Old 01-15-2015, 02:10 PM   #15
Cards2323
Drives: 2014 BRZ Limited-SWP
Originally Posted by sw20kosh View Post
Don't get sprintex. That blower and intercooler are too small.
I'm not looking for huge numbers, I would be perfectly happy with 250whp amd the early tq it produces. I really dont plan on doing many bolt ons either so I dont see the need to go with say a rotex kit...
Cards2323 is offline   Reply With Quote
Old 01-15-2015, 04:59 PM   #16
sw20kosh
Drives: 2013 Black FR-S
Even still, I would not get the sprintex.
Old 01-15-2015, 05:43 PM   #17
blown
Drives: ft86
please elaborate on the intercooler comment.
blown is offline   Reply With Quote
Old 01-15-2015, 06:33 PM   #18
weederr33
Airborne at your service
weederr33's Avatar
Drives: '17 BRZ Series.Yellow
Go big and get the most overpriced SC on the market!
Old 01-15-2015, 07:01 PM   #19
FirestormFRS
The Sprintex is actually just about right for a stock internal FA20. Bigger isn't always better.
FirestormFRS is offline   Reply With Quote
Old 01-15-2015, 07:16 PM   #20
Sellout
Mr. Cranky Pants
Sellout's Avatar
Drives: 2013 Argento FR-S
Just about right for an absolute max of 300ish whp on E85 or 300ish crank hp on gasoline, imo. If you want much (any?) more you need a larger unit. And a larger intercooler.
Sellout is offline   Reply With Quote
Old 01-15-2015, 07:46 PM   #21
tahdizzle
So elite I'm 1338
Drives: WRB Subaru BRZ
Just gives me more time to stack paper
-Jack Burton
Old 01-16-2015, 08:13 AM   #22
Xero-Limit
Xero-Limit's Avatar
Drives: JDL Turbo FRS, 335SC BRZ (ret)
300 whp when dealing with PD/Twin Screw blowers is nothing to sneeze at. It feels like more than that up until 6500 RPM where the peakier systems show better numbers. But to have the torque down low is awesome for a street setup.
I keep seeing the intercooler being questioned in regards to size...it isn't undersized. It is small, yes--compared to a bar/plate and tube/fin setup. But it is a laminova core that uses a much, much higher density of fins. This allows the compact fitment and yet support 400ish HP.
There is a distinct advantage to having a smaller package here. The throttled volume is much lower. The cosworth setup will no doubt make great power, but the volume that the intercoolers take up appears to be very significant. The more volume, the slower the throttle response. I can't say whether it is something that you will definitely feel on this car as I haven't driven it, but there's definitely advantages to the smaller core. A larger heat exchanger in the front or a higher volume pump may help make the most of the smaller core.
Xero-Limit is offline   Reply With Quote
The Following User Says Thank You to Xero-Limit For This Useful Post:
Old 01-16-2015, 08:31 AM   #23
Sellout
Mr. Cranky Pants
Sellout's Avatar
Oh I agree with that. I have been in one of the local cars that makes 300ish whp on e85. It's quick enough to be fun for sure, and could be trouble for someone who can't handle it. I see it as the way the car should have been from the factory and anything less is just not enough.
I think that traces back to some comments by one of the tuners about how difficult it is to counter knock with the sprintex kit compared to the centrifugals. Could be that they were really up against the same combustion chamber pressures with both kits and trying to make up a difference in power but the real difference was the extra juice that it takes to turn the twin screw. I'll admit that I've just been keeping with the rest of the herd on that line of thought about the intercooler, we could all be way off base.
I tend to look at the discussion about throttle response as it relates to extra space IN THE PLENUM as snake oil. Especially when we're talking about an intake manifold we haven't measured. We can't know that there's even an issue to discuss on that front yet.
Old 01-16-2015, 09:10 AM   #24
350matt
Drives: toyota mr2/ Toyota GT86
The main issue of the Sprintex IC is that the IAT's post cooler are up in the 60°C mark which is really hot - the Cosworth setup has published IAT's of less than 1/2 that...
350matt is offline   Reply With Quote
Old 01-16-2015, 11:16 AM   #25
blown
Drives: ft86
http://www.ft86club.com/forums/showt...t=48698&page=2
Old 01-16-2015, 12:40 PM   #26
Xero-Limit
Xero-Limit's Avatar
I think that datalog (as @blown shows above in reference to kodename's log) starts with temps in the 30 range. So 30c increase is not irrelevant, but for a water to air heat exchanger and many subsequent pulls in a row, it is typical and well within the acceptable range. An air to air intercooler will be better, but you just can't do that with a PD or twin screw setup and keep packaging simple.
And not sure what cosworth published, but you need to look at the delta and not the actual temp. If they managed to keep only a 15C increase with repeated pulls (half of kodename's log) then that I would be quite impressed.
Old 01-16-2015, 03:37 PM   #27
350matt
this is what Cosworth published
Old 01-16-2015, 09:14 PM   #28
Xero-Limit
Xero-Limit's Avatar
I don't think you can compare an in house test without the measurement methods outlined, to a real life test with multiple back to back runs. This one shows about a 10c increase in temp, but we don't know the boost, road vs dyno with massive fans, or a quick 1st gear pull on a cold motor vs a 4th gear pull.
Phantom Superchargers VR46 User/Vendor/Sponsor Reviews, Feedback, Comments 5 05-22-2014 09:03 AM
HKS SUPERCHARGERS ON THE SHELF! 3 AVAILABLE SCIONPRO D2BD Motorwerks Forced Induction 7 07-01-2013 01:45 PM
WHERE THE F*** ARE SUPERCHARGERS Billy2224 AUSTRALIA 11 10-04-2012 11:41 AM
Boxer Engines and Superchargers brillo Engine, Exhaust, Transmission 2 01-06-2012 05:49 AM
