Old 06-06-2013, 09:44 AM   #99
Jeff86
Jeff86's Avatar
Drives: 86 (FR-S)
Thanks for the writeup @Synack, made my airbag swap easy as pie
Jeff86 is offline   Reply With Quote
Old 07-07-2013, 03:42 PM   #100
CamryDS
Drives: 2003 Camry Blue | 2013 FR-S White
I just did this about an hour ago -- it's a cinch (I did this to install a new stalk for my fog lights)
Here are some pitfalls -- This is just a summary of what I read here and my experience - for pictures reference OP's pictures
1 - When you are attempting to take out the air bag, be extra careful not to snap anything (as far as plastics go).
2 - Forget the fuse, easier to disconnect the battery (the white fuse for the horn is the worse to take out and I gave up after screwing up my index finger (I don't have the tool to remove fuses).
2a. - If you are going to go with the route and remove the fuse, DON'T, it'll be a pain.
Here are the fuses you need to take out INCLUDING the 3 with the horns) -- FUSE 47, and 35 (look it up on the owner's manual). SRS air bag system is 47 , SRS Air Bag system and Ignition is 35 -- Do not attempt to do this without removing those two at the very least (again, I'd just take the time to reprogram everything and just remove the Negative from the battery.
3 - There are only 3 holes near the steering wheel: Left, Right, Underneath. Before you begin poking the holes to release the air bag, I find it easier to lower the steering wheel all the way down and pull the wheel all the way out so you have room to look at the holes. When you begin, make sure that you press straight in, do not poke it like you're jamming something in hard, but moderate pressure is needed. Position of the screw driver should be horizontal (0 or 180 degrees; position: -- ). (The bottom hole, your screw driver should be at 90 degrees when pushing up; position | ) Also the pin underneath is easily pushed above the bracket. Make sure that you don't push too hard where the metal pin gets thrown out of it's place, difficult to get back in.
3a. - Do not pry the airbag open, each side when you push the pin, the airbag will pop out of place and not fall back in unless you push it -- Do not fret about it. It WILL not fall back in, unless you push against the airbag. The airbag will not fall off of the steering wheel either, so don't worry about that.
4 -Once the air bag is pulled out (slowly and carefully I might add), I suggest using a flat head screwdriver that is for precision devices, wrap it with some painters tape and try to wiggle it between the orange and yellow tab. Once the tabs are popped pull the connector straight up and out, do not bend the pins!
5 - On the airbag itself there's a blue wire with a spade. The spade has a notch on it, do not just pull it out, press on the notch to release the lock and then pull out -- you can risk ripping the wire apart since it's so flimsy
6 - once the airbag is detached you're good to go to do either the stalk install or whatever mod you need.
If anyone is in the bay area that wants to get this done, Hit me up -- I'll help guide you through this. EASY PEASY!
CamryDS is offline   Reply With Quote
Old 07-22-2013, 07:23 PM   #101
07jazzrs5gt86
Drives: Firestorm 86
What's the size measurements of the steering wheel emblem?
07jazzrs5gt86 is offline   Reply With Quote
Old 08-14-2013, 10:58 PM   #102
BuBlake
Chronic Flashturbator
BuBlake's Avatar
Drives: '13 Scion FR-S MT
I got roughly 2 3/8 by 1 7/8 inch if I remember correctly. I'm going crazy looking for a emblem that fits the steering wheel right now.
OFT Stg 2 UEL E85 - Borla UEL Header - Invidia Q300 - Invidia catless frontpipe - Fa20club CAI - Billet Power Blocks - Michelin PSS 245/35/18 all around on Motegi Racing SP10 18x8 +38 - Eibach Sportline springs - SPC LCA
BuBlake is offline   Reply With Quote
Old 08-14-2013, 11:10 PM   #103
BuBlake
BuBlake's Avatar
These seem to be the right size. I went ahead and ordered one. The description says the seller has a box of them and they're used with light scratches. I figure that if mine isn't acceptable, I'll just plasti-dip it.
http://www.ebay.com/itm/Toyota-OEM-E...15863a&vxp=mtr
Old 08-16-2013, 04:10 PM   #104
MmmDieselFumes
MmmDieselFumes's Avatar
Drives: .
Awesome, thanks for the link. Let us know if it fits perfectly, without having to do any trimming to the airbag cover material to make it fit.
