Old 01-19-2015, 02:20 PM   #1
mid_life_crisis
Drives: FR-S 10 #103 AT
Rear end ratio and ECU changes?
Poking around in the tables and came across this. If this is what it says it is, shouldn't these be changed if the rear end ratio is changed?
I can't get the image to display properly, but it's a table from
Miscellaneous - Thresholds
Gear Determination Thresholds
Gear thresholds Vs Rev/Mile
“Sex is like Bridge. If you don't have a good partner, you'd better have a good hand.” - Mae West
Papa said, "son there's a lot of evil temptations out there. Best to try 'em all so you know which ones to avoid."
mid_life_crisis is offline   Reply With Quote
Old 01-19-2015, 03:16 PM   #2
Toyota John
Calle Atun
Drives: 13 FRS, 93 Mr2, 85 ae86
I think this is true and maybe someone else can back this up. I believe that the speed is taken from the ABS sensors in the wheels so rear gearing changes shouldn't have any effect. How ever tire diameter will.
Toyota John is offline   Reply With Quote
Old 01-19-2015, 04:16 PM   #3
Kodename47
Kodename47's Avatar
Drives: UK GT86
Correct mate
.: Stealth 86 :.
Kodename 47 DJ:
Old 01-19-2015, 06:14 PM   #4
mid_life_crisis
That is true, but I don't think the table is about the speedometer. It has multiple values that pretty clearly tell which gear the transmission should be in depending on the rotational speed of the tires. 65 mph with 4.10 gears could call for a different minimum gear selection than with 4.88, for example. That's why I wonder exactly what the table does and if it should be edited.
Old 01-19-2015, 11:23 PM   #5
Toyota John
Calle Atun
I think that is related to Auto Trans?
Old 01-20-2015, 04:52 AM   #6
steve99
Drives: FT86
I believe that table is to calculate what gear number to display in the dash
if you need to adjust speedo error i believe that can be done with techstream software its got a limited range for speedo correction. you can get the software for free but you will need an J2534 adapter to talk to obd port, unless you have a tactrix cable or ecutek cable .
you can get the elcheapo j2534 adapters for techstream software on ebay, just search for techstream.
dont buy the imitation clone tactrix adapters from china, they are rubbish and likely to brick your ecu buy the real one from e tactrix site www.tactrix.com if you want a tactrix adapter.
Old 01-20-2015, 08:31 AM   #7
makinen
makinen's Avatar
Drives: Toyota 86
Hi,
Gear Determination Thresholds is basically related to the gear indicator in your cluster.
With modified final gear ratio, you'll see unmatched gear number in your cluster. To say, 1-2-3-3-4-5 rather than 1-2-3-4-5-6.
makinen is offline   Reply With Quote
Old 01-20-2015, 10:41 AM   #8
wootwoot
Drives: FRS
I would LOVE it if we could find a solution for this..... As would everyone with an upgraded final drive.
Old 01-20-2015, 04:03 PM   #9
Toyota John
Calle Atun
Which problem are your talking about? The auto trans showing the wrong gear with a different final drive?
Old 01-20-2015, 04:44 PM   #10
PantsDants
Drives: Scion FR-S A/T, Whiteout
The only thing this table controls is the gear display on the dash for manual cars. It doesn't have any impact on gear readout on automatic cars.
You can adjust the table by multiplying all of its cells by the percent change you induced by changing your final drive. Ex: If you went to 4.88 from stock 4.1, you increased the ratio by 19%. Another way of saying that is you're at 119% of stock. So take that percentage (1.19) and multiply it against the table. Your gears should read correctly now.
PantsDants is offline   Reply With Quote
Old 01-21-2015, 07:15 AM   #11
mid_life_crisis
It doesn't make sense to me for that table to be for gear display. At pretty much any speed (leaving out extreme high or low) there are multiple gears you could be in for that speed. This table can't account for that by itself.
Old 01-21-2015, 10:32 AM   #12
shif7i7down
Erected Member
Drives: frs
@makinen is correct, with the mfactory 4.67 final drive I get 1,2,3,3,4,5 on the display
shif7i7down is offline   Reply With Quote
Old 01-21-2015, 02:14 PM   #13
PantsDants
The ECU also knows what your current RPM and speed are. It uses that table as part of the calculation to determine the current gear, not just by itself.
Shorter spring with FRS front rear rate ratio? Mars2 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 1 05-28-2013 08:15 AM
Rear End/Gear/Differential Ratio fly2low Engine, Exhaust, Transmission 9 02-09-2013 11:53 AM
Rear End Ratio White64Goat Engine, Exhaust, Transmission 6 07-07-2012 11:37 PM
FR-S to BRZ Ratio MannyO New England 11 03-08-2012 02:23 AM
86,BRZ MT gear ratio Yobiwan Engine, Exhaust, Transmission 1 01-26-2012 02:40 AM
