Old 01-17-2015, 06:25 PM   #1
ChrisD
ChrisD's Avatar
Drives: GT86
Coilovers for GT86
I've just bought a GT86, which I'm going to be using on the road but also for track days and drift events. So the first thing I want to do is get some decent coilovers on it.
I'm in the UK and I've found that Fensport sell the BC ER coilovers: http://www.fensport.co.uk/Parts/Mode...ategory_2/4195
Now I don't know much about coilovers so all I can go on at the moment is other people's reviews, and I did find a couple of negative reviews about BC coilovers on the GT86. Seems like they are regarded as not quite being up to the same standards as KW and H&R etc. So I started looking at KW Variant 3 coilovers, as I think quite a few people on here run those (correct me if I'm wrong), but it looks like they don't come with top mounts for some reason: http://www.demon-tweeks.co.uk/perfor...m-rear-20-50mm
Anyone in the UK actually bought KW V3s and if so where did you buy them from and what do you think of them?
Also anyone got any comments about the BC coilovers - am I right that they are not held in particularly high regard? One person (can't remember if it was on here or somewhere else) said that they made the steering feel quite vague but to be fair that was the lower spec BR series rather than ER series that I'm considering.
Thanks
Chris
ChrisD is offline   Reply With Quote
Old 01-17-2015, 07:26 PM   #2
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
It would help if you gave a budget.
If you want quality you are going to have to pay for it.
Old 01-17-2015, 07:33 PM   #3
Cvxne
Cvxne's Avatar
Drives: 2013 Whiteout FRS
ST and some rear lower control arms and call it a day.
Cvxne is offline   Reply With Quote
Old 01-17-2015, 07:38 PM   #4
ChrisD
ChrisD's Avatar
Drives: GT86
This
contradicts this
You can find positive and negative reviews for just about anything. The more you pay for dampers the fewer bad reviews you read.
Remember that people who review coilovers may not have the experience to give a wide perspective. Just because a person likes their new and shiny coilovers doesn't necessarily mean they are a quality product.
I feel like you didn't actually read the post... as I was saying pretty much exactly what you said. I said it looks like the BC coilovers are not that great and also mentioned that I had seen bad reviews of the BC ones. At no point did I mention anyone leaving a glowing review on them.
I said I think a lot of people run KW V3s and asked if anyone here had bought them in the UK. Are you saying the KW V3s are also not decent quality?
Old 01-17-2015, 07:39 PM   #5
ChrisD
ChrisD's Avatar
Drives: GT86
Forgive my ignorance but what is ST ?
Old 01-17-2015, 07:54 PM   #6
Mad1723
Mad1723's Avatar
Drives: Asphalt FR-S
ST Suspensions, a subsidiary of KW. Their 1K$ coilovers are the reference for cheap and good coilovers
Mad1723 is offline   Reply With Quote
The Following User Says Thank You to Mad1723 For This Useful Post:
hmong337 (01-17-2015)
Old 01-17-2015, 08:44 PM   #7
Captain Snooze
Drives: Red Herring
I read your post. As you can see I removed a lot of what I originally said.
When I said "If you want quality you are going to have to pay for it." I was referring to the fact that you mention BC and KWv3 in the same post.
From what I have read of KWv3 by people whose opinion I respect is that KWv3 are good value/performance for the money.
Seriously, I have read good things about BC dampers. Given that very few people actually get to test more than one set of aftermarket dampers for their car it makes objective reviews difficult to find. It took me about 30 seconds to find 3 positive reviews for BC coilovers. I am suggesting that the people making those reviews don't have the experience to make objective analysis of their new dampers.
Old 01-17-2015, 09:17 PM   #8
Mad1723
Mad1723's Avatar
Also, buyer's bias is going to show. No one wants to bash the stuff they bought. That would be admitting they made the wrong choice.
Most people are going to stick to what they bought until it fails, has major problems or the company screws them over.
The Following 3 Users Say Thank You to Mad1723 For This Useful Post:
-Tom- (01-18-2015), Captain Snooze (01-17-2015), CSG Mike (01-17-2015)
Old 01-17-2015, 09:49 PM   #9
CSG Mike
CSG Mike's Avatar
Thanks
Chris
KW V3 re-uses your stock top mounts, as they really fall into the "comfortable high performance street" coilover category. If you want top mounts, you have to buy your own (like RaceSeng), or get the ClubSport (which includes them).
