#2437 | |
Also, changing oil really frequently (like if you were doing it once a month) carries its own set of risks. Every time you change oil you are changing the specific nature of what is running through the engine. A fresh load of oil is going to be undergoing a set of initial changes, among them is some initial shear and some chemical changes. These variations are not the easiest thing on the motor compared to a steady state healthy oil (not that it is actually that hard on the engine, but still...). Beyond the fact that you are exposing your car to more chances of a loose drain plug or what not, In the end though, you have to decide what is best for you, your car and your wallet. Just be aware that while the manual calls for energy conserving oil, that oil is at the very thin end of the 0w20 spectrum.
Fun car leads to autocross, autocross leads to track days, track days lead to lemons, lemons leads to racing school, racing school leads to spec Miata...
No idea where it leads next! |
#2438 | |
Drives: 2013 Subaru BRZ Limited (WRB)
#2439 | |
Remember that UOAs were designed more for airplane and over the road trucker use than for track days. The standards that they require for those fields is pretty astonishing. A used oil analysis can tell you both if you have problematic wear in your engine AND the health of the oil. It doesn't cover EVERY possible scenario, but it does give you a whole bunch of very useful information.
#2440 |
How is everyone dealing with the trans and diff temps? Anyone using a cooler?
Any experience with something like this? http://www.evasivemotorsports.com/mm...S-TRANSMISSION |
#2441 | ||
TEQSPORT Brand Manager
Drives: '24 GR86 + '16 FR-S
#2442 |
Unfortunately, I overlooked the diff/trans oil and DID NOT change it. I've been tracking on the stock fluid for the 5 track days I've done, plus street miles. I have nearly 30k on the car and I have rear differential whining now, and I can only assume that is the cause. If I can get away with running a more race spec oil and only changing it once a year...that would be fantastic. I read here that others were changing diff/trans fluid every 2-3 or 4-5 track days.
Your thoughts? I'll need to bring the car in for warranty work, I'm guessing. I doubt changing the oil at this point will stop it. edit: There are warnings on that page about using it on the street. My car is still a daily driver at the moment, so I need to consider that. Last edited by Apex_BRZ; 01-19-2015 at 05:10 PM. |
#2443 | ||
![]() Once you change your fluid, the differential whine should decrease. We suggest running Gear 300 LS in the differential if you are tracking. |
#2444 | |
#2445 | |
300V does not shear, period. It's also significantly more than $60 for one oil change. |
#2446 | |
| The Following User Says Thank You to CSG Mike For This Useful Post: | Pat (01-20-2015) |
#2447 | |
If it was a little dirty, I suggest you run a couple days on track or another 5k miles, then change the fluid again. That 2nd change will be pretty good for some time. |
| The Following User Says Thank You to CSG David For This Useful Post: | dp1 (01-20-2015) |
#2448 |
Because compromise ®
Drives: Red Herring
I have these drain plugs fitted to gearbox and diff housing. It was difficult to get the diff plug in because the magnet is so strong it kept on grabbing the housing. They made the oem plugs look so wimpy by comparison.
http://www.drainplugmagnets.com/
| The Following User Says Thank You to Captain Snooze For This Useful Post: | Ultramaroon (01-24-2015) |
#2449 |
Drives: Red Herring
I am toying around with the idea of 16 inch wheels for track days but I'm not sure of the advantage when comparing RPF1 17x8 and TWS T66-F 16x7
Weight RPF1 + Hankook Z214 225x45 16.8 kg ..........T66-F+ Hankook Z214 225x50 14.8 kg The 16 inch tyre diameter is only 2mm smaller than the 17 inch so gearing is so close there is no advantage there. So the benefit is 2 kg of unsprung weight plus an unknown amount of angular momentum but given that the overall diameters are so close and the 16 inch tyre is actually 1 pound heavier I am thinking there wouldn't be much saving there either. The choice of 45 series 16 inch tyres is almost non-existant. Do the T66-F clear the Sprint Kit? Am I missing something here? Ta.
#2450 | |
| The Following User Says Thank You to CSG David For This Useful Post: | Captain Snooze (01-26-2015) |
| Simple question, hard to find answer... | Mango22 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 5 | 05-16-2013 06:23 PM |
| Silly question about protecting track rims | sw20kosh | Tracking / Autocross / HPDE / Drifting | 16 | 04-25-2013 12:34 PM |
| Asking the question that I already know the answer to. Are the engines the same? | Bigmaxy | Engine, Exhaust, Transmission | 10 | 01-19-2013 07:47 PM |
| Random dog-related question for those who have their BRZ | GMU-BRZ | BRZ First-Gen (2012+) — General Topics | 11 | 05-31-2012 07:48 AM |
| Got my answer - BRZ comes with HID headlights as STD | Z_Rocks | BRZ First-Gen (2012+) — General Topics | 20 | 01-10-2012 09:54 AM |
