Old 01-11-2015, 11:27 AM   #2381
CSG Mike
CSG Mike's Avatar
Originally Posted by Jonsey View Post
I am having an issue that I believe is fuel starvation but want to see if anyone else is having similar issues or if it is something else.
The issues always start when I am getting close to 5/8th of a tank left. It is only happening in two places and both are long high G left hand corners. The first set of corners is a three corner assembly that is run at between 75-80mph at 1.1g and the entire section takes about 10 seconds. I start having issues about 3/4 of the way through the following straight and then it starts cutting out. I enter into the next turn, which is another sweeping left hander done at similar speeds but is only about 4-5 seconds. Once I come out of that I have no power for 3 or 4 seconds when it first starts happening and about 10-15 seconds once I get below half a tank. Once the power comes back, I can run the rest of the track fine until I reach that section again.
First, is this fuel starvation? Second, if so, what options do we have to handle this? Running E85 the car is burning through 3/8 tank in a 30 minute session and there is no e85 within 20 miles of the track, so I can't easily keep it at a full tank.
Yup, that's fuel starvation. It won't happen on a NA car on gasoline, but with FI or E85, you basically have to keep the tank full; the pickup is on the left side of the car, so long left handers will make the fuel pump starve.
The solution is a surge tank, (and preferably in-tank), but there isn't one in production, yet.
From experience, I can tell you that you can easily fit 6 5-gallon jugs in the car, in addition to a set of tires, tools, etc...
Old 01-11-2015, 01:15 PM   #2382
enivid
enivid's Avatar
Drives: WRB JR BRZED
@zdr93523 no more running on empty tanks for you.
enivid is offline   Reply With Quote
Old 01-11-2015, 01:16 PM   #2383
zdr93523
zdr93523's Avatar
Drives: 2013 BRZ Limited
Good call hahaha. So running out of gas is bad?
Instagram: @zdr_93523
Youtube: https://www.youtube.com/user/zdr93523
Pink Ribbon Racing 2013 BRZ Limited NASA ST2 and TT2 race car
www.makesmodels.com
www.camautomag.com
zdr93523 is offline   Reply With Quote
Old 01-11-2015, 01:24 PM   #2384
ZionsWrath
Thanks
ZionsWrath's Avatar
Only for your wallet. But not if it won't notice a few ounces missing.
Old 01-11-2015, 01:45 PM   #2385
BRZZZZZZZZZZ
Car Nut
BRZZZZZZZZZZ's Avatar
Drives: BMW 335d, Toyota Echo RS, FRS
If you had to go with a BBK that was potentially also going to be driven in winter (temps as low as -30 Celsius and lots of snow and ice) and also had to fit under a 17" wheel what would be the best bet?
BRZZZZZZZZZZ is offline   Reply With Quote
Old 01-11-2015, 05:39 PM   #2386
dp1
driving smoother faster
Drives: Sold
Don't have an answer re very low temps, but I drive AP Sprint BBK in NE US Apr-Nov and swap caliper/rotors/pads for stock Nov-Apr due to salt on the roads in winter. You only need BBK if you track the car and more so with FI and stickier tires. AP Sprint BBK doesn't have protective rubber boots on steel pistons but some that do will disintegrate from heat with track use. All of my wheels are 17". AP Sprint BBK makes a world of difference on track with proper pads. I use Carbotech XP 12 on track, AX6 for AX and 1521 (Bobcats) for street. Pads for this BBK are much thicker and last much longer than stock.
dp1 is offline   Reply With Quote
Old 01-11-2015, 06:34 PM   #2387
Fricke
Drives: Toyota GT86
Stock or AP Calipers? Send @CounterSpace Garage a PM to get a quote.
Dont forget the pricing on pmu rsf01 and rsr02.
PM sent
Fricke is offline   Reply With Quote
Old 01-11-2015, 08:39 PM   #2388
BRZZZZZZZZZZ
Car Nut
The AP is out for the reasons you stated. I will not be switching back to stock rotors and calipers as its a basically a backup car for winter just in case so I want something that will deal with it just in case.
Old 01-11-2015, 08:49 PM   #2389
Lunatic
Lunatic's Avatar
Drives: 2015 Raven FRS
This I gotta see! Not doubting you but how in the hell dod you do it? I will be doing this for the 24th. Got any pictures of your placement of everything?
Lunatic is offline   Reply With Quote
Old 01-11-2015, 09:00 PM   #2390
CSG Mike
CSG Mike's Avatar
4 tires in back, 1 gas jug on top in the center.
2 gas jugs on passenger seat, 1 in foot well.
2 jugs in trunk + tools + everythign else.
This is retaining the stock spare tire; without it and the foam pieces, you can fit more.
Old 01-11-2015, 10:20 PM   #2391
Lunatic
Lunatic's Avatar
Are the tires standing up or laying down?
Old 01-11-2015, 10:26 PM   #2392
CSG Mike
CSG Mike's Avatar
standing up in the back seat
Old 01-11-2015, 10:27 PM   #2393
CSG Mike
CSG Mike's Avatar
We have options with dust boots and painted calipers if you're interested
Old 01-11-2015, 10:32 PM   #2394
Lunatic
Lunatic's Avatar
Thanks Mike.
Simple question, hard to find answer... Mango22 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 05-16-2013 06:23 PM
Silly question about protecting track rims sw20kosh Tracking / Autocross / HPDE / Drifting 16 04-25-2013 12:34 PM
Asking the question that I already know the answer to. Are the engines the same? Bigmaxy Engine, Exhaust, Transmission 10 01-19-2013 07:47 PM
Random dog-related question for those who have their BRZ GMU-BRZ BRZ First-Gen (2012+) — General Topics 11 05-31-2012 07:48 AM
Got my answer - BRZ comes with HID headlights as STD Z_Rocks BRZ First-Gen (2012+) — General Topics 20 01-10-2012 09:54 AM
