Old 01-11-2015, 08:20 PM   #1415
ATL BRZ
TEQSPORT Brand Manager
ATL BRZ's Avatar
Drives: '24 GR86 + '16 FR-S
Originally Posted by DocWalt View Post
Good thing you don't drive up, your car would barely get up to temp
I'd probably have to use the stock thermostat and disconnect or block off the oil cooler during Winter if I lived up North.
Old 01-12-2015, 09:33 AM   #1416
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
How many inches of clearance do you have between the ground and the bottom of that splitter? Any concerns destroying it when driving the car on the street?
Old 01-12-2015, 10:47 AM   #1417
ATL BRZ
ATL BRZ's Avatar
Including the vanes on the bottom right about 4 inches.
Yes. I barely cleared the ramps on the lift backing it out and didn't scrape anything driving home 25 miles mostly highway over neighborhood speed humps and several undulations but I do think I will raise the ride height a tad more not just for clearance but because during a 95mph test run on a closed road it felt like the splitter was an inch off the ground. It probably wasn't but I could definitely feel the nose hunker down; dampers are also set to be nearly full soft. The extra height should allow more travel to compensate for the aero effect at 130mph.
Old 01-18-2015, 06:31 PM   #1418
ATL BRZ
ATL BRZ's Avatar
Sunday Funday hanging out with @Bg8780 and @Slysdexia at OLOBA
4.5" of ground clearance from the bottom of the splitter after raising the ride height a bit. Much less risky.
Thanks @eric6 for the shoutout!
Awesome product and looking forward to the AOS
The Following 4 Users Say Thank You to ATL BRZ For This Useful Post:
Bg8780 (01-19-2015), chanomatik (01-22-2015), eric6 (01-22-2015), Slysdexia (01-27-2015)
Old 01-27-2015, 11:29 AM   #1419
ATL BRZ
ATL BRZ's Avatar
Let's play "what's in the box?"
Old 01-27-2015, 11:32 AM   #1420
rlpaul
Drives: point A to point C. Screw point B!
I'll play!
Front pipe.
Or maybe a drive shaft, but dimensions seem wrong for that.
rlpaul is offline   Reply With Quote
The Following User Says Thank You to rlpaul For This Useful Post:
ATL BRZ (01-27-2015)
Old 01-27-2015, 12:05 PM   #1421
ATL BRZ
ATL BRZ's Avatar
Originally Posted by rlpaul View Post
I'll play!
Front pipe.
Weighs 29 pounds
Old 01-27-2015, 12:58 PM   #1422
rlpaul
Originally Posted by ATL BRZ View Post
Weighs 29 pounds
The only thing that immediately comes to mind at around weight that you haven't done yet is a clutch kit... but dimensions seem off for that. Unless they packed the box funny
Old 01-27-2015, 01:49 PM   #1423
eric6
eric6's Avatar
Drives: 93 MR2 Turbo; 2014 BRZ
Rear axles? Coilovers?
eric6 is offline   Reply With Quote
Old 01-27-2015, 04:55 PM   #1424
ATL BRZ
ATL BRZ's Avatar
Dezod Motorsports Catback
  • 2.5" 304 stainless steel construction
  • Twin mini sport rear mufflers
  • True Y-pipe split
  • 4.5" OD polished tips
  • 18" resonator to keep drone & tone correct
  • Hollow exhaust hangers for weight reduction
  • Mandrel bent for smooth exhaust flow
  • 3 piece construction for easy bolt-on
  • Unparalleled fabrication quality
  • Excellent fitment
  • Maximum ground clearance in mind
Driveway Labs Type 1 diffuser clearance with tips.
It sounds AMAZING. Perfect tone. Zero rasp/drone. LOUD, but not too loud for tracks with sound limits. Extremely satisfied.
Sound clips soon.
The Following 2 Users Say Thank You to ATL BRZ For This Useful Post:
austinbrz (03-30-2015), buddy32 (01-27-2015)
Old 01-27-2015, 05:12 PM   #1425
Porcupint
Drives: 13 GBS BRZ
Weighs 29 pounds
But in all seriousness, looks damn nice. Surprised you aren't running 3" out.
Porcupint is offline   Reply With Quote
The Following User Says Thank You to Porcupint For This Useful Post:
Old 01-27-2015, 08:03 PM   #1426
ATL BRZ
ATL BRZ's Avatar
I know several owners that have ran 3" while naturally aspirated with a catless header and/or front pipe and have ended up hating the obnoxious volume it allows.
Old 01-27-2015, 08:29 PM   #1427
White64Goat
Mail Order Bride??
The Following 3 Users Say Thank You to White64Goat For This Useful Post:
ATL BRZ (01-27-2015), chanomatik (01-29-2015), civicdrivr (02-23-2015)
Old 01-27-2015, 08:48 PM   #1428
Porcupint
Drives: 13 GBS BRZ
Guess I need to rethink the 3" option.
jdl turbo, mazworx, racecomp engineering, track build, verus engineering
Wnt3d's 86 - Turbo E85 Daily/Track Build wnt3d Member's Car Journals 77 07-17-2017 03:35 PM
No Limit Motorsport Full Blown BRZ Build No Limit Motorsport Member's Car Journals 16 07-08-2014 12:46 PM
