Old 01-10-2015, 02:40 PM   #15
torqdork
torqdork's Avatar
Drives: RV-7
Originally Posted by Bobblehead View Post
Mine uses gas when I drive it.
There you go, he uses petrol.
torqdork is offline   Reply With Quote
Old 01-10-2015, 02:41 PM   #16
Originally Posted by torqdork View Post
Oh, before posting I thought he must be a new owner and remembered climate and road conditions when I lived there.
Nah he pops up every once in a while. Sorrta the Aussie version of SquadRougue sometimes.
Old 01-10-2015, 02:45 PM   #17
Lonewolf
Lonewolf's Avatar
Drives: Moped
In other news, the car has doors...
Old 01-10-2015, 03:32 PM   #18
Defuser
Remember
Defuser's Avatar
Drives: 2015 Asphalt
Death. Taxes. Prius tires.
This is my 17th car. Most fun so far!
Defuser is offline   Reply With Quote
Old 01-10-2015, 04:00 PM   #19
D_Thissen
D_Thissen's Avatar
I use the clutch when i want to start my car and change gears
There is a clutch?
Well.. That explains all the painful grinding. Ill have to try this clutch thing. Im a firm believer in grind it til you find it
Old 01-10-2015, 04:16 PM   #20
1GiantTurtle
Space for Rent
1GiantTurtle's Avatar
Drives: 2014 6MT ToyoBaru86ScionMonogram?
It's amazing I guarantee you won't go back ,
ToyoBaruScionGT86hachiRokuBRZMonogram
Instagram: 86turtle
Instagram: 86turtle
1GiantTurtle is offline   Reply With Quote
Old 01-10-2015, 04:17 PM   #21
1GiantTurtle
Space for Rent
What ???I get in through the windows because racecar
Instagram: 86turtle
Instagram: 86turtle
Old 01-10-2015, 06:47 PM   #22
carma143
carma143's Avatar
Drives: Toyota Highlander; Subaru BRZ (SWP)
^^^^ Tcoat should "Thank" this.
carma143 is offline   Reply With Quote
Old 01-10-2015, 07:20 PM   #23
Old 01-10-2015, 07:28 PM   #24
Bristecom
Bristecom's Avatar
Drives: 2017 Subaru BRZ PP
Yes, the stock tires do not have much grip - especially in wet and cold conditions. You want to be careful about over-correcting when counter steering or you will fish tail and lose control without TC/SC intervention. A technique I use is very quickly just give it a bit of counter steer and return to the center, and if it needs more, repeat until you are back in line. This way, you can have a nice controlled drift. But you also have to be careful with your throttle during this too. You actually want to stay on the the throttle a little as it puts more weight on the rear and balances it and allows the rear diff to work.
But as you found out, even if you are not too good at all of that, the modern electronics will still save you most of the time.
Toyota + Subaru =
Bristecom is offline   Reply With Quote
Old 01-11-2015, 01:12 AM   #25
Hotrodheart
Hotrodheart's Avatar
There is a clutch?
Whut's a clutch?
Hotrodheart is offline   Reply With Quote
Old 01-11-2015, 01:21 AM   #26
Originally Posted by Hotrodheart View Post
Whut's a clutch?
Holy crap no wonder people have a hard time learning English!
Apparently a "clutch" is a shit load of things:
1. To grasp and hold tightly: a child clutching a blanket.
2. To seize; snatch: clutched the banana from my hand.
v.intr.1. To attempt to grasp or seize: clutch at a life raft.
2. To engage or disengage a motor vehicle's clutch.
n.1. A hand, claw, talon, or paw in the act of grasping.
2. A tight grasp.
3. often clutches Control or power: caught in the clutches of sin.
4. A device for gripping and holding.
5. a. Any of various devices for engaging and disengaging two working parts of a shaft or of a shaft and a driving mechanism.
b. The apparatus, such as a lever or pedal, that activates one of these devices.
6. A tense, critical situation: came through in the clutch.
7. A clutch bag.
adj. Informal 1. Being or occurring in a tense or critical situation: won the championship by sinking a clutch putt.
2. Tending to be successful in tense or critical situations: The coach relied on her clutch pitcher.
Idiom: clutch at straws
Old 01-11-2015, 01:24 AM   #27
Whut's a clutch?
Old 01-11-2015, 01:30 AM   #28
Whut's a clutch?
By the definitions I think this is a clutched clutch!
2015 BRZ paint easily stained einstein Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 27 05-12-2015 11:01 AM
Are BRZ .Blue Edition parts easily removable? Stang70Fastback BRZ First-Gen (2012+) — General Topics 18 10-20-2014 08:23 PM
SLIPS, the Last Step Protection of the future? LeftFootBrake Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 6 08-15-2012 01:30 AM
Handling a little weird? Pulls/slips while on freeway. kuma Scion FR-S / Toyota 86 GT86 General Forum 29 07-10-2012 05:18 PM
