Old 12-15-2014, 01:06 PM   #85
NonStopTuning
NonStopTuning's Avatar
Drives: AE86
Originally Posted by JohnJuan View Post
Should I be able to see silver through the little fins that grip the belt?
Yes, this will eventually happen with anodized pulleys. Nothing major to worry about.
NonStopTuning is offline   Reply With Quote
The Following User Says Thank You to NonStopTuning For This Useful Post:
JohnJuan (12-15-2014)
Old 01-20-2015, 08:51 PM   #86
07jazzrs5gt86
Drives: Firestorm 86
Thanks NST for a great product
Finally got the chance to install the crank pulley , water pump and gates blue belt this past weekend
Didn't have an impact gun so I'll do the alternator later
1st thing I notice is its easier getting off the line and be in my ESC rpm range " 3k+ "
Launching it and activating the ESC is much easier on 1st gear now and It seems like I was able to shave about 0.3+/- 0-60 mph. My previous best is 6.2
Then when I turned off my radio I started to hear a whine that's sounds like a sc whine and my ESC doesn't produce that sound before the pulley install. It's most noticeable on 1st 2nd and 3rd gear then after that its very fient
I've check every thing and can't find anything wrong with the install. No leaks no wobble
I wonder if anyone getting that sc whine
07jazzrs5gt86 is offline   Reply With Quote
Old 01-20-2015, 08:51 PM   #87
07jazzrs5gt86
Old 01-20-2015, 10:35 PM   #88
JohnJuan
JohnJuan's Avatar
Drives: 2013 FR-S, Hot Lava; 2012 Z1000 CBO
Mine makes exactly the same sound. Nothing seems to be wrong.
JohnJuan is offline   Reply With Quote
The Following User Says Thank You to JohnJuan For This Useful Post:
07jazzrs5gt86 (01-21-2015)
Old 01-21-2015, 10:36 AM   #89
vien
Drives: subaru brz
any info in how to install on a Auto? that the problem im running into.............
vien is offline   Reply With Quote
Old 01-21-2015, 03:53 PM   #90
07jazzrs5gt86
Previous page post #67 will help you out
Good luck
Old 01-21-2015, 09:51 PM   #91
JohnJuan
JohnJuan's Avatar
Here's the important part:
Originally Posted by Kuri View Post
proper pulley removal tool for an Auto.
Ask in your local forum. Somebody might be willing to lend you one.
Pbrown (02-03-2015)
Old 01-22-2015, 10:53 AM   #92
vien
Drives: subaru brz
gotcha well then, i wonder if i can just try doing the crank pulley loose with the belt on then take it all off.....
Old 01-22-2015, 12:01 PM   #93
JohnJuan
JohnJuan's Avatar
It seems unlikely, but might work if you're using an impact wrench. it's on there really good. I believe the torque spec is somewhere in the neighborhood of 95(?) ft*lb. Make sure you keep track of the little rubber o-ring that might stick to the back of the stock pulley.
Old 01-22-2015, 12:57 PM   #94
vien
Drives: subaru brz
i do have an impact but i wonder if there is enough space for it tho. ill try my luck that way fist if not i have the breaker bars as well just gotta find a way to hold it still.
Old 01-22-2015, 09:01 PM   #95
JohnJuan
JohnJuan's Avatar
you haven't asked in your local forum yet to see if anyone has the tool. Go do that right now. Barring this, you can buy one for a few bucks, or make one, if you're crafty.
@RallySport Direct Sells them for $45 on their site
If you ask nice, they might get you a better deal.
NonStopTuning (01-31-2015)
Old 01-31-2015, 05:13 PM   #96
NonStopTuning
Drives: AE86
KITS are IN STOCK and ready to ship!
Use PROMO CODE NST10 to save 10% this weekend!!
Old 01-31-2015, 11:39 PM   #97
cslntuee
Drives: Subaru BRZ Limited
Any update for idle pulley (total 3) and the Auto-Tensioner Pulley
which you mention before as below?
Thanks.
http://www.ft86club.com/forums/showp...3&postcount=59
cslntuee is offline   Reply With Quote
Old 02-03-2015, 01:10 PM   #98
NonStopTuning
Drives: AE86
Thanks.
Yes! Those are still in the works. We expect have group buy info soon.
cslntuee (02-03-2015)
AST 5200 Dampers Updated 25th Feb DYNO CHARTS ADDED Captain Snooze Suspension | Chassis | Brakes -- Sponsored by 949 Racing 77 12-17-2015 05:06 AM
NonStopTuning FRS BRZ Pulley Kit Group Buy NonStopTuning Groupbuys 8 05-23-2015 02:27 PM
NonStopTuning 3 piece Pulley Kit - RED harkbrz Canada Classifieds 4 11-01-2014 12:12 PM
NonStopTuning Short Shifter, Info, Ideas, Feedback thread NonStopTuning Engine, Exhaust, Transmission 5 10-23-2014 10:38 PM
Run in method Dyno charts Surok AUSTRALIA 0 10-07-2012 11:29 PM
