Old 01-13-2015, 02:50 PM   #1
seven
Tells it like it is
seven's Avatar
Drives: SS1LE | F150 Diesel | Civic | S3
AVO owners who HPDE/Track... Any issues?
(Sorry if this is somewhere, I've searched and didn't find much specific info)
Just curious if you folks have encountered any cooling issues/things to address when tracking with the AVO kit?
Specifically the base kit, running in the 5-8psi ballpark.
How are you oil temps? Coolant temps? etc
Thanks all
-Seven || youtube.com/turnsevenvideo
2012 C6 Grand Sport 4LT
2015 Mazda 3i-T/Tech
seven is offline   Reply With Quote
Old 01-13-2015, 05:54 PM   #2
kbogarto
Drives: 2013 BRZ limited WRB
I have the base kit in an otherwise stock car. Never tracked it but on spirited driving the coolant temps climb from standard 190 to around 210. Doesn't answer your question but just my experience
92 240sx (sold), 03 350z (sold), 13 BRZ (AVO turbo)
kbogarto is offline   Reply With Quote
The Following User Says Thank You to kbogarto For This Useful Post:
seven (01-13-2015)
Old 01-13-2015, 06:24 PM   #3
DesertFrs
DesertFrs's Avatar
Drives: Scion FRS 10 Series AVO Turbo
Thanks all
I have the AVO kit along with the @DAMotorsports. Like any other kit I recommend getting an Oil Cooler and Upgrading the Radiator. Oil Cooler and Radiator are needed on any stock FRS/BRZ that is tracked, so it will be needed with any turbo kit that is added to the twins.
If you plan on using it for daily driving, sprint driving and drag racing you really don't need one. I live where temps are 120 degrees in the summer here in SoCal.
Once I get home I'll see if I can get you some temp info.
Overall I have no issues with the kit. I installed it when my car had 2k miles on it and I am currently at 20k. With my Highest map set at 16psi the issue I run to is trying to keep traction... LOL
Hope this helped.
AVO STG1 Turbo w/ 8PSI Actuator, AVO 3" Catless Turbo Back Exhaust, AVO Air Filter, ACT 6 Puck Clutch, DW65c Fuel Pump, 900cc DW Injectors, Grimmspeed EBC, Delicious Tuning Custom Tune, 0W-20 Purol, AEM Strutbar, GrimmSpeed Hood Struts, Mann Engineering Coilovers, RacerX UCA, Gram Lights 57Xtreme, 275/35/18 BfGoodrich G-Sport Comp2 Tires, MV Designz Aero Kit, Beatsonic Shark Fin & Roof Spoiler, Five Axis Trunk Spoiler, OEMAudioPlus Reference 400
DesertFrs is offline   Reply With Quote
The Following User Says Thank You to DesertFrs For This Useful Post:
seven (01-13-2015)
Old 01-13-2015, 11:10 PM   #4
FrX
Drives: 2013 Scion FR-S, 1993 Lexus SC300
Coolant temps have always been fine for me on the stock radiator. Oil temps are pretty high though. I logged 137 deg C in the middle of June. I would recommend an oil cooler. I would also recommend coming up with some sort of heat shielding for the motor mounts ( passenger side at least ). I melted mine.
FrX is offline   Reply With Quote
Old 01-13-2015, 11:44 PM   #5
jflogerzi
jflogerzi's Avatar
IMO at the lower PSI levels, only an oil cooler should be needed as you don't have a front mounted turbo dumping heat into the engine bay. Upgrading your radiator should not be required. Oil temps on a stock NA car in decent ambient temps can get pretty damn high as it is
The Following User Says Thank You to jflogerzi For This Useful Post:
seven (01-14-2015)
Old 01-14-2015, 12:04 AM   #6
sw20kosh
Drives: 2013 Black FR-S
No radiator is required. This has been tested by multiple peopleon Cali tracks. The limits of the stock radiator have not been found. People who buy radiators are just throwing money at vendors for no reason.
