#435 | |
U.S. forum members can send us a PM for the free-shipping code once the module is available on the site. Like Paul said previously, we will have plenty! So no need to worry about them going out of stock Nick C.
#436 |
Drives: 2013 GB BRZ
So excited! Thanks Diode Dynamics!
#437 |
#438 | |
Drives: White Aozora BRZ
| The Following User Says Thank You to chamourian For This Useful Post: | FLYFISHR (01-15-2015) |
#439 |
Since we just have to keep teasing you guys...
Here's the design for the PCB we are waiting on. This is what controls the whole thing. Soon as these boards arrive we'll get them assembled and start shipping! We've had everything else for quite a while now. (note dual function switches and trimpot for adjustable DRL brightness )
#440 |
Drives: '13 DGM BRZ Limited/'14 Yamaha R6
Nice! Is that for the brightness of the normal DRLs, the boomerangs, or both together? I'd love to be able to make the boomerangs a brighter (the DRL's are bright enough).
#441 |
We can't make anything brighter, as running things at high power than they're intended would be bad for the factory LED component. We've designed this module to be completely safe and protected from the factory electrical system. Also, you'd need to open the headlight and replace the LEDs to make things brighter. This is much more simple than that.
This module has two functions. Both are switched so you can do one or the other or both, whatever you'd like. 1. Allows you turn the boomerang into a DRL. 2. Allows you to keep the DRL on with the headlights. They will still be full brightness with normal DRL, but you can adjust the brightness of them when they are on with headlights, from 10-100% brightness. Basically, with the PWM dimmer function, you can make it so the DRLs dim when you turn on the headlights, like many OEM DRL setups. You can keep it at full brightness if you'd like too.
#442 |
PandaPandaPandaPandaPanda
Drives: 2015 BRZ Limited CWP
I'm guessing the yellow screw thing is the potentiometer for the PWM function?
#443 |
Drives: Subaru Brz
can i buy them yet?
#445 |
Run Away!
Drives: 2015 Subaru BRZ Limited
Not sure if this was answered previously, couldn't find it via search.
Where would this module be installed? |
#446 |
Drives: point A to point C. Screw point B!
#447 | ||
Run Away!
#448 |
Just a quick update,
I've painstakingly rifled through the entire thread so we will have an initial estimate on the number of modules to assemble so everyone can have it shipped quickly. We sincerely appreciate everyone's patience, and of course @Lithium for conceiving this great idea! Nick C.
| [Closed] Gauging Interest thread | pansontw | Cosmetic Modification (Interior/Exterior/Lighting) | 49 | 08-27-2014 03:14 PM |
| So has anyone managed to get the BRZ Boomerang/parking lights to operate as DRLs? | gt8613 | BRZ First-Gen (2012+) — General Topics | 18 | 04-27-2014 02:09 AM |
| Gauging Interest | ISC Suspension | Announcements, Contests, Giveaways | 17 | 04-03-2014 09:44 AM |
| Jdm headlights - gauging interest | Hawk77FT | Exterior Parts (Aero, Lighting, Etc.) | 7 | 03-31-2014 09:38 AM |
| FS: Oil Pressure gauge (includes Block galley plug for free!) True plug and play! | Sportsguy83 | Engine, Exhaust, Bolt-Ons | 10 | 08-30-2013 10:53 AM |
