Old 01-21-2015, 02:35 PM   #1
BboyKidKoda
BboyKidKoda's Avatar
Drives: Scion Frs
Please help!
I went to go start y car and would not turn over. The radio, ac, windows, charger ports, and drls are not either. I managed to get it started by popping the clutch and it had no power steering, and still had none of the other things. The mph were not working either and all the lights were on the dash too. My car would also not go above 4k rpm it acted as I hit the rev limiter. Can someone please help me!
Be original don't copy!
BboyKidKoda is offline   Reply With Quote
Old 01-21-2015, 02:39 PM   #2
Battery is toast.
Old 01-21-2015, 02:39 PM   #3
frslee
Just drive it
Drives: 13' FR-S
Call your local toyota dealer. Seriously.
frslee is offline   Reply With Quote
Old 01-21-2015, 02:40 PM   #4
Xuningshen
Drives: Subaru BRZ
whenever the check engine light is on, the ECU goes into "limp" mode, and wont go over 4k rpms to protect itself.. so I wouldn't worry about that part of your problems.
2014 WRB BRZ
Xuningshen is offline   Reply With Quote
Old 01-21-2015, 02:43 PM   #5
BboyKidKoda
Drives: Scion Frs
Let me also say. I put a new battery in and did the same thing. I checked all my fuses and relays. Hooked a multimeter up. Changed the positive terminal and nothing. It all still did not work
Old 01-21-2015, 03:01 PM   #6
Celadrielas
Celadrielas's Avatar
Drives: 2013 Asphalt Fr-S
Battery -- tested. Move to Alternator. A faulty Alternator could drain a battery.
I, however, would be getting it to a dealer. I have a warranty for a reason.
Old 01-21-2015, 03:34 PM   #7
BboyKidKoda
Drives: Scion Frs
Yeah. I checked alternator too. Seems fine. And it's not starting anyways even after I charged battery up. I just hope I didn't void warranty. I Have a intake on it and suspension that's about it tho
Old 01-21-2015, 03:41 PM   #8
Well you have covered just about everything that anybody here could tell you to check so let's take a look:
Intake and suspension are not likely related so should not be an issue for warranty.
Get it to the dealer or a garage that can actually look at it!
Koa (01-21-2015)
Old 01-21-2015, 03:44 PM   #9
BboyKidKoda
Drives: Scion Frs
Yeah I work at a garage. Mechanics here soad wiring could be broken,cut, loose something like that. Will take to dealer asap. My local one sucks, suabru is across the street but will likely do nothig. Have to take to next town over where I bought the car anyways I'm sure. Thanks for the help so far. Really weird issue. Happened out of the blue too
The Following User Says Thank You to BboyKidKoda For This Useful Post:
Tcoat (01-21-2015)
Old 01-21-2015, 03:45 PM   #10
BboyKidKoda
Drives: Scion Frs
I do also have a headerback exhaust
Old 01-21-2015, 03:46 PM   #11
[QUOTE=BboyKidKoda;2099776] Happened out of the blue too
QUOTE]
Electrical issues frequently do!
Old 01-21-2015, 03:59 PM   #12
BboyKidKoda
Drives: Scion Frs
I know haha. Just sucks
Old 01-21-2015, 06:51 PM   #13
BboyKidKoda
Drives: Scion Frs
So I dropped off at dealership. Hope to hear something tomorrow
Tcoat (01-21-2015)
Old 01-21-2015, 08:06 PM   #14
Jond63
Jond63's Avatar
Drives: FR-S Firestorm 2013
Had this issue on my S2K a few winters ago -- a squirrel had gotten into the engine compartment and chewed through part of the wire harness.
Jond63 is offline   Reply With Quote
