Old 01-20-2015, 06:12 PM   #1
2much
I wanna go fast
Drives: 2013 FR-S 6MT
OFT - flashing back to stock for dealership work
Hi all,
I am taking my 86 into the dealership today because I've discovered some heavy oil leakage, sourced either from the valve covers or timing cover. I expect this to be warranty covered, so naturally as a precaution I've re-flashed the oem ecu ROM.
However, the car is still in dead-pedal mode. Much more throttle input is needed to move the car anywhere, from what I understand the car is training itself all over again.
My question is, if the pedal is still less than responsive upon delivering the car to the dealership, can that get in some sort of trouble regarding warranty?
2much is offline   Reply With Quote
Old 01-20-2015, 06:35 PM   #2
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
Originally Posted by 2much View Post
Hi all,
I don't think you have anything to worry about with regard to dead pedal. As far as the dealership is concerned you could have just easily induced that by disconnecting the battery momentarily. Our car also had an oil leak from the passenger side valve cover. There is a plate that is poorly sealed from the factory that tends to leak over time. And the drop of oil land right on the overpipe causing a burning oil smell. Fortunately, it's an inexpensive and easy fix to replace and reseal it. Assuming that is your problem of course.
Shiv@Openflash is offline   Reply With Quote
The Following User Says Thank You to Shiv@Openflash For This Useful Post:
2much (01-20-2015)
Old 01-20-2015, 06:42 PM   #3
2much
I wanna go fast
we shall see exactly what they diagnose. thanks for the input!
Old 01-20-2015, 07:17 PM   #4
Tromatic
I went in for a few transmission CEL in November with the OFT ROM. They had to drag out the fancy data tool to diagnose the CEL, nobody said a word about the ROM. YMMV!
Old 01-20-2015, 09:03 PM   #5
2much
I wanna go fast
I have taken it in with the oft rom applied before, and they didnt care. I believe it was tuned when I got my full service and fuel pump replaced. didn't want to take a chance this time though.
I got a Corolla loaner car... its so depressing. But on the bright side I already appreciate and miss my 86 more.
Old 01-20-2015, 09:57 PM   #6
Toyota John
Calle Atun
Drives: 13 FRS, 93 Mr2, 85 ae86
I got Techstream to work tonight. I have an ecutek tune on my car right now. I don't now if I have the full version but everything I tried to do it seemed to work. It read the cal id B01C with the ecutek tune. I would guess that would be as far as the techs would get? With open source I am almost 100% positive then wouldn't know with out detailed logging that it is on there. And they would still have to know what the stock parameters for the car should be. Pretty sure they would need to be an frs expert to know.
Toyota John is offline   Reply With Quote
Old 01-20-2015, 11:52 PM   #7
Error
Error's Avatar
Drives: FRS
Although I haven't purchased the OFT + OFH yet, I'm planning on getting it soon. Quick question regarding the dead pedal though, recently took my car out of winter storage and reconnected battery. Currently experiencing dead pedal spot, really annoying cause it throws off the clutch throttle blend. Any idea how long it takes for it to relearn?
Error is offline   Reply With Quote
Old 01-21-2015, 02:46 AM   #8
2much
I wanna go fast
usually about 50 miles or so. for me a day or two. drive the car smoothly for quicker results.
The Following User Says Thank You to 2much For This Useful Post:
Error (01-21-2015)
Old 01-21-2015, 12:59 PM   #9
Jyn
Noob
Jyn's Avatar
Drives: FR-S Mammogram
Pump the gas pedal in ACC and then full electronics 4-5 times. I've reset my battery a lot and it seems to help. I do kinda slow pumps, but I'm not sure if the speed makes a difference.
Jyn is offline   Reply With Quote
The Following User Says Thank You to Jyn For This Useful Post:
Error (01-21-2015)
Old 01-21-2015, 02:13 PM   #10
Error
Error's Avatar
Drives: FRS
Thanks for the tips, I'll try out the gas pedal pump trick. Before if I breathed on the throttle it would rev.
Best dealership for warranty/TSB work? Tainen Northwest 5 07-10-2018 03:26 PM
OFT - Flashing to stock error Kody Software Tuning 14 08-23-2016 03:41 PM
Work or worked at a dealership? Need help. peachsnow Scion FR-S / Toyota 86 GT86 General Forum 70 11-28-2014 06:07 PM
Flashing from openecu back to stock mhiscott Software Tuning 2 08-23-2014 09:41 PM
Does anybody work at a Lexus Dealership? PradiG Southern California 1 06-19-2013 07:09 PM
