Old 01-24-2015, 11:42 AM   #1765
Rekkless
ahh k thnx good thing my phone plan has unlimited data
Rekkless is offline   Reply With Quote
Old 01-24-2015, 12:36 PM   #1766
Simok
Drives: 2013 FRS
Thanks guys. Ive literally been dealing with customer service since I put the unit in a month ago. They help me fix one problem then another comes up. I had to take out the swc lead because my volume kept going up, I emailed them and he linked me to page 75 here. I asked him if I had to do the antenna lead and amp lead and he said no only the swc. Then I emailed him about the door speakers he told me some bs about checking the speakers to make sure they are hooked up right.
Simok is offline   Reply With Quote
Old 01-24-2015, 01:44 PM   #1767
emre1252
Drives: Mazda3
Originally Posted by emre1252 View Post
Hi guys... i read all the pages you wrote about 80. Most of you have ca-fi universal model if im not wrong??? I have specific dashlinq4 for my Mazda3 with canbus. I have a question; as i see all the updates on the website are for "without canbus" versions. What about if i apply the rooted dashlinq4 update u published here for non canbus to my dashlinq4. Thanks.
Any idea?
emre1252 is offline   Reply With Quote
Old 01-25-2015, 08:57 AM   #1768
emre1252
Drives: Mazda3
Ok guys i hurried and couldnt wait for the answer and rooted my canbus device with the non canbus android os. And the result is everything works normally except bluetooth... the device doesnt recognise the bluetooth adapter. I think theres something wrong with the bluetooth driver. Can anybody help me?
Old 01-25-2015, 09:11 AM   #1769
emre1252
Drives: Mazda3
I read something on the website says that the update you gave here is only for a specific bluetooth module (i think without canbus ones). thats why now i cant use the bluetooth now. I asked Will to give me the original Mazda3 rom with canbus. I hope he can help
Old 01-26-2015, 05:53 AM   #1770
Fakk
Drives: 13 BRZ Limited 6MT CBS
Originally Posted by B-R-Z View Post
I bought a FreedomPop service for internet since my Verizon phone service doesn't allow tethering without paying for it. The service i got is 500mb/month and is free for 4g (yes, free) but if you want 3g AND 4g, its $4 per month--there are higher packages available. It runs on Sprints network if you want to check coverage, I was told coverage is bad if you go with 4g only, while 3g/4g provides continuous coverage. I've been using it for a month now and its well worth it for me. I only need it for Waze traffic updates for navi to avoid backups on my way to work. I paid $20 initially to sign up which included both a usb dongle and a WiFi device. Still can't get the usb device (Sierra wireless 250u) to work though
I use PdaNet on my Android phone, also Verizon, it allows you to create a WiFi hotspot, Bluetooth hotspot, or tether via USB to a computer. It works great with my iPad and laptop, I'm sure it would work fine with the HU. Currently its a one time fee of like $8 and you can use the code as many times as you want. The only downside would be turning it on every time you wanted to use it in the car. Apologies if I'm not supposed to post things like this here!
Fakk is offline   Reply With Quote
Old 01-26-2015, 06:31 PM   #1771
Skorov
Skorov's Avatar
Drives: 86 GTS White
Okay... So i figured out that my unit slightly faulty. The blue/white wire (amp remote) isn't providing a strong enough current (probably less than 200mA). This is much less than what is expected.
Who is our normal support contact and what would be the best way to contact them?
By the way, does anyone know what the rated current is given to the Amp remote wire?
Thanks!
Skorov is offline   Reply With Quote
Old 01-27-2015, 02:29 AM   #1772
Berliner
Drives: T
Dashlinq 4 ROM rooted for new Bluetooth version
If somebody still looking for a rooted ROM for the new Bluetooth version, here is it:
http://www.filedropper.com/rooteddas...btfrom20140829
This version is the same as you can find on Burmjeff's Place (http://burmjeff.com/dashlinq4-rom/), but compatible with the latest Bluetooth version (means >20140829 only!)
Please check your hardware configuration first: SETTINGS > ABOUT DEVICE > BLUETOOTH MODULE VERSION before upgrading.
Berliner is offline   Reply With Quote
Old 01-27-2015, 05:35 AM   #1773
born2lose
Drives: Toyota GT86
Originally Posted by SVXdc View Post
I think you'll find that you only need to make one modification to the Dashlinq's harness -- changing the power antenna lead, as I describe in that earlier post.
