Old 01-15-2015, 05:26 PM   #2885
grostoine
Drives: Subaru BRZ
Originally Posted by ExquisiteStance View Post
So with the Front LCA I should be able to add camber without risking the bag rubbing? So I can't use the airlift camber plates at all? I don't mind the camber I actually want to run some in the front. What wheels are they? And why do you say that? Is he a member on the forum? Or IG?
Got pictures of your setup?
I don't hve my wheels yet but from what i measured last summer with some other wheels, 18x9 et35 wheels with 225/40/18 should fit without camber and safe without rubbing.
You can adjust the top plate but you won't get many camber, ithe bag is already very close to the inside of the shock tower. The best you can do is compress the shock to the max and push the bag as close as you can to the shock tower and let 0.5mm between the bag and the shock tower. That's going to be your max camber.
Theese wheels are WatercooledIND wheels and are very bad quality for 4500$ wheels. Polish full of swirl, the lip was cracked nest to a bolt, spec were not as ordered, etc... Doesn't worth the price. He is a member on this forum but do not come during winter...
grostoine is offline   Reply With Quote
Old 01-15-2015, 06:00 PM   #2886
ExquisiteStance
ExquisiteStance's Avatar
Drives: Brz Series Blue
Originally Posted by PradiG View Post
im a cheater, im parked on a slight incline
Are you on bagged ?
ExquisiteStance is offline   Reply With Quote
Old 01-15-2015, 06:08 PM   #2887
ExquisiteStance
What do you mean by compress the shock? I still want to lower the front more. So I'm thinking I'll add the safest amount of camber from the plates and the rest from the LCA.
And just to clarify the Front LCA would add camber on the hub and should affect the bag rubbing?
Old 01-15-2015, 06:18 PM   #2888
PradiG
Drives: Fr-s
Are you on bagged ?
yes
PradiG is offline   Reply With Quote
The Following User Says Thank You to PradiG For This Useful Post:
ExquisiteStance (01-15-2015)
Old 01-15-2015, 06:26 PM   #2889
ExquisiteStance
yes
There is hope! Lol airlift struts? That's what I'm hoping to accomplish. Mind sharing your set up? I'm trying to run 18x9.5 in the front.
Old 01-16-2015, 07:26 PM   #2890
grostoine
Drives: Subaru BRZ
yes. With the lca you will be able to put a lot of camber in front without minding about the bag rubing in the shock tower... but with 9.5 you will have to think about the fender then :P
Old 01-16-2015, 11:01 PM   #2891
mike_frs
mike_frs's Avatar
Drives: 2015 Subaru BRZ Limited
Looks good man
mike_frs is offline   Reply With Quote
The Following User Says Thank You to mike_frs For This Useful Post:
PradiG (01-17-2015)
Old 01-17-2015, 09:56 PM   #2892
ExquisiteStance
But then if I do camber a lot I still have to worry about the wheel rubbing on the bag still no? Lol damn bags 😒. I'll try my best to fit them if not I got a back up plan 😋
Old 01-18-2015, 03:03 PM   #2893
grostoine
Drives: Subaru BRZ
That's another problem we have to face with bags... That's why custom wheels are no brainer if you want a nice setup...
Old 01-19-2015, 12:46 PM   #2894
Brndn704
Brndn704's Avatar
Looks good man. I love the front lip.
Brndn704 is offline   Reply With Quote
Old 01-19-2015, 03:50 PM   #2895
bwag
Drives: 2014 Whiteout FR-S
Can I play now... My semi aggressive setup.
bwag is offline   Reply With Quote
The Following User Says Thank You to bwag For This Useful Post:
slava (01-26-2015)
Old 01-19-2015, 03:55 PM   #2896
adamg
Drives: brz
lets go cruise!
adamg is offline   Reply With Quote
Old 01-19-2015, 05:08 PM   #2897
bwag
Originally Posted by adamg View Post
lets go cruise!
hit me up whenever man!
Old 01-20-2015, 07:13 PM   #2898
cfig21
cfig21's Avatar
Drives: SWP BRZ Ltd , 96 240sx Built KA-T
Anyone running the tomei 80r on a slammed frs/brz? My MXP exhaust got destroyed due to some crappy road work so i need to replace it with something that isnt as low hanging.
Check out my Build Thread:
Emma's build
Instagram: @cfig21
cfig21 is offline   Reply With Quote
dontlike?dontlookmoveon
Post the Wheels You want On your FRS/BRZ!! Zaku Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1738 10-11-2017 04:29 PM
RPF1 and PF01 aggressive fitment size requests Crossover Auto Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 12 10-22-2012 02:30 PM
post VIN with any problem thread? fistpoint Issues | Warranty | Recalls / TSB 0 10-04-2012 10:11 PM
Do aggressive offsets cause more debris to kick up into the paint? switchlanez Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 7 09-26-2012 10:03 PM
Scion FR-S / Toyota FT-86 / Subaru with Aggressive Body & High Wing! + VIDEO! Hachiroku Scion FR-S / Toyota 86 GT86 General Forum 538 06-15-2011 02:20 AM
