Old 01-26-2015, 03:45 PM   #351
jayhoang
jayhoang's Avatar
Drives: 2014 Scion FRS
Originally Posted by TylerLieberman View Post
Thanks! Visually, it's definitely the car has ever been.
The problem was that the car could no longer function in the way I wanted it to. 9.5j wheels are very big for this car up front; especially when you start adding in extra steering angle.
Big wheels and big tires with big steering angle under little fender wells is bad news waiting to happen. I didn't want to risk seriously damaging something so I decided to just bite the bullet and cut my losses.
I'm definitely bummed about it but when I look at my bank account, I suddenly don't feel so sad anymore lol
Interesting! What was your offset? I'm going to be running 9.5 +40 but on 245's. I wanted to go with 265's at first but thought I should play it safe first... The 265's look nice and perfect on yours, but I guess if you need room then it's too tight.
The Todoroki gives extra room, correct?
http://www.lifewithjson.com
Instagram: jayhoang
jayhoang is offline   Reply With Quote
Old 01-26-2015, 03:58 PM   #352
TylerLieberman
TylerLieberman's Avatar
Drives: '24 GR86
The wheels were the same as yours, just Mag Blue SLs(18x9.5 +40). With the spacers though, I was running a +16 offset.
The Todoroki's are 30mm wider so I was able to space the wheel out and have it further away from the frame rails; which I figured would be enough. The problem is the boxer engine; it's so wide that frame rails take up a lot of space underneath the front fenders.
Even with the spacers and calculating out the difference by getting extended LCAs, it still wouldn't be enough to clear the front fenders. I could MAYBE fit it with like -6 camber and 215/40s up front but even then it would be questionable and would cost be another $1,000 to get everything needed.
Too much money to spend on something that still probably wouldn't work; so I just said screw it and bought some temp wheels and started selling a bunch of stuff off haha
Old 01-26-2015, 04:01 PM   #353
jayhoang
jayhoang's Avatar
So without spacers, was it hitting something to begin with? Just trying to wrap my head around this as this is a fairly common size to run. Unless of course you're trying to achieve something other than just daily driving/occasional track days.
Instagram: jayhoang
Old 01-26-2015, 04:07 PM   #354
TylerLieberman
Drives: '24 GR86
They'll fit perfectly fine without spacers or wide fenders.
My issue is that I have increased steering angle cause I drift this car. Stock steering angle wasn't enough so I made changes to get more and as the wheels turn more, they get closer to the frame rails as they hit full lock.
That's where I started running into problems.
Old 01-26-2015, 04:25 PM   #355
jayhoang
jayhoang's Avatar
Ah gotcha. That's the part I was missing!
Good luck! At least your bank account isn't suffering anymore!
Instagram: jayhoang
Old 01-27-2015, 03:10 PM   #356
TylerLieberman
Drives: '24 GR86
I've been getting people asking a bunch about my steering wheel and stuff recently.
It's a Key!s Racing OEM replacement wheel; similar to the Prova/Cusco/DAMD wheels.
It allows you to retain your airbag and cruise control but the wheel is a bit smaller in overall diameter. The wheel is also a bit thicker and the quality of the material is MUCH better than OEM. It still feels super natural while drifting and having the wheel spin through my hands. It also is really comfortable on a day to day basis on my commute. I'd say that this wheel is the best of both worlds and worth every penny. I got it from the guys @Touge Factory. Awesome pricing and awesome service as always.
In regards to the emblem itself, it was custom made and swapped out with the scion emblem on the airbag. I think it ties it all together pretty well.
The Following 2 Users Say Thank You to TylerLieberman For This Useful Post:
Carlos_M (01-27-2015), Touge Factory (01-27-2015)
Old 01-27-2015, 04:47 PM   #357
Touge Factory
Touge Factory's Avatar
Drives: ZN6
Send a message via AIM to Touge Factory
you're 5x114 now right?
Touge Factory is offline   Reply With Quote
Old 01-27-2015, 04:50 PM   #358
TylerLieberman
Drives: '24 GR86
5x100 still.
If only the right 5x114 wheels came along, I'd be willing to run conversion adapters
Old 01-27-2015, 06:17 PM   #359
Touge Factory
Drives: ZN6
5x100 still.
I think if you convert to 5x114, the doors would open to more options...instead of waiting for "the one" lol
We've been running the 10mm conversion spacers, and we're able to try out a lot more wheels with various offsets.
17x9 +29'ish Advans are plentiful...
I know modified knuckle guys can't run much wider then 9" wheels due to the added angle.
Old 01-27-2015, 07:43 PM   #360
TylerLieberman
Drives: '24 GR86
I tried numerous times while I was deployed to find some used wheels in jp. I looked for blitz 03s, SSR minervas, Panas, model5s, and even VSKFs, but there wasn't really anything that would be a good starting point to rebuild. Everything decent would end up costing me like 3500 in the end.
I found out today I might get to ETS from the Army early and if it happens, I'll be back in California this fall. Once I get out there and get everything situated, I may try again.
I'm pretty set on some 17x8/9 or 17x9 squared bronze model5s. I'll happily run conversion spacers for them too lol.
Old 02-04-2015, 02:21 PM   #361
TWMPerformance
Drives: Manual Transmission, All the Way!
Oh man! Love this car man
Renato
Team TWM Performance
TWMPerformance is offline   Reply With Quote
Old 02-04-2015, 04:58 PM   #362
GuerillaRacing
GuerillaRacing's Avatar
Drives: Scion FR-S
Love the build man.
GuerillaRacing is offline   Reply With Quote
Old 02-05-2015, 07:18 PM   #363
TylerLieberman
Drives: '24 GR86
Seems I have some work to do next weekend
The Following User Says Thank You to TylerLieberman For This Useful Post:
Touge Factory (02-06-2015)
Old 02-05-2015, 09:25 PM   #364
gk
Drives: 2013 Raven FR-S
What are the square things used for above the camber bolts?
gk is offline   Reply With Quote
KO's Raven FR-S Build: Name "Raven12s" KO Member's Car Journals 3 07-18-2013 02:09 AM
WORK KIWAMI 18" x 9.5" + 18" x 8.5" +38 Offset GC GTS Aero Kit Australia Classifieds 16 03-22-2013 05:49 AM
Which Markets have "GT86" and "Toyota" badges on trunk? Tanuki Scion FR-S / Toyota 86 GT86 General Forum 20 02-10-2013 05:23 PM
Anyone else try running "square" tires on "staggered" wheels? hamlet Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 21 12-19-2012 12:59 PM
Five Axis Spoiler - Painted "RAVEN" Black that_guy Canada Classifieds 29 12-18-2012 08:34 AM
