Old 01-07-2015, 06:33 PM   #15
cjd
cjd's Avatar
Drives: 2017 BRZ
Originally Posted by kodyo View Post
This is technically how the dealer is told to install these, or at least somewhere close to that. Is this what yours looks like?
Try to complain if that's what they did, but not sure you're guaranteed any replacements. Painting the plugs sounds like a decent alternative if they won't cover a new bumper.
Wow. I'm not sure what Scion suggests, but the install kit I got would have resulted in the two large holes only. Thankfully the shop I used did not install the plate for me, and after duly alerting me to the law I put the plate in the dash and drove off. I ended up using the magnet trick for mine, not sure that works on a Scion (it might...)
Regardless, the kits provided DO require additional holes, and when the state law mandates the front plate and the dealer does the install, that's how it goes.
Old 01-07-2015, 07:12 PM   #16
Bristecom
Bristecom's Avatar
Drives: 2017 Subaru BRZ PP
Originally Posted by Enders FRS View Post
No. It will cause more turbulence, and will degrade the efficiency of the stock set up slightly. But would not cause failure.
But because I'm not an Aerospace Engineer, I ran it past my fiancé, who is one semester shy of completing her coursework on her doctorate in computational fluid dynamics, I asked her. She said its fine.
Yeah, it's probably fine but I just remember from years of watching WRC that it was a big deal when something even partially blocked the radiator. Of course, their tolerances are probably much lower than a stock car.
As silly as it may sound, the front license plate law is a big reason why I refuse to live in some states. A lot of cars like this simply aren't designed well to accommodate a big, ugly plate. So much for optimized aerodynamics.
Toyota + Subaru =
Bristecom is offline   Reply With Quote
Old 01-12-2015, 09:53 AM   #17
jamies31
jamies31's Avatar
Drives: 2014 Scion Frs (Argento)
That is not even close to how the mount is supposed to be installed to the front bumper, Its sad to see some people at the dealership cant even take the time to read the instructions that come in the bag with the mount
jamies31 is offline   Reply With Quote
Old 01-12-2015, 10:06 AM   #18
adamg
Drives: brz
adamg is offline   Reply With Quote
Old 01-12-2015, 02:24 PM   #19
N1rve
N1rve's Avatar
Drives: 2019 BMW ///M4
Wow...I bought my car in California and ALL the FRS' on the lot were not drilled. They told me that customers kept complaining about a drilled bumper so they stopped on all FRS'.
They're just feeding you BS.
Hence my California bought FRS with no drill holes and tow hook for license plate
N1rve
Old 01-12-2015, 03:08 PM   #20
wrussi
wrussi's Avatar
Drives: 2013 frs
you most likely wont get anywhere with it since technically it is a part required by law.
YOU should have checked and noticed that the car already had the front liscence bracket on BEFORE signing, requested another vehicle that didnt had the bracked installed or requested a repair.
as a guy with OCD, on all my car purchases (yes even new) before final paperwork is signed i like to go out with the sales guy and point out any dents, scratches or imperfections that i notice. if there is anything major (bumper scratches underneath from transport dings or scratches on interior panels) i like to get a signed promise to repair from the dealership before i continue signing. they hate me but hey i dont care.
wrussi is offline   Reply With Quote
The Following User Says Thank You to wrussi For This Useful Post:
tennisfreak (01-12-2015)
Old 01-12-2015, 03:42 PM   #21
tennisfreak
Drives: 2018 BMW M240i
This x 1000.
I worked my deal over the internet and when I arrived they pulled it around front for me to inspect. After parking the little shop fellow that popped out of the driver seat went straight to the front bumper with a bracket in hand. I promptly told them if he put that thing on the bumper I would not sign.
Old 01-12-2015, 08:14 PM   #22
Miniata
Drives: 13 BRZ - 90 Miata - 07 FXT -05 Mini
Front plate is law in my state too, but I told the dealership when I ordered my car, and again when they called to tell me it had arrived, that if they drilled the front bumper or mounted the front bracket in any way, the deal was off. They complied with my wishes.
17x7 Kosei K1-TS w/ 215/45-17 Dunlop Star Specs
Nameless Track Pipe - Strano front sway bar
Miniata is offline   Reply With Quote
Old 01-13-2015, 09:45 AM   #23
BlueSky
BlueSky's Avatar
Drives: 2015 Aozora BRZ
It's the law in Ontario too, I got lucky when I picked mine up the dealer asked if I wanted it drilled centered or offset
Told him not to worry about it, he mentioned he had received tickets for no front plate ($110) but I have been lucky so far
BlueSky is offline   Reply With Quote
Old 01-13-2015, 10:11 AM   #24
funwheeldrive
I made it a point to not have my license plate drilled in before picking up my car. I've never heard of anyone getting pulled over for a front plate in California.
Old 01-13-2015, 02:31 PM   #25
Poodles
Drives: 2015 Series.Blue
Keep in mind that this may be because it's a secondary offense and not a primary offense.
I don't know the laws there, but a secondary offense is something they can write you a ticket for it they have already pulled you over, but they can't pull you over simply for a secondary offense.
It's a primary offense here so I run a Raceseng mount.
Old 01-19-2015, 10:34 PM   #26
jeffsquared
Drives: 2013 FR-S 10 Series #1186
My state requires front plates. This picture in this post illustrates almost exactly how the dealer installed it. Mine might be a little bit higher but not touching the painted part of the bumper.
At least they didn't drill holes into the painted part. If they're told to drill into the paint then I guess thankfully my dealer did it wrong
http://www.ft86club.com/forums/showpost.php?p=1411145&postcount=13
Yeah, it blocks airflow a bit, and I wish I didn't need the front plate, but the holes are already drilled.
jeffsquared is offline   Reply With Quote
Old 01-19-2015, 10:43 PM   #27
2much
I wanna go fast
Drives: 2013 FR-S 6MT
Originally Posted by msugi07 View Post
Hey guys,
So I purchased my FRS brand-new from the Livermore California dealership. After owning the car for about one week, I decided to take the black bracket off of the front bumper and noticed that they installed the bracket incorrectly. They installed additional screws drilling into the painted part of the bumper. After discovering this I contacted the dealership right away. The dealership stated that they were instructed by Toyota to install the front license plate this way. At this point I have contacted Scion to try and get someone there to help me. Anyone with any ideas on how I can get this resolved?
my dealer did the same thing!
2much is offline   Reply With Quote
Old 01-19-2015, 11:11 PM   #28
Sugi
Sugi's Avatar
Drives: 2015 FR-S - Halo
I still have not got this resolved. let me know if you find out anything
Sugi is offline   Reply With Quote
Request: Filling in holes from dealer license plate bracket? t00n3wb DIY (Do-It-Yourself) Guides 12 08-14-2013 09:06 AM
Installed these CF License Plate Frames mechaghost Cosmetic Modification (Interior/Exterior/Lighting) 4 12-21-2012 07:05 PM
Front license plate: Why you don't want the dealer to drill your bumper CircuitJerk Issues | Warranty | Recalls / TSB 53 08-27-2012 03:02 AM
Bumper Plugs for License Plate holes by dealer? mikeg7827 Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 6 08-13-2012 06:33 PM
License plate holes - Dealer installed for sure? FastLap Scion FR-S / Toyota 86 GT86 General Forum 28 08-05-2012 04:20 AM
