Old 01-18-2015, 04:26 AM   #29
350matt
Drives: toyota mr2/ Toyota GT86
That data will be off their engine test dyno I suspect
and the kit produces about 0.5 Bar (7-8psi) of boost I believe
I dare say someone will take the plunge and let us all know soon enough
350matt is offline   Reply With Quote
Old 01-19-2015, 12:53 PM   #30
Cards2323
Drives: 2014 BRZ Limited-SWP
Any clue what these other kits are expected to put down?
Cards2323 is offline   Reply With Quote
Old 01-19-2015, 10:43 PM   #31
weederr33
Airborne at your service
weederr33's Avatar
Drives: '17 BRZ Series.Yellow
For PD superchargers such as the Innovative, or Cosworth, does anyone know which oil coolers work best with them? I've been eyeballing either the Perrin or Mishimoto oil cooler.
Old 01-20-2015, 01:56 AM   #32
sw20kosh
Drives: 2013 Black FR-S
If you track the car, neither of those. Those are barely enough for NA motors. I would go with the Jackson Racing Oil Cooler at least. It is sized for tracking a superchaged FA20. NA guys around here are using the NA version (same core).
@CSG David @CSG Mike @WoOosOn
The Following User Says Thank You to sw20kosh For This Useful Post:
WoOosOn (01-22-2015)
Old 01-20-2015, 01:58 AM   #33
sw20kosh
Originally Posted by moto-mike View Post
I think that datalog (as @blown shows above in reference to kodename's log) starts with temps in the 30 range. So 30c increase is not irrelevant, but for a water to air heat exchanger and many subsequent pulls in a row, it is typical and well within the acceptable range. An air to air intercooler will be better, but you just can't do that with a PD or twin screw setup and keep packaging simple.
And not sure what cosworth published, but you need to look at the delta and not the actual temp. If they managed to keep only a 15C increase with repeated pulls (half of kodename's log) then that I would be quite impressed.
Do you have temp data from a tracked 210 w/ IC?
Old 01-20-2015, 10:07 AM   #34
weederr33
weederr33's Avatar
Thanks for the info. I don't track my car, but I do do plenty of spirited driving on back roads. I'll keep that oil cooler in mind.
Phantom Superchargers VR46 User/Vendor/Sponsor Reviews, Feedback, Comments 5 05-22-2014 09:03 AM
HKS SUPERCHARGERS ON THE SHELF! 3 AVAILABLE SCIONPRO D2BD Motorwerks Forced Induction 7 07-01-2013 01:45 PM
WHERE THE F*** ARE SUPERCHARGERS Billy2224 AUSTRALIA 11 10-04-2012 11:41 AM
Boxer Engines and Superchargers brillo Engine, Exhaust, Transmission 2 01-06-2012 05:49 AM
