Old 01-07-2015, 07:59 PM   #2157
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
Originally Posted by el-92 View Post
Hey guys quick question anybody experience loss of power around 4500 in 6 gear at 100+ ?? Loses power round that then starts climbing again . I'm on stage 2 tune e85 any pointers to get rid of that little dip ?
I'll be in LA on Saturday. If you can reproduce what you are describing and show it to me, I'd love to see/log it.
Shiv@Openflash is offline   Reply With Quote
Old 01-07-2015, 08:06 PM   #2158
el-92
el-92's Avatar
Drives: 2014 ASPHALT FR-S MT
Yes that sounds good
el-92 is offline   Reply With Quote
Old 01-08-2015, 12:15 PM   #2159
Luckrider
My Other Ride's a Jeep
Luckrider's Avatar
Drives: 2013 BRZ Limited
Just so we're all aware, 6th at 4500 is something like 130 or 140mph. It is getting awfully close to the cars top speed.
Luckrider is offline   Reply With Quote
The Following User Says Thank You to Luckrider For This Useful Post:
D_Thissen (01-08-2015)
Old 01-08-2015, 12:59 PM   #2160
Bergen23
Drives: '15 Halo FR-S
There's not a chance I'll be reading through 99 pages of this. My question is this.
I'll be getting the OFT shortly. I have an AEM intake and a Spec-D exhaust. I'm curious as to which tune would be the ideal one to use. One consideration, the AEM intake has an extra sensor included with it, so it adjusts things on the intake side by itself (Or so it claims).
Will I still need a tune for the intake, or just something with the exhaust?
Bergen23 is offline   Reply With Quote
Old 01-08-2015, 01:19 PM   #2161
KoolBRZ
KoolBRZ's Avatar
Drives: Silver 2013 BRZ Ltd Auto 45,000 mi
Depends on which header you're using. Stock header stage 1 tunes, equal length headers use stage 2 EL tunes, and unequal length headers use stage 2 UEL tunes. For the intake I recommend checking for a MAF scale that's already been done for the AEM without adapter. All the adapter does is compensate for the change in MAF scale. Once you have the OFT you can scale the MAF yourself. Seriously, you won't get the most responsive, quick, and quiet power gains without scaling the MAF as close to 0% STFT/LTFT as you can get it. No manufactured option can come as close as doing it yourself. If you doubt me, just hook up your OFT, select diagnostics, your car, and watch your STFT and LTFT numbers. Positive numbers are too lean, and negative numbers are too rich. Too much either way costs you power and mileage. Anything over 5 positive or negative is worth fixing.
KoolBRZ is offline   Reply With Quote
Old 01-08-2015, 01:20 PM   #2162
Bergen23
Cool. I'm on the stock header for now. I guess I'll have to wait until I get it and play around with stuff.
Old 01-08-2015, 02:17 PM   #2163
j_Zer0
Drives: Asphalt FRS 2014
I got a CEL with code P0700 after reading my car's stock ECU file with the OFT. On a different thread I think I remember @Shiv@Openflash saying that this code is normal for 6AT cars during the flash process and the code will clear itself in a few drive cycles. Only thing is, I just did a read and haven't written anything yet. Can any 6AT owners confirm that a P0700 CEL is normal with OFT use and will clear itself? Many thanks.
j_Zer0 is offline   Reply With Quote
Old 01-08-2015, 02:53 PM   #2164
phrosty
It's normal. It'll clear after some drive time.
phrosty is offline   Reply With Quote
The Following User Says Thank You to phrosty For This Useful Post:
j_Zer0 (01-08-2015)
Old 01-08-2015, 05:04 PM   #2165
Jyn
Noob
Jyn's Avatar
Drives: FR-S Mammogram
Is there a need to do MAF scaling with the TRD intake? Sorry if it's been asked, I got through ~22 pages before I got sidetracked.
Jyn is offline   Reply With Quote
Old 01-08-2015, 06:30 PM   #2166
KoolBRZ
KoolBRZ's Avatar
If you have the OFT, what are your STFT/LTFT numbers like? If they are less than 5 plus or minus, I would leave it alone, more than 5, scale the MAF.
Old 01-08-2015, 06:59 PM   #2167
Jyn
Noob
Jyn's Avatar
Ah, okay. Was looking to see if anyone knew, but I should have my OFT hooked up by the end of the month. Car is currently in the body shop
Old 01-08-2015, 09:19 PM   #2168
cuddefred
Drives: Black 86 GT
I'm pretty sure it is much nearer to 105mph in the manual than the figures you mention here
cuddefred is offline   Reply With Quote
The Following User Says Thank You to cuddefred For This Useful Post:
el-92 (01-09-2015)
Old 01-08-2015, 11:05 PM   #2169
TruRace
TruRace's Avatar
Drives: FRS-Raven-MT
Originally Posted by themajesticone View Post
I'm selling my OFT soon - this company and its representative are full of complete nonsense. Stay away people or you may have some engine problems in the long run.
Care to elaborate?
TruRace is offline   Reply With Quote
Old 01-09-2015, 12:19 AM   #2170
steve99
Drives: FT86
If you can log it. would be helpful in diagnosing any issue.
Suggest
rpm
load
flkc
Knock Correction
IAM
AFR
Commanded AFR
Throttle plate
IAT
LTFT
STFT
MAF
speed
cat overtemp
OpenFlash Tablet Rombinhood@OpenFlash Software Tuning 1838 07-29-2023 07:35 PM
OpenFlash Tablet Stg 2 Tune (Dyno Progress) Rombinhood@OpenFlash Software Tuning 26 10-24-2013 02:19 PM
FBM Tuning fixed my issue, FA20 and Visconti didn't work as well whitefrs Forced Induction 253 08-19-2013 01:39 PM
