Old 01-07-2015, 09:41 PM   #1107
Porcupint
Drives: 13 GBS BRZ
And I just bought Cusco arms. Damn it.
Porcupint is offline   Reply With Quote
Old 01-07-2015, 10:14 PM   #1108
AZbrz89
Drives: 14 BRZ Crystal Black Silica Limited
@Jive Turkey should I consider the spc toe arms too? Im running 18x9.5 with 255/35/40 all around. Thanks for your input!
AZbrz89 is offline   Reply With Quote
Old 01-07-2015, 10:24 PM   #1109
Creole
Creole's Avatar
Drives: Monogram FRS
Meaty Tire Thread
I have 255/35/18 Michelin super sports on 18x9.5+45. I also have the SPL control arm, and other tid bits. Do you think I will need to give a minor roll to my fender?
Build Thread:
Creoles Creation
Creole is offline   Reply With Quote
Old 01-07-2015, 10:52 PM   #1110
AZbrz89
You having any rubbing issues?
Old 01-07-2015, 11:02 PM   #1111
Creole
Creole's Avatar
Meaty Tire Thread
Not sure yet, haven't gotten it off the lift. I was asking out of curiosity of what to expect. I don't think I will rub though
Build Thread:
Creoles Creation
Old 01-07-2015, 11:14 PM   #1112
AZbrz89
Let me know because my set up wont be ready until 1st week of February because the 18x9.5+45enkei raijins are on back order
Old 01-07-2015, 11:58 PM   #1113
Creole
Creole's Avatar
Will do! I went back and re read the first post, and I'm almost certain I won't rub. (Aside from the tab on the front bumper).
Build Thread:
Creoles Creation
Old 01-08-2015, 12:19 AM   #1114
AZbrz89
Thanks! I got a dremel worst case scenario.
Old 01-08-2015, 07:22 AM   #1115
adprokid
adprokid's Avatar
Drives: ZN6 / GDB-G
My friend is running 18x9.5 +45, 255/35 Michelin PSS, Ohlins coilovers, unrolled fenders with no rub even on hard turns, he only rubs when he is turning full lock to the right getting out of a parking! Funny that I noticed this too as I run same setup but on Goodyear, I just don't turn it full lock.
adprokid is offline   Reply With Quote
Old 01-08-2015, 09:08 AM   #1116
BRZZZZZZZZZZ
Car Nut
BRZZZZZZZZZZ's Avatar
Drives: BMW 335d, Toyota Echo RS, FRS
I am running SPC arms and they have slipped once. I am going to machine spacers for them as I leave them at a set spot, and fit those spacers in on either side so there's no chances of them slipping.
BRZZZZZZZZZZ is offline   Reply With Quote
Old 01-08-2015, 02:02 PM   #1117
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
Originally Posted by texasbound972 View Post
I'm gonna have close to 600 ftlb of torque. So yeah I actually need wider tires lol. If you haven't been following my build I'm getting Crawfords built short block and my turbo is twice as big as his. I'm on KW V3's.
600 ft lbs would put you roughly at 700ish whp. assuming thats wtq. Goodluck with anything but Mickey's or non-DOT's breaking loose. Oh and dyno please when it comes to light
The Following User Says Thank You to cdrazic93 For This Useful Post:
texasbound972 (01-08-2015)
Old 01-08-2015, 04:24 PM   #1118
JarredH
JarredH's Avatar
Drives: Scion frs
Originally Posted by Jive Turkey View Post
you should not get tires that aggressive for the street, especially if you don't have a lot of seat time. you're better off with a v12 category of tire. please don't buy tires for a certain tread look.
because your offset is low you should go no wider than 255/35, especially if you go with the type of tire you describe, most run wide, and if you want to not rub, without running crazy camber and actually have a somewhat okay handling car.
Do you think i'll need a fender roll knowing my offset? had the direzza zii priced at $1300 in Canada.
JarredH is offline   Reply With Quote
Old 01-08-2015, 07:31 PM   #1119
texasbound972
USMC
texasbound972's Avatar
Drives: 2013 FR-S 6-MT Raven
Took a ride in Crawfords BRZ today and holy shit! We went sideways a couple of times lol. I asked Quirts son and he said the car is at 25 psi. Not sure if that's what I'm gonna be at. Changed my mind from r888 to falken azenis 275's. Getting fenders rolled as well. Here's my build.
http://www.ft86club.com/forums/showthread.php?t=76832
texasbound972 is offline   Reply With Quote
Old 01-08-2015, 09:53 PM   #1120
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
Yeah i don't have any idea what that would be if I didn't know the turbo. Plus 600. Ft lb of torque with even higher hp would spin you around, not just get sideways.
Winter Tire Review Thread (Please contribute) pastuch Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 344 03-13-2024 05:49 PM
Wheel Directory: Forgestar F14 18x8.5 +38/18x9.5 +38 ScionFR-S Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 97 09-09-2015 06:32 PM
Meaty rubber on flush spoke rims? red_comet Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 16 06-14-2013 12:21 PM
Official wheel/tire fitment thread needed empower-auto Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 06-22-2012 01:40 AM
The Wheel and Tire Fitting Thread EvoFanatic Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 03-15-2012 03:05 PM
