Old 01-25-2015, 04:41 AM   #1
Mike Brz
what is the optimal rim and tire size for 1/4 mile?
Hey guys. Wanted to know what the best rim and tire size for a 1/4mile. Brz is ~205whp naturally aspirated. Looking for best size for optimal gearing. i was thinking to go with 16x8 rims for the rear, (not sure what tire size, i was thinking to go with a smaller rolling diameter than stock) and fronts id get 16x5 rims. Thanks
Mike Brz is offline
Old 01-25-2015, 05:04 AM   #2
fatoni
Please don't.
Drive upgrades. Don't buy them.
fatoni is offline
The Following User Says Thank You to fatoni For This Useful Post:
SkAsphalt (02-03-2015)
Old 01-25-2015, 08:02 AM   #3
slicktop
Drives: 2013 Raven FRS 2JZ-GTE/V160 swapped
At that power level, you could run your daily setup just fine. Expect low-mid 14s.
Why would you want smaller rolling diameter?
slicktop is offline
Old 01-25-2015, 09:00 AM   #4
raven1231
Drag radials! Add a wheelie bar just in case
raven1231 is offline
#maverick# (02-07-2015)
Old 01-25-2015, 09:09 AM   #5
AJPG
Drives: 22RE, FA20, 4G63
AJPG is offline
Old 01-25-2015, 03:38 PM   #6
Mike Brz
Wow useless info. I guess this is why no one uses the forum anymore
Mike Brz is offline
Old 01-25-2015, 04:13 PM   #7
Mikeez
Engineering Student
Drives: Scion FR-S 2015
Hahaa, many people here are useless. They are here just to insult you, make fun of you and it is very intimitading. I blame the moderators for not stepping up. Anyways, I just ignore those kids.
I've seen few youtube videos, they are usually running 15 inches wheels and meaty tires. So more rubber, less metal. The more there is ground patch, then the more the power will be deliveried. In other words, 15x8.5-9 would be an ideal.
However, 200 horsepower on the wheel. It won't matter as much. Running 18x8.0 will be almost equivalent to 15x8.5-9
Hope it helped.
LET ME KNOW YOUR SCORES
There’s no time to stop for gas, we’re already late
Mikeez is offline
The Following 2 Users Say Thank You to Mikeez For This Useful Post:
Dadhawk (01-29-2015), Mike Brz (01-26-2015)
Old 01-26-2015, 01:39 AM   #8
Mike Brz
Hope it helped.
Thanks. Well so far i run 14.8-14.9 in the 1/4 but im upgrading a few more goodies and getting a e85 tune so just hope to get low 14's or break into the 13's. My real questionis what rolling diameter tire will be best for a 1/4 mile? Im going to use 16x8 because most 15's wont fit. The height or rolling diameter. Can affect 1/4 mile times in a negative or positve way but i doubt the factory size is optional for the fastest 1/4 mile time
Mike Brz is offline
Old 01-26-2015, 01:46 AM   #9
Mike Brz
Smaller rolling diameter is going to be easier for the engine to turn the wheels. Also faster acceleration but lower top speed in 1/4 mile. Larger diameter would be easier to hook but slower acceleration with higher top speed. Im just wondering if anyone has found the sweet spot for a 210whp brz
Mike Brz is offline
Old 01-26-2015, 01:51 AM   #10
dobbrz
Drives: RB v1 FRS
please tell me you didn't buy this for 1/4 mile
PROPΔGΔNDΔ
DRIVEN TO INFLUENCE
instagram: @andrewdobbie93
dobbrz is offline
The Following 2 Users Say Thank You to dobbrz For This Useful Post:
adamg (01-26-2015), NWFRS (02-17-2016)
Old 01-26-2015, 09:22 AM   #11
TheVoiceOfReason
TheVoiceOfReason's Avatar
Drives: BRZ Limited
I don't think anyone here will take this question seriously or will have an answer for you because nobody with around 200whp is going to be experimenting with which tire diameter is going to gain them .1 seconds (if that). They are going to put that money in to the turbo kit they want or give up drag racing this car. The driver is going to make far more difference than the tire diameter anyway.