Old 01-18-2015, 09:11 AM   #10
ChrisD
ChrisD's Avatar
Drives: GT86
Ahhh ok thanks, in that case then I guess I'll be fine just ordering the KW V3s
Old 01-18-2015, 03:51 PM   #11
KoolBRZ
KoolBRZ's Avatar
Drives: Silver 2013 BRZ Ltd Auto 45,000 mi
Thanks
Chris
Look at the spring rates as well when shopping for a coilover. For instance, when you take into account the motion ratio of the rear control arms, the rear springs actually have only 75% of their rated capacity. From the Fensport page, "8kg/mm front and 6kg/mm rear" becomes 8kg/mm front and 4.5kg/mm rear.
This would give a very uncomfortable ride on the street, since every bump rocks the car back on the softer rear springs. I've found a better ride when the rear springs are at least 27% stronger than the fronts. Also remember that your stock springs are about 2.754kg/mm front and 3.774kg/mm rear, so these are much stiffer than stock.
KoolBRZ is offline   Reply With Quote
Old 01-18-2015, 04:27 PM   #12
Captain Snooze
Drives: Red Herring
Originally Posted by KoolBRZ View Post
Look at the spring rates as well when shopping for a coilover. For instance, when you take into account the motion ratio of the rear control arms, the rear springs actually have only 75% of their rated capacity. From the Fensport page, "8kg/mm front and 6kg/mm rear" becomes 8kg/mm front and 4.5kg/mm rear [1].
This would give a very uncomfortable ride on the street, since every bump rocks the car back on the softer rear springs. [2] I've found a better ride [3] when the rear springs are at least 27% stronger than the fronts[4]. Also remember that your stock springs are about 2.754kg/mm front and 3.774kg/mm rear, so these are much stiffer than stock[5].
[1] The motion ratio of Mac struts is not 1:1. It's usually around 0.9-0.95
More importantly the wheel spring rate is given by spring rate x motion ratio squared. So in the example of 6kg/mm spring it becomes 3.375 kg/mm not 4.5kg/mm.
[2] You are making a general statement which ignores the quality of damping. Damping plays a more important factor in "comfort" than the spring rate.
[3] You have found shit.
[4] This totally disregards a person's preference for steering style. Whether they prefer more understeery, neutral or oversteery.
[5] Huh? "Your stock springs.......these are much stiffer than stock"
The Following 3 Users Say Thank You to Captain Snooze For This Useful Post:
CSG Mike (01-18-2015), J95 (08-30-2023), Mad1723 (01-18-2015)
Old 01-18-2015, 04:56 PM   #13
KoolBRZ
KoolBRZ's Avatar
Insults are the refuge of a feeble mind. If you think I'm wrong then prove it with some facts and cite your sources, otherwise you're just vomiting up your own opinions. Of course if all you have is a feeble mind, let the flames begin.
Old 01-18-2015, 06:27 PM   #14
ChrisD
ChrisD's Avatar
Drives: GT86
Well I'm going to go ahead and get the KW V3s, if you guys want to turn this in to an argument be my guest but I won't be reading it any more. Enjoy
The Following 2 Users Say Thank You to ChrisD For This Useful Post:
CSG Mike (01-18-2015), Mad1723 (01-26-2015)
Beatrush Mounts ,BC BR, Bilstein, ISC N1, ST Coils, KW Coils and Stance Coilovers b2autodesigns Brakes, Suspension, Chassis 818 09-10-2017 08:33 AM
Coilovers Coilovers, Coilovers: Tein, KW, BC, D2, Cusco, Eibach + more FREE SHIPPING! No Limit Motorsport Brakes, Suspension, Chassis 204 05-26-2017 12:09 PM
* BC Racing BR Coilovers & Stance Super Sport Coilovers | IN STOCK | FAST SHIPPING * Speed Element Brakes, Suspension, Chassis 21 03-03-2014 08:56 PM
PTUNING FRS/BRZ/GT86 Ohlins Coilovers NOW AVAILABLE w/Free Shipping! Ken@PTuning Brakes, Suspension, Chassis 13 10-21-2013 11:12 AM
