Old 05-13-2012, 11:04 PM   #1317
mottor
mottor's Avatar
Honestly if I lower it at all it'll only be like an inch or an inch and a half. What do you mean by tuck? Example?
mottor is offline   Reply With Quote
Old 05-13-2012, 11:29 PM   #1318
CoryUyede
NisSubuGuru?
CoryUyede's Avatar
Drives: 2011 Subaru WRX
Rears tucked
No but seriously, The natural arc of the suspension wants to carry the wheels inwards (toward the center of the car When looking from the front or rear). Lowering the Car and having the car sit in a different position on the suspension arc effectively makes them tucked..or sunken in. The other factor is a small optical illusion that happens when a car is lowered vs. regular height. If a car has 3 inches of wheel gap, and the edge of the tire sits an inch inside of the wheel well, it won't look so tucked, because of the excessive wheel gap. Lower that same car 2.5 inches, to the point where there's 1/2inch wheel gap and keep that same inch of tire to inner fender clearance, the wheel will look much more tucked.
If you're going for a certain Flush/semi-agressive look. Always Lower to desired height first, THEN get wheels. You'll get optimal results that way
Here is an Civic Type R with wheels that are tucked.. or conservative.
Heres an MR2..with what most would say is TOO aggressive
Past to Present
CoryUyede is offline   Reply With Quote
Old 05-13-2012, 11:32 PM   #1319
oldskule
oldskule's Avatar
Drives: Mazda
Basically meaning when the wheel isn't pushed out enough towards the fender (not flush enough). A good example is Pekingduck's car, I believe he's lowered on stock wheels. Specifically the rear wheel.
oldskule is offline   Reply With Quote
Old 05-14-2012, 01:03 AM   #1320
mottor
mottor's Avatar
Ahhh yeah, I know what you mean, just didn't know the word for it. Any idea what width/height would be necessary to keep it from looking like that? (Not sure if this has been covered already).
Old 05-14-2012, 01:10 AM   #1321
CoryUyede
NisSubuGuru?
CoryUyede's Avatar
Your "flushness" is a factor of both width AND offset. One number is meaningless without the other
Past to Present
Old 05-14-2012, 01:17 AM   #1322
mottor
mottor's Avatar
Yeah, just figured that one out. I'm looking some more for something with either less offset or more width or a combination (like 17x8 and +35 maybe). Thanks for the lesson.
Old 05-14-2012, 01:39 AM   #1323
CoryUyede
NisSubuGuru?
CoryUyede's Avatar
For the sake of keeping steering geometry true. Its best not to veer too far away from stock offset. +45-+40 is fine. going to the low 30s isnt ideal really. Something slightly more aggressive would be like a 7.5 inch +45 . Very common sizing. Your wheels will stick out 9-10mm more. You could go semi aggressive and and do a 8 or 8.5 +45. This will stick out about 15 or 21mm more. Lower the car first or wait for other members and see what fit you like from others experimenting
Past to Present
Old 05-14-2012, 01:51 AM   #1324
mottor
mottor's Avatar
Duly noted. And that's the plan anyway is to wait and see what others' results are. OZ Allegeritas are pretty nice, though I may want something a bit more unique. Guess we'll see.
Old 05-14-2012, 03:04 AM   #1325
CoryUyede
NisSubuGuru?
CoryUyede's Avatar
I guess i'm lucky, I've got a Set of 5x100 18x8.5 +48's i've got sitting in the Garage that i'm going to Test fit on the BRZ, that'll give me a really good idea what i need for a perfect fit
Wheels CAN be a fairly expensive purchase, let other people figure it out =p
Do it once and do it right.
Past to Present
Old 05-14-2012, 10:52 AM   #1326
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
It'll come down to clearance on both sides. There seems to be PLENTY on the outside, but we don't know about the inside.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 05-14-2012, 12:04 PM   #1327
civicdrivr
civicdrivr's Avatar
Drives: 2018 Golf R
Well, my friend just posted this:
That was a 15x7 Rota that was on his Civic. He was doing about 30mph one a side street when it happened. He said he could barely contain his laughter as the barrel of the wheel rolled down the block and into someones yard
Parting out HERE
civicdrivr is offline   Reply With Quote
Old 05-14-2012, 12:07 PM   #1328
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
That looks like an impact for the rim to have that damage.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 05-14-2012, 12:11 PM   #1329
igorot
Sneakerhead
igorot's Avatar
Drives: 2003 Honda Civic Si
Yeh, there has to have been previous damage to just go off like that
igorot is offline   Reply With Quote
Old 05-14-2012, 12:50 PM   #1330
Duff_man
Duff_man's Avatar
Drives: Ultramarine FR-S
I'll prolly wait until next summer to buy a fancy set of wheels and tires( RPF1 or OZ alleggerita hlt most likely). But for now I'll keep it on stock wheel and tires, but since I really hate painted/machined finish on stock wheel, I'm going to order a few cans of matte black or white plastidip and give them a bit of a facelift
Duff_man is offline   Reply With Quote
How to embed a YouTube video in a post ichitaka05 Site Announcements / Questions / Issues 71 03-21-2021 03:47 AM
Post your Workspace. Ricepuddin Off-Topic Lounge [WARNING: NO POLITICS] 10 11-25-2014 10:15 AM
Post your Desktop Ricepuddin Off-Topic Lounge [WARNING: NO POLITICS] 125 10-10-2013 02:38 PM
Any news or updates for Oz post here Calais AUSTRALIA 92 07-28-2011 06:55 AM
