Old 05-11-2012, 07:40 AM   #1
Blaaaack-BRZ
Drives: 2013 BRZ Limited
Cusco Rear Diff. Jewelry
http://www.facebook.com/#!/media/set...8312172&type=1
Blaaaack-BRZ is offline   Reply With Quote
Old 05-11-2012, 08:24 AM   #2
old greg
Rocket Surgeon
Drives: PSM GGA OMG
old greg is offline   Reply With Quote
Old 05-11-2012, 09:12 AM   #3
ESBjiujitsu
MUST HAVE MORE 86 ! ! !
ESBjiujitsu's Avatar
Drives: Mazdaspeed 6 2.3 AWD Turbo
me likey the cusco blue!!!!!
WISH LIST: Whiteout FRS- Bronze 18' race rims, Cooper Zeon RS3-S tires,
Cusco Coilovers, Cusco 6 point cage, CF Lip spoiler, CF F1 Mirrors, HKS GT-86 SC
92 carmy -> 86 corolla-> Honda S2000 -> Audi TT -> Mazdaspeed6 -> NEXT UP TOYOTA FT-86!!!!
ESBjiujitsu is offline   Reply With Quote
Old 05-11-2012, 09:23 AM   #4
70NYD
70NYD's Avatar
Drives: RX8 S1
I don't get it? What is it supposed to do?
70NYD is offline   Reply With Quote
Old 05-11-2012, 09:29 AM   #5
MattR
Running in the 90s
MattR's Avatar
Drives: 2014 Scion FR-S Monogram
From what I can gather via a poor Google translation, it is supposed to help dissipate heat generated by the diff better (heatsink fins) and possibly hold more fluid.
From http://minkara.carview.co.jp/userid/...blog/26435400/
"Up Def cover capacity differential oil effective for sports driving, such as ① Circuit!  500cc up the capacity of the oil   (from the Service Manual) 0.05 l 1.15 l ± genuine  ± 0.05 l 1.7 l capacity after installing the cover-up def → cooling capacity up by air-cooling fin"
MattR is offline   Reply With Quote
Old 05-11-2012, 09:30 AM   #6
OrbitalEllipses
Drives: Attitude
Bling.
Old 05-11-2012, 09:49 AM   #7
old greg
Rocket Surgeon
Drives: PSM GGA OMG
Something completely unnecessary.
Rear end ring and pinion gear sets are what are known as Hypoid gears, which involve quite a bit of sliding between the faces of the meshing teeth. This creates heat from friction which raises the temperature of the gear oil. The more power you're putting through the diff the more heat is created, and the hotter the oil gets the less it lubricates which leads to more heat, wear and premature failures. That's why you'll see differential oil coolers on high horsepower race cars. The fins on this diff cover increase the surface area which would mean improved cooling and by extension lower diff temps and less wear.
The thing is, though, the stock diff is totally overbuilt for the meager 200hp the car is making. Diff temp will not even remotely be an issue, even if you were racing at the 25 hours of Thunderhill. If you were to turbo your car and regularly take it to track it might be a worthwhile mod. Otherwise, it's just a shiny blue bauble.
Old 05-11-2012, 10:29 AM   #8
Ryephile
Hot Dog
Ryephile's Avatar
Drives: quicker than arghx7
The diff was designed for a heavier car with more power. Diff temps shouldn't even be on the radar yet, though good dataloggers will record it anyway to find out at which power and race duration level it'll be relevant to regulate the temp.
"Wisdom is a not a function of age, but a function of experience."
Just Say No to unqualified aftermarket products.
Ryephile is offline   Reply With Quote
Old 05-11-2012, 10:39 AM   #9
70NYD
70NYD's Avatar
Drives: RX8 S1
Sorry I meant what the hell is the purpose of this? I get how diffs work, And am fairly familiar with tribology, what I don't get is how they can just manufacture something like this which obviously needs extensive testing to make properly. If anything, this can, on a daily application, overcool the lubricant leading to premature failures
Old 05-11-2012, 11:07 AM   #10
Ryephile
Hot Dog
Ryephile's Avatar
^^This is why so many aftermarket products are "buyer beware". IME you should only be changing component specification for items that need improvement, otherwise you risk creating problems for yourself.
Old 05-11-2012, 11:34 AM   #11
djdnz
1337
Drives: 2013 BRZ WRB S/C
You'll have more headaches with this than anything. This is similar to decorative valve covers, my friend installed some on his Mustang and they have been leaking slightly ever since. What a pain.
Pass on this.
djdnz is offline   Reply With Quote
Old 05-11-2012, 07:52 PM   #12
jkonquer
Drives: 2005 Subaru STI
i wonder how hard it is to torque down the top bolt.
jkonquer is offline   Reply With Quote
Old 05-11-2012, 08:09 PM   #13
Godzilla35
Drives: Nissan GT-R
^^This is what is kind of scaring me about the FRS / BRZ / GT86 tuning parts done so far. A lot of it seems a bit... rushed? I really hope these big name companies are actually doing the R&D on a new car like this, especially with suspension geometry... and NOT just doing "what they normally do" or "what's worked in the past". I have friends in the engineering field, and a lot of them say that if it's true most of the time, this case is probably no different... but I just get the feeling this car isn't as "inexpensive" as it seems in the long run.
Godzilla35 is offline   Reply With Quote
Old 05-11-2012, 08:36 PM   #14
SkullWorks
Drives: SSM LT MT BRZ
how long do you think it takes to design a diff cover and produce it?
I make 1 off Oil pans and Trans Pans all the time, if you want cooling you simply add surface area, how much is usually limited by design not desire. you are not going to "over cool" diff fluid, it doesn't have to get pumped so the system pressure never comes into play.
is this a necessary product for the car on this date? um negative, I can only think of about 3 cars I have seen that need this and I'm fairly sure none are running the stock diff, however, as soon as someone wants to put this car on the track with R-Comps (as cusco has been doing for months) they are going to start seeing diff fluid come out of the overflow tube, especially with longer than 20-30 minute sessions.
If you happen to be running the Cusco Clutch type LSD, and are tracking your car this will become quite necessary
however...haters gonna hate, so continue on without thinking please
Cusco Parts Announced JSC Speed Scion FR-S / Toyota 86 GT86 General Forum 46 04-13-2012 04:13 PM
CUSCO PRODUCTS groupb Brakes, Suspension, Chassis 7 04-06-2012 06:23 PM
Sexy Cusco Parts gdi2290 BRZ First-Gen (2012+) — General Topics 47 04-01-2012 01:35 PM
New Product Releases from Cusco for the 86 and BR-Z. toxicdrift Suspension | Chassis | Brakes -- Sponsored by 949 Racing 2 02-02-2012 02:27 PM
Gearing Options and Diff options airboy808 Engine, Exhaust, Transmission 26 12-25-2011 01:11 PM
