| Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack Specific topics relating to wheels and tires. |
Wish Nissan made one
Drives: '13 WRB BRZ Premium
Fitting 9.5" wheels in back.. is my math correct?
I've been mulling over the idea of fitting some wide wheels on the back of the BRZ.
I have 2 18 x 8.5 +30 offset fronts and 2 18 x 9.5 +22 rear wheels. I think they would be a great combination. I'd probably keep the stock wheels and put some r-comps on them for autocross and other track use to keep the stock handling and suspension setup. But for daily driving or car show events, a nice set of "RWD" wheels would really make the car look amazing. So, I've used a wheel offset calculator to see what I could figure out. Converting from the stock 17x7 +48mm wheel to a 18x9.5 +22 wheel changes the the inner clearance by 6mm less and the outer clearance by 58mm more. Converting the front wheels from the same 7" +48 to a 8.5" +30 gives 1mm less inner clearance and 37mm more outer clearance. Now.. that would be assuming I could fit the wheels direct to the hub.. . But, I cannot. I will need 5x100 to 5x114.3 adapters. That will add another 19mm (thinnest I could find). So when you add the 19mm to the equation you get +13mm inner in the rear and + 18mm inner in the front.. clearly this is not a problem! However, the outer clearance does move out quite a bit. The 37mm front changes to 56mm and the 58mm in the rear changes to 77mm. Now.. those sound like really big numbers to me, but I don't use mm often, so when converted inches it doesn't sound so bad. 56mm is 2.2 inches. 77mm is 3.0 inches. So.. if I were to move the wheels out 2.2" in front and 3.0" in the back would they rub on the fenders when the suspension compresses? This is assuming I fit tires that have similar "squareness" to them. I wonder if I were to slightly stretch the tires if that would help a bunch. I hate the super-flush rubber band tire craze that is going around.. so I'm not about to adjust for massive negative camber and super stretch tires, etc.. just some slight stretch maybe.. Last edited by eikond; 05-11-2012 at 09:05 AM. |
#2 |
Drives: 2007 STi
If my limited understanding of rwd is correct, you will get understeer with a staggered set up. I'm not sure if you need to worry so much about fender rubbing as I hear the fenders are pre-rolled. I'm waiting for Bill (Scooby South) to put some 17x9 - 245s on to see how they work out. :P
| The Following User Says Thank You to pithy_logorrhea For This Useful Post: | Scooby South (05-11-2012) |
#3 |
Yes, you are right.. it would understeer with wider rear wheels and bigger tire contact patches. Plus it would be a little heavier than stock and that's not great either. However, I wouldn't be using these wheels for track purposes. I would keep the stockers and put some better tires on them for that use.
I just don't like the narrow little fwd offset stock wheels.. They don't do much for the appearance of the car. To save money, I'd like to use the wheels that I already own that are sitting in my basement. I think they would look really good on the car and they are free to me since I already own them. I suppose if it was close, I could roll the fenders a little more (pull them really). Or instead of using the 19mm adapters I could look into re-drilling the hubs. Look at how sunken these wheels are: I have to believe that having wider rear wheels (extending by 3" total) would fit just fine. I think the human thumb is roughly 3" long on average?? So for a frame of reference, imaging someone's thumb length adding to the position of the rear wheels. Then remember than suspension doens't move directly vertical when it compresses.. it swings up and in. I have to think it would clear.
| The Following User Says Thank You to eikond For This Useful Post: | dori. (05-11-2012) |
#4 |
Rocket Surgeon
Drives: PSM GGA OMG
Your math is right, but your eyeballing skills are questionable. The wheels are a bit sunken, but I'd say there's more like 1.5" of space, max. Your wheels just don't have enough offset and the spacer/adapters are only making things worse. Sell your wheels and use the money to buy a set that fits.
#5 |
Señor Member
Drives: white BRZ 6MT
I disagree, you should make em fit. I can't speak for anyone else but I want to know what the limits are when it comes to fitting wheels with no suspension modifications.
#7 |
Drives: 2000 accord v6 coupe
I'm going for 18x8.5+30 work emotions all around. The greddy guys fit 9.5" in the back (don't know the offset though) so it would probably be a tight fit or you may need the red fenders rolled a bit more but who knows until you try!
#8 | |
Conedancer
Drives: 2013 Subaru BRZ SWP
...looking forward to it myself..Stock Rims are 17x7 with a 48.....Everything I have read and studied...says that 8's need to be 48..9's need to be 38-45 or so..so with a 30 offset you might run into some Poke..I will be test fitting my 17x9 42 with a 245/40/17 tire next week when my car gets here.....I would suggest waiting til I get some decent pics of clearance ..I only have 1 tire mounted for now..to ensure they are going to work... ![]() Bill Last edited by Scooby South; 05-12-2012 at 11:48 PM. |
#9 |
Drives: '23 BRZ
Fricking absurd. Under/oversteer from modest stagger is the *least* of your worries.
+30 offset 8.5 fronts, +22 offset 9.5 rears won't fit. Unless you do body modification. And then you still will have changed suspension leverage ratios adversely, and added a TON of scrub radius. This is an 8 1/2" +45 fitment with 235/40-17 tires: ![]() That fits. Another 1.5" pokey-outie? Not so much... |
| The Following 2 Users Say Thank You to ZDan For This Useful Post: | civicdrivr (05-11-2012), Scooby South (05-11-2012) |
#10 | |
Drives: 2018 Golf R
Parting out HERE
#11 |
Drives: '91 MR2
I have some examples. The plain red car has 8" wide wheels with +45 offset.
http://www.ft86club.com/forums/showthread.php?t=5749 The Yokohama/Enkei/TRD car looks to have the 8" +35. The wheels look like they poke out farther, at least in the back. I hope we can get official confirmation on that. http://www.ft86club.com/forums/showthread.php?t=3593 And the white one looks to have 8" wide +45 offset in front with 9" wide +45 offset in back.
Tada-san: Oh so cooler than the concept.
| The Following User Says Thank You to Fly Guy For This Useful Post: | civicdrivr (05-12-2012) |
#12 | |
Drives: Car
Level that car and I'm sold. That'd be a perfect daily driver. |
#13 |
I just don't get the black wheels thing, sorry. I think its because of my age. To me, when I see black wheels from any distance other than up close I think "Hey, dude you lost your hubcaps". Too many years of driving $300 cars with factory steel black rims on them I guess.
| The Following User Says Thank You to Dadhawk For This Useful Post: | Scooby (05-13-2012) |
#14 | |
| "back-seat-remove" option. | Z_Rocks | Scion FR-S / Toyota 86 GT86 General Forum | 53 | 06-25-2013 04:24 AM |
| Which 18" wheels will weigh the same or less than the stock wheels? | mickey177 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 32 | 05-16-2013 03:07 PM |
| The *Official* "I'm Back!" thread | BoostJunkie | Off-Topic Lounge [WARNING: NO POLITICS] | 34 | 02-02-2012 07:21 AM |
| 18" OEM Wheels!!! | madfast | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 40 | 12-11-2011 03:15 PM |
| So, I did a little math on Subaru's new 2.0... | iggyhop9 | Scion FR-S / Toyota 86 GT86 General Forum | 33 | 10-21-2010 11:46 PM |