I would recommend an oil cooler much bigger than the standard 13 row setrab series 6. I would go with a setrab 15 row series 9.
The Following 3 Users Say Thank You to sw20kosh For This Useful Post:
EAGLE5 (01-14-2015), hmong337 (05-04-2015), seven (01-14-2015)
Old 01-14-2015, 02:07 AM   #7
seven
Tells it like it is
seven's Avatar
Yeah, stock(ish) boost levels. No more than 8 psi basically. I don't need more than 275-300whp (which is likely do-able at 8psi with supporting mods).
I would probably grab AVO's oil cooler kit, and I figured a rad wasn't needed, perhaps a lower t-stat as a bit of piece of mind at most.
Thanks all.
Old 01-14-2015, 02:23 AM   #8
jflogerzi
jflogerzi's Avatar
Thanks all.
Don't bother with the t-stat. Stock is fine
2013 Series 10 FRS #553
sw20kosh (01-14-2015)
Old 01-16-2015, 02:18 PM   #9
Drift-Office
Drift-Office's Avatar
Drives: AE86 / FRS / FC3S / GC8 / S14 / R32
When did you get back into a FRS?! :P
Bob @ Drift-Office, LLC
Drift-Office is offline   Reply With Quote
Old 01-18-2015, 07:16 AM   #10
Flasher
Smartass
Flasher's Avatar
Drives: Toyota GT86 & Impreza STi
If u'r planing on getting the AVO Kit, don't forget to buy the AVO breather tank. Otherwise you will get lots of blow-by, especially when tracking.
Toyota GT86, Leather, JBL-Sound, Aero-Kit, inferno orange
MODS |O.Z Leggera 18 x 8,5|Front:Tarox B32|Rear:OEM+EBC GreenStuff|Braided Lines|Milltek CAT-Back & Overpipe|Motiv Concepts catted Frontpipe| AVO Turbo|AVO breather tank|Mishimoto Oilcooler|Exedy Stage 1 Clutch|BeatSonic Sharkfin|TRD Ducktail|TRD Aero cover|Valenti blinker
Flasher is offline   Reply With Quote
Old 01-19-2015, 09:20 AM   #11
ChrisD
ChrisD's Avatar
Drives: GT86
I saw that the AVO Breather Kit is a recommended item to buy along with the AVO turbo kit, but what exactly does the breather kit do? What is it?
ChrisD is offline   Reply With Quote
Old 01-19-2015, 10:15 AM   #12
protpibe
protpibe's Avatar
Drives: 4-Runner Sport - 13' BRZ SportTech
I did my first track day in spring of last year when the ambient temps were at about 8 degrees celcius and my oil temps were still uncomfortably high. I installed an oil cooler shortly thereafter. An oil cooler is 100% mandatory for any boosted BRZ/FRS, regardless of being tracked.
As for a radiator, like someone else said, it's not really necessary. I've never had an issue with water temps even on days that are 30C. Even though I didn't need it, I installed an FBM rad upgrade with shroud and fans. Difference? None that I could tell, although with the hood up and fans going, you can feel a LOT more heat being pushed out of the fans. But I'm sure that's what the stock rad does when air is being forced through at speed.
In summary:
-Get an oil cooler
-You don't need a rad
Top Tier Imports - Check out my build journal HERE
protpibe is offline   Reply With Quote
Track Days: HPDE and AutoX Campo Arizona 35 07-29-2015 08:22 AM
Minimal safe setup for a track day/hpde? slaxx Tracking / Autocross / HPDE / Drifting 37 01-19-2015 01:20 AM
2014 HPDE and Track Day Schedule Nihilation Tracking / Autocross / HPDE / Drifting 2 01-10-2014 04:17 PM
Track/HPDE insurance CSG Mike Tracking / Autocross / HPDE / Drifting 6 08-06-2013 01:36 AM
PacNW Track Day/HPDE/School thread rice_classic Northwest 12 07-10-2012 08:58 PM
