Old 01-15-2015, 09:17 PM   #1
dad&sonFRS
Drives: Firestorm FR-S
Winjet tail light problems
So I noticed a month ago that my right tail light had condensation. I was hoping as the weather got better the problem would go away. But I've noticed the condensation still has not went away. But what makes it even worse is that I think the water killed the lights now a portion of my right tail light doesnt work. Anyone know of a way to fix the condensation and the lighting?
dad&sonFRS is offline   Reply With Quote
Old 01-15-2015, 09:32 PM   #2
swarb
1. take apart.
2. buy new ones.
your choice.
The Following User Says Thank You to swarb For This Useful Post:
dad&sonFRS (01-16-2015)
Old 01-16-2015, 08:07 AM   #3
BlackMonarch
Drives: Red BRZ
I'd bake them, take them apart, clean the connectors, but I don't know if there's a way to replace those CFL's in there...
BlackMonarch is offline   Reply With Quote
The Following User Says Thank You to BlackMonarch For This Useful Post:
Old 01-16-2015, 01:51 PM   #4
Tenament05
Drives: fast
The best advice is already given, so I'll furnish some tangential advice..
hoping electrical problems go away is a thing of the past.. If something is not working correctly, with today's tolerances and operations, then much more often than naught the problem will not correct itself if ignored. I recently had a grounding problem with my Tom's tails and switchbacks that caused my right turn signal to stay lit whenever the car was on. Frustrating, and no amount of time fixed it.. turning the polarity around on the right switchback fixed it, though.
Condensation is never good for electronics, no amount of waiting it out will help it. Waiting it out only helps for devices that have been exposed to moisture but NO current going through it. Otherwise you're frying the circuits
Tenament05 is offline   Reply With Quote
The Following User Says Thank You to Tenament05 For This Useful Post:
Spyder tail light problems John92 Cosmetic Modification (Interior/Exterior/Lighting) 10 05-01-2017 11:09 AM
**PHASTEK** Winjet JDM Replica Headlight and Tail Light Thread PhastekSport Exterior Parts - Lighting 62 04-22-2015 05:15 AM
Winjet BRZ/FRS Red Lens Tail Lights Mpowered Exterior Parts (Aero, Lighting, Etc.) 5 11-01-2014 09:22 PM
FS: Winjet Tail lights Black Clear randel_07 Exterior Parts (Aero, Lighting, Etc.) 10 09-09-2014 10:38 AM
Red Tail Problems FRS_Sovereign Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 5 08-05-2013 06:26 PM