GT86 models don't have the illumination(-) lead on the car's 6-pin harness, so you can leave the Dashlinq's SWC wire where it is. And GT86 doesn't have an amplifier for the door speakers like BRZ and FR-S in North America, so you don't need to pin the Dashlinq's amp trigger lead.
See the posts by Narcoden and my replies starting at #1659. He found his HU was doing strange things on the HU's amp trigger output and dimmer input. I recommend you use a voltmeter to do the same tests that I list in post #1662. If you find that the Dashlinq's illumination input lead does anything strange, you should un-pin it so it doesn't connect to your car (and post a reply here to let us know).
The wiring on my GT86 worked smoothly, just as described - the only change I had to make was to wire the ca-fi's orange/black harness wire to the blue antenna power lead. No other changes needed.
However - installation was a totally different matter. The GT86 OEM brackets are apparently different from everything I've seen here, and they simply do not match the unit. Right now I am trying to decide how to mount them, but I don't think it will be possible without serious DIY filing/drilling.
And as for my first impressions on the unit - I usually use the radio while driving and totally miss the OEM unit's option to just show all available stations, by name. Also, when using waze, which is still my favourite gps app, radio sometimes randomly hangs.
Sound quality is about the same as the OEM unit, although at higher volumes it sounds just a bit less loud. otherwise, I'm quite happy with it, although I still need to play around for a while before I decide if it's the right thing.
born2lose is offline   Reply With Quote
Old 01-27-2015, 08:10 AM   #1774
SilverlightPony
SilverlightPony's Avatar
Drives: '13 Subaru BRZ, '06 Toyota 4Runner
Is the unit sitting too far forward, and preventing the trim panel from sitting flush? If so, you're using the wrong mounting holes. You'll need to file down or bend away the lobe of each bracket closest to the front face of the unit so the bracket can reach the correct set of mounting holes. I just bent mine out, rather than trying to file them down.
SilverlightPony is offline   Reply With Quote
Old 01-27-2015, 10:44 AM   #1775
born2lose
Drives: Toyota GT86
I've seen the pics posted here with the correct mounting position - the problem is that I think the GT86 brackets are different from what you have, I'll post some pics later tonight (if I get the chance). My brackets also have some little bumps on their back (the side that sits against the unit) for allignment, I guess. These bumps don't fit any of the holes in the ca-fi, so even when I mount them in what I think is the correct position, they will stay 2-3 mm away from the head unit, which is enough to prevent me from screwing them into the dashboard. Will post pictures later tonight (4:44 pm now in Germany).
Old 01-27-2015, 07:33 PM   #1776
godzuki
godzuki's Avatar
Drives: frs
Definitely remember the bumps causing problems and dremeling them off. Tin snips made short work of the front few mm of the bracket as well. They cut through the metal mounting hardware like butter.
godzuki is offline   Reply With Quote
Old 01-27-2015, 07:35 PM   #1777
SilverlightPony
Yep, if those alignment nubs aren't fitting into any holes, you don't have it aligned right. You will not be able to get those nubs into their proper holes unless you file down, cut off, or bend out the bit of bracket closest to the face of the unit.
To borrow some pics from earlier in this very thread...
Incorrect:
Correct:
Note the flanges at the top and bottom of the bracket on the right side of the image have been filed down in the second pic so the bracket itself can sit closer to the front of the unit. Bending them out away from the body would also work.
Your brackets may look a bit different from this (mine do), but you'll have to do effectively the same thing in order to get it to sit in the proper position.
Old 01-27-2015, 11:40 PM   #1778
Prog
Prog's Avatar
Drives: 2016 Cadillac CTS
Do I just do a normal system update from the settings menu to install this? Also, does this wipe all of the apps that are currently installed?
Prog is offline   Reply With Quote
REVIEW: Ca-Fi Toyota Universal - Stock Fitment ANDROID Stereo SHIFTER Electronics | Audio | NAV | Infotainment 16 06-13-2017 06:23 PM
Android, bluetooth, Music, and the FR-S stock pioneer stereo JayNutter Electronics | Audio | NAV | Infotainment 27 12-18-2014 03:54 AM
How to: Torque on an android powered stereo with no hacking v. Ca-Fi Dashlinq4 SHIFTER Electronics | Audio | NAV | Infotainment 29 04-07-2014 04:58 AM
