orthojoe
Old 01-20-2015, 02:29 PM   #323
CSG Mike
CSG Mike's Avatar
Originally Posted by brzaapi View Post
No I don't. Not for this car anyway. But with the OFT, it shouldn't be hard to get something and take a look at values. In fact I think the OFT may actually show the temps on the screen. But to be honest I have not dived into the OFT too much.
So, for the pedal dance to work, am I right in saying that you want your water temp to be above 190f before the car will allow it.
Thanks everyone. Next AX is Feb 8th...if the weather doesn't kill it.
The exact number is 178F. Unless you have an unusually low thermostat, it shouldn't be affecting it. Toyota/Subaru isn't stupid; they know people will add lower temp thermostats.
brzaapi (01-20-2015)
Old 01-20-2015, 02:35 PM   #324
stugray
Drives: 2013 GBS BRZ Limited
I have have been wanting to make a switch that tells the car that it is warmed up just for the pedal dance.
I even looked up the pinouts on the ECU, but havent dug in any further.
All it needs to do is open the circuit to the cooolant temp sensor, and switch in a fixed resistor.
One you complete the pedal dance, you switch it back to reading real engine temp.
It would probably mess with the ECU running any special "warmup" maps, but it should be inconsequential.
Old 01-20-2015, 02:49 PM   #325
brzaapi
CAR-AHOLIC
brzaapi's Avatar
Drives: 2018 BRZ Ts - CWP
Well if its not the thermostat, and not the tune. I am just perplexed. I really don't think it is user error, but maybe. If anyone else has any ideas, please let me know.
Track Toy - 2018 BRZ Ts - CWP
Daily: Audi TT RS
DD/4WD - Colorado ZR2 Bison - Mallett Supercharger
brzaapi is offline   Reply With Quote
Old 01-20-2015, 03:36 PM   #326
renfield90
The Stig's German cousin
Depending on the design of the state machine in the underlying software, you could kick the system into closed-loop fueling and there may not be a path back into open loop. Then your fuel trims are being calculated/updated based on sensors that haven't come up to temperature. This would self-correct eventually, but it wouldn't sit well with me to drive the car in competition with potentially bad fuel trims. (I've heard WOT is open loop anyway, but still.)
Old 01-20-2015, 04:48 PM   #327
stugray
This should behave the same as restarting with it already warmed up (even though it isnt), so it shouldnt be a problem.
The only difference is going from warm to not warm instantaneously.
I suppose that it's possible to upset the state machine, but I would hope the software is more robust than that.
Old 01-20-2015, 05:09 PM   #328
renfield90
I'm less concerned about breaking the state machine. I'm more concerned about the software making assumptions about things like O2 sensor readiness that aren't true.
Old 01-20-2015, 05:52 PM   #329
stugray
My suggestion would only affect coolant temperature measured value.
Should not affect any other operation.
The system should operate normally under a failed temp sensor, so one reading strangely (jumping abrubptly) should not break it.
Old 01-20-2015, 09:40 PM   #330
CSG Mike
CSG Mike's Avatar
Coolant measured value affects warmup mode...
Old 01-20-2015, 09:40 PM   #331
CSG Mike
CSG Mike's Avatar
Try doing it "slower". Some people rush it, but you can really do it slowly. Make sure the "BRAKE" light goes off between e-brake pulls.
Old 01-21-2015, 10:18 AM   #332
brzaapi
CAR-AHOLIC
brzaapi's Avatar
I will definitely try doing a couple slower run throughs. Thank you sir.
Daily: Audi TT RS
Old 02-04-2015, 08:21 AM   #333
brzaapi
CAR-AHOLIC
brzaapi's Avatar
Alright. I still can not get the pedal dance to disable the nannies. I have an event this Sunday, so I wasted almost an hour trying it over and over.
Finally something occurred to me. I did not install TPMS sensors in my latest set of wheels. I hate tpms, so I didn't bother. But when the car is going through the start up sequence, the tpms is sensor is blinking, and then goes solid since it cant find tire pressure. That is the only thing that happens in my car, that probably doesn't happen in many others. Do you think that sensor/idiot light staying on could cause the car to not allow the Non-Nanny/pedal dance mode.
Like to hear your thoughts.
Daily: Audi TT RS
Old 02-04-2015, 10:52 AM   #334
Lunatic
Lunatic's Avatar
Drives: 2015 Raven FRS
I don't have TPMS on my track wheels and I can still do the pedal dance.
Lunatic is offline   Reply With Quote
Old 02-04-2015, 12:34 PM   #335
brzaapi
CAR-AHOLIC
brzaapi's Avatar
Damn. I thought I found the reason. I may just post a video of me doing the damn thing. But I cant believe I am screwing the sequence up.
Daily: Audi TT RS
Old 02-04-2015, 01:40 PM   #336
CSG Mike
CSG Mike's Avatar
Try flashing a stock map on with your OFT, while on pump gas, and see if you can do it.
Where to buy "heel/toe" shaped gas pedal? dookie11 Scion FR-S / Toyota 86 GT86 General Forum 56 01-22-2019 12:24 PM
Which Markets have "GT86" and "Toyota" badges on trunk? Tanuki Scion FR-S / Toyota 86 GT86 General Forum 20 02-10-2013 06:23 PM
Anyone else try running "square" tires on "staggered" wheels? hamlet Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 21 12-19-2012 01:59 PM
Thoughts on a "component" setup with a 3.5" dash and 6.5" door setup? PatrickSAN Electronics | Audio | NAV | Infotainment 22 11-14-2012 03:12 PM
Dyno testing and "drivetrain loss" serialk11r Other Vehicles & General Automotive Discussions 5 11-03-2011 09:55 AM
