Old 01-14-2015, 09:10 PM   #1
Andreas83
Andreas83's Avatar
Drives: 2013 Subaru BRZ
PCV fitting threads
Does anyone know what type/size threads the PCV fitting in the block has?
Andreas83 is offline   Reply With Quote
Old 01-15-2015, 02:00 PM   #2
Jeff@Racer X Fab
Drives: Subaru BRZ, Toyota MR2 Turbo
Fitting appears to be 3/8 BSPT, it is very close to a 3/8 NPT but the thread count is 1 tooth off between the 2 fitting sizes.
The PCV does have a check valve inside of it.
Jeff@Racer X Fab is offline   Reply With Quote
The Following User Says Thank You to Jeff@Racer X Fab For This Useful Post:
Andreas83 (01-16-2015)
Old 01-16-2015, 01:33 PM   #3
Andreas83
Andreas83's Avatar
Thanks for the info.
I know about the check valve.
I am installing a boomba 1/2" check valve between my radium catch can and the intake manifold.
Want to clean up the rest with a 1/2" hose from the catch can to a AN flittig in the block.
JDM exhaust fitting westonben Engine, Exhaust, Transmission 5 06-04-2014 03:00 PM
fitting a brz lip onto a frs? Grip Ronin Cosmetic Modification (Interior/Exterior/Lighting) 11 02-13-2014 09:01 PM
fitting 17x9's with 255s, and fitting brake pads Matt Andrews Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 06-29-2012 12:08 PM
Anyone worried about not fitting in the car? budakajana AUSTRALIA 35 06-27-2012 08:55 AM