MmmDieselFumes is offline   Reply With Quote
Old 08-19-2013, 07:11 PM   #105
BuBlake
BuBlake's Avatar
I got lucky and mine was perfect, like new. I sanded down the grooves where the old Scion logo used to go, then cut out a piece of red cardboard that was laminated and glued it to the back of the emblem. Glued it in place(using a hot glue gun, so it's reversable) and I think it looks pretty professional if I must say so myself. I think I might go for a little darker red if anything.
The emblem is maybe a fraction of an inch bigger, but it's hard to tell. I trashed the stock emblem upon removal and threw it away, so couldn't compare.
The Following 2 Users Say Thank You to BuBlake For This Useful Post:
FRSapex (10-06-2013), MmmDieselFumes (08-20-2013)
Old 08-20-2013, 12:49 PM   #106
MmmDieselFumes
Drives: .
That looks great! Killer job bud. Where'd you find the red laminated cardboard? Think we can get another shot of it dead on from the driver's seat?
Old 08-24-2013, 04:15 PM   #107
mrbbs
Drives: GT86
Is there any way to have a adapter hub installed while retaining the original steering wheel and thus airbag, so the steering wheel can be pulled closer to the driver?
mrbbs is offline   Reply With Quote
Old 08-24-2013, 04:22 PM   #108
Khazzy
Khazzy's Avatar
Drives: SWP Subaru BRZ
I want to see an Alcantara air bag cover stitched where it is on the 86 air bag in red stitching. I think it would look wonderful. Then obviously some sort of emblem in the center of that. Hmmm maybe I will have a project one day.
2013 SWP BRZ full STi Lip kit installed. Tons of other mods from interior to exterior. One of the cleanest BRZ's around in the midwest! Enjoy the build thread below.
Full of pictures, exhaust clips, garage shots, and walk around video encasing its beauty.
Old 04-02-2014, 04:44 PM   #109
Baramzisyan
turbo turtle
Baramzisyan's Avatar
Drives: exit GT86 enter STI
hello! and how to change scion logo airbag cover to subaru logo airbag cover
Baramzisyan is offline   Reply With Quote
Old 06-20-2014, 10:41 AM   #110
Frishkorn
Hi everybody!
Frishkorn's Avatar
Drives: 14 Whiteout FRS 6M. 16 Abyss iA 6A.
Originally Posted by titusdrake View Post
Im definitely behind the 8 ball on this one... Why are we spending hundreds of dollars to replace working airbags??
Sent from my DROID RAZR
Because people like us HATE the Scion marque. Anyone done the JDM Replica Winjet headlight swap?
Frishkorn is offline   Reply With Quote
Old 01-18-2015, 02:09 PM   #111
zeal86
zeal86's Avatar
Drives:
Originally Posted by Synack View Post
First you'll need to go the side of the steering wheel, there are 4 holes on each side but it's the bottom 2 you should be working on. There is a metal pin if you look inside the holes. You need to grab a screwdriver or something similar and push that pin inwards of the steering wheel, while simultaneously pulling the airbag. Do this to each pin on both sides and pull the airbag out, it is semi-difficult. Gave me a bit of trouble.
Giving me some trouble as well... before I get too frustrated I thought I would ask somebody who has done it.
Ok...so I pushed in the side clips and released the airbag assembly from the top and sides...the bottom is difficult to dislodge. How hard did you pull to remove the airbag? Any tips or tricks on how to do this without breaking something?
thanks in advance
2014 6-speed Monogram (37J)
zeal86 is offline   Reply With Quote
Old 01-18-2015, 02:14 PM   #112
zeal86
zeal86's Avatar
Drives:
Resolved.
steering wheel controls inimitable BRZ First-Gen (2012+) — General Topics 79 09-05-2016 12:56 AM
Anyone tried debadging the steering wheel? Synack Cosmetic Modification (Interior/Exterior/Lighting) 60 07-22-2013 07:18 PM
do you want steering wheel buttons? Spaceywilly BRZ First-Gen (2012+) — General Topics 125 04-09-2012 08:46 AM
That steering wheel poormans_LFA Scion FR-S / Toyota 86 GT86 General Forum 26 12-04-2011 12:16 AM
FT-86 concept's steering wheel Dark Scion FR-S / Toyota 86 GT86 General Forum 35 08-07-2010 06:17 AM
