2012 Toyota 86 AT before I update?
Skorov is offline   Reply With Quote
Old 01-26-2015, 06:38 PM   #298
Kodename47
Kodename47's Avatar
Drives: UK GT86
Probably not, best to check the compatibility display when programming the ECU
.: Stealth 86 :.
Kodename 47 DJ:
Old 01-26-2015, 08:54 PM   #299
steve99
Drives: FT86
I would aggree eith @Kodename47 that E00I unlikely to be compatable with prevoius vehicles
I tried D00G on my manual 2013 and it threw 2 CEL çodes P0155 re dash communiçations and another re alternator control, car ran fine though. Suspect changes to dash and altenator, probably same for auto.
Old 01-27-2015, 06:06 PM   #300
Jetbill
Drives: 2013 FRS, 2014 BMW 335 M-Sport
Anyone know how to get access to custom map levels in EcuTek?
I can log and view the table data but can't access the actual map.
Is there a RaceRom add on needed that can be downloaded?
Jetbill is offline   Reply With Quote
Old 01-28-2015, 02:28 AM   #301
Kodename47
Kodename47's Avatar
Drives: UK GT86
You need to purchase it. If you have already then chase up whoever you bought it off to update your dongle.
.: Stealth 86 :.
Kodename 47 DJ:
Old 01-30-2015, 01:01 AM   #302
zkv476
zkv476's Avatar
Drives: 2014 SWP BRZ, MT
Did D00C ROM's lose the ability to be flashed to older C versions? I could have sworn on the last ProECU build ZA1JD00C was on the list of flashable roms. So since the latest update provided D00C RaceROM files I recreated my map on D00C hoping it'd fix some of the issues from B01C RaceRom which incidentally hasn't been updated since February of 2014 (or at least not released to us). Except after spending all the time pasting over my new map, I found it was deemed incompatible.
I wish there was a way for retail customers to get access to beta tables. It's tough needing to repaste every single table manually (as we don't have compare ROM either) when I need to edit a table that I can get to in RomRaider but not EcuTek. Currently tuning 1000cc injectors, and not being able to edit low-pulse-width injector comp is rather annoying.
The answer is racecar. Always.
zkv476 is offline   Reply With Quote
Old 01-30-2015, 02:44 AM   #303
Kodename47
Kodename47's Avatar
Drives: UK GT86
I think there have been issues with compatibility with the newer ROMs on older cars. I also noticed the same with the G series recently.
.: Stealth 86 :.
Kodename 47 DJ:
Old 03-01-2015, 03:08 AM   #304
Kodename47
Kodename47's Avatar
Drives: UK GT86
Looking at ECUteks Twitter feed I noticed that they have managed to get the cylinder knock parameters for the new WRX (FA20 DIT):
I've emailed them about this but is anyone else able to locate these parameters on our ECU? Would be a nice addition to have.
.: Stealth 86 :.
Kodename 47 DJ:
Old 03-03-2015, 11:18 PM   #305
19eightysix
Drives: Ae86
getting my ecutek dyno tune next week, pretty excited to see the gains.
19eightysix is offline   Reply With Quote
Old 03-07-2015, 03:12 PM   #306
Jetbill
Those looking for an easy , convenient solution to view, log and make changes quickly...windows tablet from HP Stream ($99) works well. Only thing you need is a USB on the go cable and a USB hub.
Increase text size in EcuTek and view critical parameters real time..oil and coolant temp, PI duty, ethanol percentages, AM, ign correction.. Etc
(Oil pressure is Hardwired so that's a separate gauge me)
Make quick changes at the track without that bulky laptop!
Size:  135.2 KB Name:  ImageUploadedByTapatalk1425758866.151858.jpg
Old 03-08-2015, 10:12 AM   #307
Xero-Limit
Xero-Limit's Avatar
Drives: JDL Turbo FRS, 335SC BRZ (ret)
Thanks for that...many don't realize that these tablets are now in a ridiculously low price range, and this allows pretty much real time adjustment. Any of deal sites routinely FPs the win8 tablets once they get to 100 bucks, and at that point the whole setup is hard to beat.
Xero-Limit is offline   Reply With Quote
Old 03-14-2015, 03:30 AM   #308
NissanGuy
NissanGuy's Avatar
Drives: Strangely.
Originally Posted by EcuTek View Post
EcuTek are pleased to announce the release of BRZ/FT-86/FRS Tuning Software for retail customers. For the first time, these products allow retail customers to edit their own ROM files using EcuTek Tools...
ProECU BRZ
This software will allow the enthusiast to calibrate, program and data log their vehicle. It will also include the following RaceROM features:
  • Launch Control
  • Flat Foot Shifting
  • Auto Blip
  • Throttle Mapping
  • Per Gear Rev Limits
This software update, known as ProECU BRZ will be released as a FREE update for owners of EcuTek ProECU Programming Kits - available from and supported by EcuTek's Master Tuners.
*** ProECU BRZ is a FREE Product Upgrade ***
RaceROM BRZ
There will also be a product upgrade option available. Known as RaceROM BRZ, this will give you access to all RaceROM BRZ features. This will be available and supported exclusively by EcuTek Master Tuners. RaceROM BRZ will provide the following additional RaceROM features:
  • Four Way Map Switching
  • Custom Maps offering unique functionality:
    • Traction Control
    • FlexFuel tuning
    • Closed Loop Boost Control
  • Speed Density based Engine Calibration
  • High Horsepower Forced Induction Load Limiter Lift
*** RaceROM BRZ will have a suggested retail price of £249 or $399 USD ***
We are in the process of educating our dealer network and have some webinars to do tomorrow. We're going to be busy getting the product ready for launch, but we'll attempt to answer all your questions.
ProECU BRZ will be available for download on Friday 20th December 2013.
RaceROM BRZ will be available at the same time. Contact your Master Tuner to purchase the upgrade.
If you do not yet have an EcuTek ProECU Programming Kit, you can order this from any EcuTek Master Tuner to get ProECU BRZ.
We hope that the release of the product at this time, gives you the chance to explore the software over the Christmas break. We welcome your feedback.
All the best
The Team at EcuTek
I just bought your stage 2 tune! Plugged into the car, downloaded everything, and now I'm at an impasse. Um... Where is it?
I can't find my calibration ID, my Dongle ID, or my tune (is that what a ROM is?). Can't seem to find any guides that tell you where to find this stuff. There's like eight indistinguishible ROMs to choose from, and you may gather I'm not the sort of person that knows how to choose.
I just want my cruise control to start working again. How do I do this?
My FR-S has a build thread!
(It's mostly full of Nissans)
NissanGuy is offline   Reply With Quote
ecutek, edit, proecu, racerom, tuning
EcuTek End User/Retail Tuning Software Release! Dustin@Dynosty Forced Induction 27 12-19-2013 09:17 AM
So what ECUtek software do you need to make changes to the ECU yourself? seven Engine, Exhaust, Transmission 30 01-04-2013 11:58 AM
EcuTek's BRZ / FT86 / FR-S ProECU Software available for Pre-Order now Visconti Engine, Exhaust, Bolt-Ons 7 07-27-2012 01:00 PM
Toyota will announce the FT86 in Tokyo 2011 motor show? ossme Scion FR-S / Toyota 86 GT86 General Forum 9 12-05-2010 02:36 PM
