Old 01-19-2015, 08:45 AM   #309
Kido1986
Dodging cones
Kido1986's Avatar
Drives: 2013 BRZ Limited, 93 Z28
Originally Posted by brzaapi View Post
yes sir, car is fully warmed up. I have tried it a half dozen times over the last few weeks. I always try it after I drive somewhere.
Oh, but one problem I didn't think of. I have a mishomoto thermostat installed that definitely keeps my temps lower. Maybe that is not allowing the coolant temp to hit a proper level.
Thanks for your help.
Are you restarting the car first? You have to do it within 30 seconds to start up.
Originally Posted by trevorovert View Post
Originally Posted by mrbillclintong View Post
If you guys spot any riced frs/brz post them here just for laughs no hating please.
Isn't there already a thread like this? It's called aggressive wheels or summat...
C Street Build/Progress Questions about C Street Autocrossing?
Kido1986 is offline   Reply With Quote
The Following User Says Thank You to Kido1986 For This Useful Post:
brzaapi (01-19-2015)
Old 01-19-2015, 10:15 AM   #310
brzaapi
CAR-AHOLIC
brzaapi's Avatar
Drives: 2018 BRZ Ts - CWP
Yes. I turn the car off. Then restart and do the process well within 30secs.
I have tried it with radio on,off
I have tried with foot on clutch, and off
In short I have tried it in numerous combinations.
I was able to do it on my 12 BRZ. But I have never been able to do it on my 15. Now that being said. I didn't try till after I had a flash and thermostat installed.
I don't think the problem is the way I do the pedal dance. But obviously if you think I am doing something wrong please point it out.
Thanks to all for help.
Track Toy - 2018 BRZ Ts - CWP
Daily: Audi TT RS
DD/4WD - Colorado ZR2 Bison - Mallett Supercharger
brzaapi is offline   Reply With Quote
Old 01-19-2015, 12:25 PM   #311
My money's on the thermostat. The stock radiator is REALLY effective and I can't see the difference between "not quite yet" and "ok to dance" on the temp gauge. It's really tight.
Old 01-19-2015, 01:08 PM   #312
CSG Mike
CSG Mike's Avatar
Do you have a tune? If you have an altered startup sequence in your tune or a higher idle, that can prevent the pedal dance from working as well.
brzaapi (01-19-2015), Ultramaroon (01-19-2015)
Old 01-19-2015, 01:52 PM   #313
brzaapi
CAR-AHOLIC
brzaapi's Avatar
Yes sir. I have a UEL header and 91/E85 tune from Shiv at Vishnu/Openflash. Please let me know your thoughts, but obviously I need
to go ask Shiv about this as well since he was the tuner.
Daily: Audi TT RS
Old 01-19-2015, 09:47 PM   #314
troek
troek's Avatar
Drives: 2012 Toyota 86
i have never had an issue with any of my Open Flash tunes, nor has anyone ive read about.
troek is offline   Reply With Quote
Old 01-20-2015, 12:31 AM   #315
CSG Mike
CSG Mike's Avatar
Shiv should know the circumstances under which the Pedal Dance doesn't work, but at the moment, if the other conditions like ECT are met, then it sounds like an issue with your particular tune.
Old 01-20-2015, 09:19 AM   #316
brzaapi
CAR-AHOLIC
brzaapi's Avatar
I agree. I have actually never ran into a problem with any of Shivs tunes, whether it was on a BRZ or Miata.
Daily: Audi TT RS
Old 01-20-2015, 09:21 AM   #317
brzaapi
CAR-AHOLIC
brzaapi's Avatar
Well, I am waiting to hear from Shiv. Do you think it could be a thermostat thing at all? My temp definitely runs cooler.
Daily: Audi TT RS
Old 01-20-2015, 09:31 AM   #318
celica73
I've got an openflash and can verify that the dance works fine with 91 and 93 octane Stage 2 UEL tunes ('13 BRZ). Can't comment on the E85 tune though. I like where the thermostat idea is going. If it's 5 degrees cool then the dance will never work.
Old 01-20-2015, 10:16 AM   #319
renfield90
The Stig's German cousin
Do you have any logging tools? Torque Pro could tell you in five minutes if your temps are too low.
From experience, it doesn't take much cooling to get under the threshold. I could go autocross my car hard in 90+ degree weather, shut the car off in grid and in two minutes when I go to start it again, it's cooled off too much.
The Following 2 Users Say Thank You to renfield90 For This Useful Post:
CSG Mike (01-20-2015), Ultramaroon (01-20-2015)
Old 01-20-2015, 10:47 AM   #320
brzaapi
CAR-AHOLIC
brzaapi's Avatar
No I don't. Not for this car anyway. But with the OFT, it shouldn't be hard to get something and take a look at values. In fact I think the OFT may actually show the temps on the screen. But to be honest I have not dived into the OFT too much.
So, for the pedal dance to work, am I right in saying that you want your water temp to be above 190f before the car will allow it.
Thanks everyone. Next AX is Feb 8th...if the weather doesn't kill it.
Daily: Audi TT RS
Old 01-20-2015, 12:23 PM   #321
stugray
Drives: 2013 GBS BRZ Limited
A ELM327 from ebay for $10 and Torque will allow you to see your temps.
And a tune should not affect the pedal dance as the Engine ECU does not enable/disable TC/VSC. Different ECU.
Old 01-20-2015, 01:01 PM   #322
celica73
OFT logging can show coolant temps.
Where to buy "heel/toe" shaped gas pedal? dookie11 Scion FR-S / Toyota 86 GT86 General Forum 56 01-22-2019 11:24 AM
Which Markets have "GT86" and "Toyota" badges on trunk? Tanuki Scion FR-S / Toyota 86 GT86 General Forum 20 02-10-2013 05:23 PM
Anyone else try running "square" tires on "staggered" wheels? hamlet Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 21 12-19-2012 12:59 PM
Thoughts on a "component" setup with a 3.5" dash and 6.5" door setup? PatrickSAN Electronics | Audio | NAV | Infotainment 22 11-14-2012 02:12 PM
Dyno testing and "drivetrain loss" serialk11r Other Vehicles & General Automotive Discussions 5 11-03-2011 08:55 AM
