#113 | |
This has little to do with the actual engine and the parts the caused it to fail and more to do with Toyota and the politics around a new engine, and repair in general. I'm hoping it all ends up on the up and up for my good buddy. It should. He's done nothing wrong, and honestly, he's a hell of a good guy. If anyone deserves a break on this, it's him. Edit: Seems like I got out of the car just in time (have an M3 now). Subaru has been hard to get warranty work done for a bit now because of the older sti's that ruined it. Now that toyota has jumped in on the "we won't fix it" bandwagon, I'm glad I don't have it anymore. Sad. Such a fun, bad ass little car. Shame the manufacturers are going to ruin it. |
#114 | |
FT86Club Vancouver
Drives: BRZ Sport-Tech; Drove: MR-S, AE86
Not to also mention... The way some people drive it, mod it, etc. Many reasons why things can go wrong as per Murphy's Law... HOWEVER, yes... there also can be lemons... Sir, I love you. Nohomo...
1984 AE86 BT 20V 5MT 2007-2012
2000 MR-S 5MT 2010-2012 2013 BRZ Sport-Tech 6AT Since '12 (OEM+ STI tS Build) 2015 Lexus IS250 AWD F-Sport 2 2015-2018 2018 Lexus NX300 F-Sport 3 Since '18 |
#115 | |
And I love me too. No narcissism...
#116 |
Drives: WRB Limited BRZ
Aww man, just reading this thread kinda scares me. I've seen people in this thread say how much they love this car but has to deal with warranty issues.
Mine has almost 15K miles, I haven't checked it lately because I been car pooling to work. But man I hope my engine is fine, and will last. I also plan on Supercharging it in the future. |
#117 | |
Engine Failure (#4 Rod Bearing + Short Block)
Chances of a bad engine aren't high. Example @whataboutbob and @DriftEm. I've watched these two build their cars and beat the livin' piss out of them without major issues. The cars are pretty stout, but those couple bad ones are going to stand out. Like I mentioned before, there will be hiccups on a new motor. The car was honestly THE best handling and balanced car I've owned. (Over my E46m3 and my current E36 M3) Sent from my iPhone using Tapatalk |
#118 | |
All new cars can have problems. When on here you hear about those problems. There is a list of about 300 people that claim to have "major" issues. So lets take a worst case scenario and say (purely a speculative number it could be way high or low) the total number of people with major issues may as high as 1000. This is 1% of the cars out there! What you don't hear about are the other 99% of the owners that never had a single issue. Don't get paranoid because you read that somebody or even 100 or 500 somebodies had an issue because that does not mean everybody has or ever will!
#119 | |
Preach on!!!!!! Sent from my iPhone using Tapatalk |
#120 | |
#121 |
#122 | |
We are all concerned about our new cars.
#123 |
Just chiming in here that I had the exact same issue with my FR-S at 20,000~ish miles that ended up being a bearing on cylinder 4 (rod knock). Exact same sound as video and descriptions, ended up getting a replacement engine pull under warranty from a wrecked BRZ (102 miles). Granted Toyota would not cover my warranty for various excuse reasons, this car had all maintenance done by the original dealer it was purchased from and from the local dealer in my city since. The dealer I bought it from had to fork out for the replacement engine and the dealer in my city worked the service order to keep my power train warranty intact. Getting a new engine from the sound of all this is the best that could have ended up happening in my situation because it sounds like the first runs on these cars are prone (same rod bearing cylinder 4).
Knocking doesn't sound good :-(. I'm over 16,000 miles on the new engine with no issues, I did get the latest ECU updates after the engine swap as well. Original engine gave no CEL's or warning, just started knocking. Also notate what casting your front cover has (you know the thing with the oil pump and oil passages). My original engine that spun rod bearing cylinder 4 has a "#1" with an eagle / bird stamping, my new engine pull from a later 13 / early 14 BRZ has a "#2" with no logo stampings on the front cover. No issues like I said 16,000 miles now, I smell production issues and Toyota / Subaru is not wanting to cause some type of bigger attention. Also wanted to note that my car originally had Toyota engineers / service team on-site with it originally over various engine issues early on in it's life, guess with good reason. I'm floored that they left it hanging and blamed the customer, again every service like clockwork with Toyota and oil always checked. |
#124 |
Drives: sentra ser
these guys talk about a weakness on FA20... issue related to oil. you guys might want to take a look.
watch from 3.57 |
#125 | |
Drives: Firestorm 2013 FR-S
He says the variable valve timing device fails, leading to oil pressure to the rest of the engine low enough to destroy it but not low enough to trigger the low oil pressure light, which only glows at 4psi or less. This makes perfect sense. I haven't read all the pages, but in the OP's case I suspect the tech didn't put enough oil in at the last change. My understanding is that dealerships don't use jugs but rather a device on which you set a knob to determine how much goes in. Faulty setting or device + tech not checking dipstick = ruined engine.
1995 BMW M3, 1973 DeTomaso Pantera, 1972 Dino 246GT, 1964 Fiat-Abarth 1000TC vintage racer
#126 | ||
Drives: 2013 GBS BRZ Limited
Makes me wonder if a bad tune, or a failed cam position sensor can starve the engine of oil pressure. If this failure mode has any basis in reality, then Toy/Sub would have zero problem blaming an engine failure on an aftermarket tune.... |
| Full Blown Stage 1 Short Block | FullBlown | Forced Induction | 116 | 03-22-2019 07:29 PM |
| Upgraded short block installed? | Yruyur | Issues | Warranty | Recalls / TSB | 13 | 01-28-2014 09:13 PM |
| Built B18B Short Block | C130NAV | Miscellaneous | 0 | 01-04-2014 12:15 PM |
| FA20 oem Short Block 3k miles | Area51 | Engine, Exhaust, Bolt-Ons | 29 | 09-13-2013 01:01 AM |
| WTB: short block or long block | DOTman05 | Engine, Exhaust, Bolt-Ons | 2 | 07-14-2013 06:48 AM |
