Old 01-20-2015, 10:11 AM   #127
SkAsphalt
Ridge Racerrrrrrrrr
SkAsphalt's Avatar
Originally Posted by GT86_PRAGUE View Post
Nothing new?
It has been a while, car is put away for the winter but I have several small projects underway.
  • Interior upgrade (dash panels, potentially the steering wheel and door cards)
  • New shift knob from Anarchy Motive on the way
  • Motec Shift Springs
  • Aluminum reverse lock out to replace the cheap factory plastic one
  • Front lip needs to be installed
  • I have a few options for the fender garnishes - don't know which to go with yet or just to stay with the stock 86 piston ones
  • Rear fog needs to be wired in (I put the bulb in and did all of that work already, just need to wire it in to the marker lights so it comes on with the running lights
  • Delicious Tuning flash and go tune, new map sensor, electronic boost controller and better tune will be done in the spring as well
I have been looking at different sets of wheels too, wouldn't mind going to a 17x8 or 18x8 square set up with some nice light wheels but I have not settled on anything yet. Some sort of rear sub-frame mounts/bushings/collars will go in as well. Maybe just the Whiteline bushings.
The Following User Says Thank You to SkAsphalt For This Useful Post:
GT86_PRAGUE (01-20-2015)
Old 01-20-2015, 11:02 AM   #128
GT86_PRAGUE
Drives: GT86
Yeah, that Goliath is sick in acid green. I would like to have it in this color, but it wouldnt match my car. So I went for more OEM look.
You dont have any shortshifter?
I would like to get TWS 17x8, they should be very similar to TRD and they are not so expensive when ordering from Japan.
I have rear from Whiteline and I like it, except the cost of it.
GT86_PRAGUE is offline   Reply With Quote
The Following User Says Thank You to GT86_PRAGUE For This Useful Post:
SkAsphalt (01-20-2015)
Old 01-20-2015, 03:35 PM   #129
SkAsphalt
Ridge Racerrrrrrrrr
SkAsphalt's Avatar
I have kind of always wanted TSW Nurburgring rims because they remind me so much of some of Porsche's wheels but I like my big brembo's up front...sigh. one day I will find some rims that work for me.
Would you say BRZ side fender garnish (with the chrome bit) or the Aero stabilizer fins? Random question.
Old 01-20-2015, 04:28 PM   #130
Scottemad123
Drives: 2014 SWP BRZ Limited
I believe that the 17x8's fit the sprint kit, is the Brembo kit wider? (thinking about the 18x8's myself actually)
Scottemad123 is offline   Reply With Quote
Old 01-21-2015, 03:37 AM   #131
GT86_PRAGUE
Drives: GT86
TWS not TSW :-)
But I like those Nurburgrings too.
I like TRD aero fins, but not their price. I would rather get this money into performance upgrade first.
What best brakes could you fit into 17/8?
Old 01-21-2015, 09:50 AM   #132
SkAsphalt
Ridge Racerrrrrrrrr
SkAsphalt's Avatar
TWS not TSW :-)
You can fit the STi brembo set up into a few 17x8's. Cheap example would be Enkei RPf1 at +45. Could also get some volks that would fit. But you did say "best brakes" so that would probably be a good Alcon kit
GT86_PRAGUE (01-21-2015)
Old 01-21-2015, 10:03 AM   #133
Scottemad123
TWS not TSW :-)
If only I could get the Mrs. to not have a heart attack if I got a set of TWS wheels. They are around $800 per wheel here.
The Following User Says Thank You to Scottemad123 For This Useful Post:
Old 01-21-2015, 10:37 AM   #134
GT86_PRAGUE
Drives: GT86
At least you can buy them. I have to order them from Japan.
And I would deny to tell my Mrs. their price
SkAsphalt (03-17-2015)
Old 04-27-2015, 02:56 PM   #135
SkAsphalt
Ridge Racerrrrrrrrr
SkAsphalt's Avatar
Some new photos coming in
Photos by Dustin Veitch, behind the scenes write-up of the photo shoot can be found here
CrazyWookiee (01-28-2016)
asphalt, avo turbo kit, brembo big brake kit, jpm coachworks, rota
Saskatchewan Thread Jlturner CANADA 3467 09-18-2022 05:00 PM
Asphalt FR-S 6MT in STL, MO jwtscion Dealer Cars 2 07-27-2012 12:50 PM
Any Saskatchewan FRS owners out here? SkAsphalt CANADA 4 07-25-2012 01:00 PM
Got my Asphalt! killa.sushi.robot Scion FR-S / Toyota 86 GT86 General Forum 20 06-30-2012 02:02 PM
Asphalt 6MT FR-S Symbiont Southern California 22 06-06-2012 08:47 AM
