Old 01-07-2015, 12:23 PM   #43
iLaw
iLaw's Avatar
Drives: 2015 BRZ, Aozora Edition
For those running 25mm spacers or wider, did you need extended studs?
iLaw
2020 Subaru Crosstrek Sport
2015 Subaru BRZ Aozora Edition (Sold)
iLaw is offline   Reply With Quote
Old 01-07-2015, 12:26 PM   #44
cameronjones239
cameronjones239's Avatar
Drives: 2015 Subaru BRZ Series Blue
I'm running 25mm all the way around and used stock studs. Go 20 in the front if you can. My front wheels throw debris all over the side of my car. Worse than I thought it would. I may end up taking them off for awhile until I get some paint protection or mud flaps. I like the handling on the pro kit a lot better without them, just doesn't look as good.
cameronjones239 is offline   Reply With Quote
Old 01-07-2015, 12:48 PM   #45
2point0
2point0's Avatar
Drives: '13 BRZ Ltd WRB
Bolt-on spacers don't need extended studs (they'd get in the way), and that would be a huge spacer to not bolt on. They need to be thick enough to cover the existing studs, then you mount your wheels to the studs pressed into the spacer itself.
You'd use extended studs if you're planning to use slip-on spacers over 5mm or so, to ensure that you get enough available thread to spread the load of the lug nuts being torqued.
I'm not sure how wide is too wide when it comes to spacers over extended studs, but I would think it'd be best to keep it minimal still. Maybe that's where the slop comes from that someone else mentioned.
2013 BRZ Limited - SOLD
2008 Forester XT Sports
1967 Mustang Coupe - 289 V8
2point0 is offline   Reply With Quote
Old 04-03-2015, 09:13 PM   #46
iLaw
iLaw's Avatar
Thank you to everyone who contributed to this thread. As a result of everyone's input, I finally settled on 20mm spacers for the front and 25mm spacers for the rear. Coupled with Eibach Sportline Springs (and a few other suspension mods), I got the exact look and stance I wanted.
Here are the results:
And final stance photos:
iLaw
The Following 8 Users Say Thank You to iLaw For This Useful Post:
Adox (07-03-2016), Aozora.BRZ (04-12-2015), CarzCarzCarz (04-13-2016), golemslord (08-02-2016), JDM4E (05-20-2017), MGPAX (07-12-2015), MokSpeed (04-07-2015), Mr.Impreza (10-12-2016)
Old 04-07-2015, 04:13 PM   #47
MokSpeed
Granny Shifter
MokSpeed's Avatar
Drives: 2014 FR-S
This is very similar to the stance I'm looking for from my car. What are the specs of the Blue series wheels? Are they 17x7 as well?
MokSpeed is offline   Reply With Quote
Old 04-07-2015, 04:18 PM   #48
continuecrushing
continuecrushing's Avatar
Drives: 2013 Firestorm FRS
blue series wheels are 17x7!
Old 04-12-2015, 01:53 PM   #49
Aozora.BRZ
Aozora.BRZ's Avatar
Drives: '15 WRB Series.Blue
Thumbs up
Awesome. Thanks for the great images. Just what I am looking for.
Aozora.BRZ is offline   Reply With Quote
Old 08-27-2017, 12:33 PM   #50
HamburgerSushi
Drives: 2017 Subaru BRZ 6MT, Perf Pack
[ame="https://www.youtube.com/watch?v=gk1qbB6MGyM&t=364s"]Are Wheel Spacers Safe? - YouTube[/ame]
[ame="https://www.youtube.com/watch?v=hWijfooeSyU"]Wheel Spacers & Adapters - Good Or Bad? - YouTube[/ame]
[ame="https://www.youtube.com/watch?v=j8CCFF3kJPc"]Benefit Of Wheel Spacers On A Subaru BRZ - YouTube[/ame]
Some great videos to understand the effects of wheel spacers
The increase in track is a small benefit, the downsides are:
- Softer spring rate effective at the wheel
- Increased wear on the wheel bearings
- Change in geometry causing a shift in scrub radius outward
...and there are more...
HamburgerSushi is offline   Reply With Quote
what bushing should i get for better handling nearvincent Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 10-15-2014 04:26 PM
Guys, would you say our FRS's handling is same or better than BMW's? 2082FRS FR-S / BRZ vs.... 125 06-05-2014 11:30 PM
Best handling car? gt8613 FR-S / BRZ vs.... 154 10-07-2013 09:57 PM
Best handling IS ever ! All real footages Whitigir Other Vehicles & General Automotive Discussions 0 06-17-2013 08:12 AM
A Testimony To The FR-S's Handling skoodge Scion FR-S / Toyota 86 GT86 General Forum 25 06-08-2012 06:36 AM
