Old 01-13-2015, 01:14 PM   #5937
DeliciousTuning
PhoneFlash by EcuTeK
DeliciousTuning's Avatar
Originally Posted by Fizz View Post
I just flashed the Innovate Stg2 tune, and first thing I noticed when driving off was the lethargic throttle response, which seems like there's nothing much happening in the first 5mm of throttle pedal travel. Needed to give it more gas so I didn't stall at lights.
Initially I put this down to the "just flashed" symptom where the ECU takes awhile to get up to speed. But reading Bill's post I wonder if it's possible to switch throttle map to "Sport" instead.....because at the moment it feels like its on the "Soft" setting as described above.
Also noticed some bucking happening when taking off quickly, where the car jerks momentarily as soon as I've released the clutch pedal and press on the throttle.
Pretty sure Bill will be able sorts these issues out, and apart from that, it's really smooth to drive and the biggest improvement I've noticed was the total elimination of shift-knock and tip-in knock at WOT.
I believe you have our update for the throttle at this time and should make the care more responsive as requested.
Cheers,
William Knose
Old 01-13-2015, 01:49 PM   #5938
xxscaxx
Drives: 2013 SWP BRZ
Originally Posted by Canivideo View Post
I've been searching all morning but haven't been able to find the information:
Can anyone provide the hex bolt size for the 6 bolts that attach the rear intake chamber? See image below.
TIA.
They are M6x20 bolts.
xxscaxx is offline   Reply With Quote
The Following User Says Thank You to xxscaxx For This Useful Post:
Canivideo (01-14-2015)
Old 01-13-2015, 02:31 PM   #5939
brianhj
Drives: 2017 Camaro 1SS
My wrench says 5mm. I tried 5.5mm and it was too big.
brianhj is offline   Reply With Quote
Old 01-13-2015, 02:32 PM   #5940
poorsche
poorsche's Avatar
Drives: 13 BRZ Limited, 2000 Impreza Sport
Bolt sizes are typically by shank diameter, not head size
Innovate powered- Corn fed- FBM tuned
poorsche is offline   Reply With Quote
The Following User Says Thank You to poorsche For This Useful Post:
Ultramaroon (01-13-2015)
Old 01-13-2015, 02:34 PM   #5941
brianhj
That's why I specifically said I used a 5mm wrench because I had a feeling bolt specs are retarded like that
Old 01-14-2015, 03:23 AM   #5942
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
Anyone with the innovate/sprintex kit using the OEM Subaru oil cooler? I'd like see how you've connected the hoses to the throttle body inlet/outlet....
Fizz is offline   Reply With Quote
Old 01-14-2015, 08:40 AM   #5943
Vex
Running the Sprintex 210 w/ inter cooler with a 69mm pulley, E85 (flex fuel), full HKS exhaust w/ cats and a custom Ecutek tune.
1050cc injectors.
Pulling about 11psi and 200kw at the wheels - is this what I should be expecting or should I be getting more out of the car?
Vex is offline   Reply With Quote
Old 01-14-2015, 08:58 AM   #5944
sam69
Drives: GT 86
1050cc injectors.
Depend on the dyno and the operator.
sam69 is offline   Reply With Quote
Old 01-14-2015, 10:42 AM   #5945
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
^ This. Personally I don't really care what peak power my car makes or can make, but instead how the power and torque is delivered when driving.
Old 01-14-2015, 11:19 AM   #5946
stockysnail
Just the tip
stockysnail's Avatar
1050cc injectors.
That's sound like you're in the correct ballpark. No cats would get you a little more as would a full 3" exhaust, but the price/increase isn't really worth it in my opinion.
Old 01-15-2015, 12:36 PM   #5947
xxscaxx
Are you talking about the OEM forester cooler? If so I have it, but the setup is no different than if I was running the supercharger or not. I'd check that thread out for more info (if thats in fact what your talking about lol).
Fizz (01-16-2015)
Old 01-16-2015, 10:37 AM   #5948
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
Yes the forester cooler. Nevermind I figured out how to run the coolant lines. I'm going to just hook it up to the throttle body coolant loop.....the easiest method
The Following User Says Thank You to Fizz For This Useful Post:
asphaltkyle (03-05-2015)
Old 01-16-2015, 11:07 AM   #5949
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
Anyone still using the factory catback with the supercharger? Is it possible for the internal baffles inside the factory muffler to fail/break?
I've noticed over the past week or so that there's a loud rasp coming from the muffler. Started happening intermittently and only in certain mid to high engine loads. But since I fitted my catless UEL header this morning the rasp just went ballistic! Even blipping the throttle in neutral now will give out an enormous rasp, very distinctly coming from the rear end.
Note: there are no leaks whatsoever, and was verified by the exhaust shop. I'm going to try borrowing a mate's used factory muffler to see if that makes any difference. By the way my exhaust setup is catless header, 2.5" overpipe, 2.5" catted front pipe, stock catback.
Old 01-16-2015, 12:32 PM   #5950
kbye
kbye's Avatar
Drives: 2014 FR-S
Unlikely it's your muffler's fault. The rasp is def. from your header. You hear it from the rear end because that's where the exhaust sound comes from. You wouldn't expect it to come from the front end, unless you have an exhaust leak.
kbye is offline   Reply With Quote
Innovative ideas to increase interior storage capacity? swift996 Cosmetic Modification (Interior/Exterior/Lighting) 0 01-30-2013 10:45 PM
AVO vs Innovative diss7 Forced Induction 32 01-21-2013 06:15 PM
Technical topic sub-forums OrbitalEllipses Site Announcements / Questions / Issues 1 07-17-2012 11:38 PM
