Old 01-19-2015, 07:57 PM   #1387
914_WHITE_FRS
914_WHITE_FRS's Avatar
Drives: White 2013 Scion FR-S
I'm not a track person never went to one but someday would like to do it in Connecticut i think they have one or up north. I just like my car to be supercharged so I can enjoy it more. I just like to make my car look super clean and fast. I'm not the type to meet up people and street race. I just want those extra boost to be available.
914_WHITE_FRS is offline   Reply With Quote
Old 01-19-2015, 08:12 PM   #1388
BRZChix
Drives: Subaru BRZ 2013
Originally Posted by Pat View Post
I'd love to see quantifiable evidence backing up this statement. I have no doubt it's helpful, but after 12 track days without one and a well-running engine, I disagree.
Originally Posted by RehabJeff86 View Post
Someone wants to learn the hard way or just not pushing the car at all ....
I didn't push the car much and still learnt it the hard way...
#doublefail
BRZChix is offline   Reply With Quote
Old 01-19-2015, 09:42 PM   #1389
CSG David
CSG David's Avatar
Originally Posted by Boofneenee View Post
Noon question here. How can one dial back the boost on a sc like the jackson to no greater than, say 7 psi at max output? I know turbos an do that with a wastegate and im interested in doing so for the safety and longevity of my engine
The CARB tune is quite safe at 9psi. To give you an idea of how plug and play the system is, it still uses the MAF sensor (despite maxing it out). In other words, it's literally an add-on to your car with no other modifications required.
The oil cooler has always been a questioned component of the system. Just to make it very simple, power output drops when oil temps and water temps increase. While in the heat of the moment, the driver will not realize that the engine out put is a little lower due to excessive heat.
Therefore, oil coolers are absolutely necessary to run safely for track use. Whether you are NA or FI, this is an absolute necessity. If the car is setup for pure street use and maybe a couple spirited runs, we suggest running a slightly different setup to reduce initial cost, however, the JROC kit is quite a good kit with quite a good core at the heart of it.
The Following 3 Users Say Thank You to CSG David For This Useful Post:
*LongFella (01-19-2015), DAN_BRZ (03-11-2015), mkivsoopra (01-19-2015)
Old 01-20-2015, 12:34 AM   #1390
CSG Mike
CSG Mike's Avatar
You can do it yourself. Get an OBD2 scanner or OBD2 bluetooth device of your choice, along with the appropriate app for your smart phone (Torque for android is what I use).
Check your oil temp when you come off track, or log it. You'll want an oil cooler immediately.
The Following 3 Users Say Thank You to CSG Mike For This Useful Post:
buddy32 (01-20-2015), jflogerzi (01-20-2015), Xerious (01-20-2015)
Old 01-20-2015, 12:35 AM   #1391
CSG Mike
CSG Mike's Avatar
Larger pulley (although one is not offered), or a boost controller/wastegate welded onto the intake charge pipe.
However, after 28k miles and counting on the CSG car, I'm not particularly worried about engine longevity with the JRSC. We averaged about 7k miles per engine in our NA 2013, but our 2014 with the JRSC hasn't had any blown engines.
Old 01-20-2015, 12:36 AM   #1392
Xerious
Speed Chaser Thrill Seekr
Xerious's Avatar
Drives: 2014 Asphalt Monogram FR-S 6MT
That's what I use. Work really well. Get a good quality OBD2 BT scanner that xfers data fast so your torque app updates quickly.
Performance: Jackson Racing SC & Oil Cooler, 18x9.5 Gram Lights 57Xtreme Wheels, 255/35 Yokohoma Tires, Rays Volk Racing Black 17hex 12x1.25 lugs, KW V3 C/O, Stance Control Arms
Exterior: LED DRL MOD Kit, Tom's Tail-lights, 5%/40% tint
My Build
Xerious is offline   Reply With Quote
Old 01-20-2015, 12:37 AM   #1393
CSG Mike
CSG Mike's Avatar
If you're never going to track, then you will be okay without the oil cooler.
Old 01-20-2015, 12:40 AM   #1394
CSG Mike
CSG Mike's Avatar
Originally Posted by megamarines View Post
Really now? I'm super interested to see how you do this. Because that's exactly what I'm wanting.
JRSC + CARB tune, then add flex fuel kit of your choice (CSG uses the Delicious flex fuel kit, and also sells it), and get a re-tune.
Old 01-20-2015, 01:05 AM   #1395
megamarines
megamarines's Avatar
Drives: 2015 FR-S RS 1.0
Send a message via AIM to megamarines
Are you guys running multiple tune options or just the one that's retuned?
megamarines is offline   Reply With Quote
Old 01-20-2015, 02:23 AM   #1396
Boofneenee
Go-Kart Enthusiast
Boofneenee's Avatar
Drives: Toyota Scion FRS
Hi having trouble understanding what you mean here. What happens at 7k miles? Is NA naturally aspirated or north america?
FRS
Current mods: K&N air filter, OFT, OFH, berk high flow cat front pipe, Q300 exhaust, lighter wheels
Boofneenee is offline   Reply With Quote
Old 01-20-2015, 02:44 AM   #1397
Xerious
Xerious's Avatar
He's saying that he's blown several naturally aspirated engines (no forced induction) at 7k miles. The fact that his supercharged brz has lasted 25k+ miles shows the quality of the Jackson kit.
My Build
The Following 2 Users Say Thank You to Xerious For This Useful Post:
Boofneenee (01-20-2015), CSG Mike (01-20-2015)
Old 01-20-2015, 02:55 AM   #1398
CSG Mike
CSG Mike's Avatar
Our tune has multiple maps
Old 01-20-2015, 02:56 AM   #1399
CSG Mike
CSG Mike's Avatar
We were averaging about 7000 miles per engine when we were naturally aspirated on our 2013 BRZ with the factory tune, and zero powertrain mods.
Currently we're at a bit over 28k miles, almost all of it boosted, without issue.
Old 01-20-2015, 07:06 AM   #1400
buddy32
Drives: WRB Subaru BRZ Limited
I don't think you will "see" anything immediately. I have been tracking my car at stock power levels without any add-ons oil cooling wise, and have seen oil temps up to 265-270 on Road Atlanta. I use the same set up @CSG Mike mentioned, Torque on an android device, and backed off on the track when I saw those numbers... When you pay for that track time, you want to be out there, able to flog your car with confidence...
buddy32 is offline   Reply With Quote
Jackson Racing Rotrex Supercharger System Info and Discussion Jackson Racing Forced Induction 827 04-06-2020 04:56 PM
Jackson Racing Supercharger Press Release and Info CounterSpace Garage Forced Induction 110 01-03-2017 09:04 PM
jackson Racing engine oil cooler - modular to fit the Jackson Racing Supercharger! CSG Mike Forced Induction 24 04-27-2016 12:59 PM
Jackson Racing supercharger NoppyNop Forced Induction 241 06-26-2014 03:05 PM
Jackson Racing Supercharger Pre-Order Sale, $200 off! Xero-Limit Forced Induction 2 03-05-2014 04:14 PM