TheVoiceOfReason is offline
The Following 5 Users Say Thank You to TheVoiceOfReason For This Useful Post:
adamg (01-26-2015), Dipstik-sportech (02-08-2015), NWFRS (02-17-2016), Pat.Thornton (02-16-2016), Tcoat (01-26-2015)
Old 01-26-2015, 09:25 AM   #12
adamg
Drives: brz
this thread is great
adamg is offline
The Following 3 Users Say Thank You to adamg For This Useful Post:
Mike Brz (01-28-2015), raven1231 (01-26-2015), Tcoat (01-26-2015)
Old 01-26-2015, 09:56 AM   #13
Ya pretty much your standard "I have already made up my mind and will argue with everybody that answers then whine when they don't say what I want since this forum is useless and everybody is just mean and childish" thread.
Tcoat is offline
Arigh (01-26-2015), NWFRS (02-17-2016), Pat.Thornton (02-16-2016), Rabbit of Caerbonnog (01-26-2015)
Old 01-26-2015, 11:10 AM   #14
Amaya
Amaya's Avatar
Drives: 2015 Scion FR-S 6MT
Ok, so drag racing isn't really what these cars are best for but that's what you want to do with it so I will go with it. I have taken mine to an 1/8th mile dragstrip and hopefully I can go back soon for a comparison now that I have bigger/better tires. I will tell you what I would do as a starting point if I was going to be drag racing this car.
Remove spare tire, tools, front passenger seat and rear seats, floor mats, owners manual, cup holder, and any junk you keep in it (go look at the weight reduction thread).
Rear wheels: Enkei RPF1 17x9 offset about +40 (+/-5)
Rear tires: high performance summer tires size 255/40 (or /35 or /45 whatever is available)
Front wheels: Enkei RPF1 17x7 +35
Front tires: same as rear but in a 225/40ish size
Run max tire pressure (or higher but only on the track) on the front and experiment with the rear tire pressure. Start at normal pressure and drop the pressure by about 1 psi at a time.
Find the lightest exhaust setup that fits your budget (there's a thread that lists weights go search for it). That will mean headers, no cats, single exit, muffler delete and it will probably be loud and obnoxious as fuck.
Cut up the intake snorkel, search for threads about intakes and you'll see what I'm talking about.
Get a tune, either off the shelf or custom.
Get a higher final drive, I know there's a 4.88 available.
At this point you have spent a decent bit of money and invested quite some time (unless you paid someone to do the work, in which case more money) and you haven't really done anything that can't be reversed. The car also remains "streetable" (even if not street legal) although that is a relative term, I have daily driven a fully stripped down Honda that weighed less than 1800lbs but not everyone is as crazy as I am.
If this is a dedicated track car go ahead and remove trim, carpeting, radio/speakers, a/c system, airbags, and start replacing parts with lighter components, every ounce will make a difference.
Now that is if you aren't going to be using forced induction. But if you are then I would just start with wheels/tires and whatever FI system you prefer. If I wanted a fast drag car I would just go straight for FI, then worry about weight reduction later. Or even better, use a different car :P
Amaya is offline
The Following 2 Users Say Thank You to Amaya For This Useful Post:
Dadhawk (01-29-2015), Tcoat (01-26-2015)
Optimal Wheel Size for Stock Power Tanuki Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 110 06-09-2016 10:08 PM
optimal tire size for stock wheels brillo Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 20 12-05-2015 12:01 PM
Optimal tire size for DD and canyon driving? ashtray Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 18 11-26-2014 04:22 PM
Optimal Tire Size For Stock Rims Raven604 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 04-05-2013 08:41 PM
optimal street tire size for RTR on 17x7 hankster Tracking / Autocross / HPDE / Drifting 110 03-21-2013 12:40 AM
