go_a_way1
Old 01-14-2015, 10:49 PM   #2871
ExquisiteStance
ExquisiteStance's Avatar
Drives: Brz Series Blue
Ok so nobody running air ? This is what I'm trying to fit.
ExquisiteStance is offline   Reply With Quote
Old 01-14-2015, 10:54 PM   #2872
lukey86
Built Not Bought
lukey86's Avatar
Drives: 2012 Toyota 86 ZN6
Could've sworn there was someone here running air. Just can't remember which thread I saw it in.
lukey86 is offline   Reply With Quote
The Following User Says Thank You to lukey86 For This Useful Post:
ExquisiteStance (01-14-2015)
Old 01-14-2015, 11:12 PM   #2873
ExquisiteStance
@lukey86 yea I'm sure I'm not the only one just need some advice on the front wheels really.
Old 01-14-2015, 11:14 PM   #2874
lukey86
Built Not Bought
lukey86's Avatar
mmmm yeah seems you need some camber there lol
Old 01-14-2015, 11:22 PM   #2875
AznKirby
Are you 20/20?
AznKirby's Avatar
Drives: Hopes and dreams
There's a few guys running air.
This guy, for example. I forgot his username, but he's a friend of mine lol
2014 FR-S Monogram
2005 Acura RSX Type-S
IG: @MonKehC
The Following User Says Thank You to AznKirby For This Useful Post:
Old 01-14-2015, 11:38 PM   #2876
ExquisiteStance
Yes I do! I want to have around the same amount of camber all around 😔 the front still needs to be lowered and running 0 camber atm.
Old 01-14-2015, 11:39 PM   #2877
ExquisiteStance
Yuss! Such a beauty, I need to get in contact with him lol
Old 01-14-2015, 11:46 PM   #2878
lukey86
Built Not Bought
lukey86's Avatar
Not sure whether you can fit them to air but theres aftermarket camber plates
then theres whiteline camber bolts of course
Old 01-14-2015, 11:53 PM   #2879
ExquisiteStance
Yea I have the stock airlift plates so u can add camber from there & I might need the camber bolts but I hear about the bag rubbing on the body 😥
Old 01-15-2015, 12:24 PM   #2880
ZOMFGAARON
A Demon
ZOMFGAARON's Avatar
Drives: Raven GT86
I'd say post in this thread. http://www.ft86club.com/forums/showthread.php?t=68140
Old 01-15-2015, 01:06 PM   #2881
ExquisiteStance
Thanks I'll see if I can get any help there.
Old 01-15-2015, 04:09 PM   #2882
grostoine
Drives: Subaru BRZ
He is running racer-x front LCA to fit these wheels. You cannot put more camber on the airlift topplates. They should not put this on their kit. It is stupid to have adjustable top plate when you cannot touch them ... I'm on air too and had the same problem. I ordered some custom wheels but with less agreesive spec so i dont need camber...
He did not keep those wheels for a long time... Wayyyyyy to much camber in front needed. It was dangerous.
Bad quality wheels too. No bullshit.
grostoine is offline   Reply With Quote
The Following User Says Thank You to grostoine For This Useful Post:
ExquisiteStance (01-15-2015)
Old 01-15-2015, 04:54 PM   #2883
ExquisiteStance
So with the Front LCA I should be able to add camber without risking the bag rubbing? So I can't use the airlift camber plates at all? I don't mind the camber I actually want to run some in the front. What wheels are they? And why do you say that? Is he a member on the forum? Or IG?
Got pictures of your setup?
Old 01-15-2015, 05:14 PM   #2884
PradiG
Drives: Fr-s
im a cheater, im parked on a slight incline
PradiG is offline   Reply With Quote
The Following 4 Users Say Thank You to PradiG For This Useful Post:
cfig21 (01-15-2015), ExquisiteStance (01-15-2015), HATED1 (01-15-2015), s13Henry (01-24-2015)
dontlike?dontlookmoveon
Post the Wheels You want On your FRS/BRZ!! Zaku Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1738 10-11-2017 04:29 PM
RPF1 and PF01 aggressive fitment size requests Crossover Auto Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 12 10-22-2012 02:30 PM
post VIN with any problem thread? fistpoint Issues | Warranty | Recalls / TSB 0 10-04-2012 10:11 PM
Do aggressive offsets cause more debris to kick up into the paint? switchlanez Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 7 09-26-2012 10:03 PM
Scion FR-S / Toyota FT-86 / Subaru with Aggressive Body & High Wing! + VIDEO! Hachiroku Scion FR-S / Toyota 86 GT86 General Forum 538 06-15-2011 02:20 AM
