Old 01-06-2015, 06:33 PM   #9339
Young_makaveli
Young_makaveli's Avatar
Drives: 2013 frs
Originally Posted by lukey86 View Post
There's a type of actuator inside the pulley (not sure what you would call it) that can activate and deactivate the a/c pump to start and end duty cycles, with the a/c on you'll hear a click and the pulley will re-engage itself when the system needs more cool air.
The mechanics of it is pretty cool really
Yeah you're right ..I just checked it again and it goes on and off
Thanks everyone for the help
Young_makaveli is offline   Reply With Quote
Old 01-06-2015, 06:59 PM   #9340
This also is the cause of the "idle fluctuation" that a lot of new owners are worried about. (not to be confused with the early run cars that actually had an ecu problem)
Old 01-06-2015, 07:02 PM   #9341
Young_makaveli
Drives: 2013 frs
Yes I also noticed the rpm fluctuation every time the ac compressor would engage
Old 01-06-2015, 07:03 PM   #9342
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
For future reference its called an "electromagnetic clutch" basically add an electric charge the pulley is connected directly to the compressor shaft. When I was little I thought i could use that tech to make a mad max supercharger lol
The Following 3 Users Say Thank You to FRSBRZGT86FAN For This Useful Post:
lukey86 (01-06-2015), Tcoat (01-06-2015), Young_makaveli (01-06-2015)
Old 01-06-2015, 07:03 PM   #9343
Originally Posted by iStanley View Post
DON'T YOU DARE. WE WILL SUCEED FROM THE NATION AGAIN IF WE HAVE TO.
Didn't go well the first time if I recall.
Besides what ever happened to "southern hospitality"?
Old 01-06-2015, 07:09 PM   #9344
lukey86
Built Not Bought
lukey86's Avatar
Drives: 2012 Toyota 86 ZN6
Duly noted! Thanks!
lukey86 is offline   Reply With Quote
Old 01-06-2015, 07:27 PM   #9345
Quentin
Drives: ‘16 4Runner, ‘19 Corolla HB
FUCK YOU. WE DON'T PLACE 50TH IN EDUCATION FOR NOTHING!
Edit: Turns out we are actually 51st place when they include DC. Smh... http://www.alec.org/state-education-...carolina-last/
Explains Lindsey Graham.
Sent from Tandy 400
Quentin is offline   Reply With Quote
Old 01-06-2015, 07:30 PM   #9346
iStanley
They call me Stan
iStanley's Avatar
Drives: Firestorm FR-S
Sent from Tandy 400
Nothing good ever comes out of SC...Except iced tea...
iStanley is offline   Reply With Quote
Old 01-06-2015, 07:31 PM   #9347
Young_makaveli
Drives: 2013 frs
Might be a dumb question but how come it engages and stops and not just keeps staying engaged when the ac is on?
I remember on other cars once you would turn on the ac ..The ac compressor would be engaged til you turned it off.
Thanks for all the info guys
Old 01-06-2015, 09:12 PM   #9348
wtrxprs007
wtrxprs007's Avatar
Drives: 2006 Toyota Prado 4.0V6
Me thinks it's for the good reason of saving fuel and not waste engine power when it's not needed. It automatically disengages when the temperature sensors in the system say "ok this is good enough, you can have a break now, mr. AC" and re-engages again when it's "not good enough".
Think that's the best explanation I can give right now lol
wtrxprs007 is offline   Reply With Quote
The Following User Says Thank You to wtrxprs007 For This Useful Post:
Young_makaveli (01-07-2015)
Old 01-06-2015, 10:08 PM   #9349
FRSBRZGT86FAN
^ That's one of the reasons and it is also because moisture/condensation buildup tends to freeze a bit on the evaporator, so when it continues to buildup it has a chance to drain off as the system defrosts a bit. If it click on off on off on off repeatedly really fast then that means there's a charge issue (not our case).
The Following User Says Thank You to FRSBRZGT86FAN For This Useful Post:
Old 01-07-2015, 12:15 AM   #9350
twag4
Drives: frs
Not today, about three weeks ago. Changed the stock appearance to new wheels and ride height. Didn't like the supplied stickers for center caps, so I found these stickers on ebay. This all looks so much better in person than in a photo. Depth and color perception are so much better in real life. Anyway, I'm very please with how it turned out.
twag4 is offline   Reply With Quote
The Following 3 Users Say Thank You to twag4 For This Useful Post:
Demandred7 (01-07-2015), Lonewolf (01-07-2015), Quentin (01-07-2015)
Old 01-07-2015, 12:31 AM   #9351
wtrxprs007
wtrxprs007's Avatar
Looks awesome mate
twag4 (01-07-2015)
Old 01-07-2015, 01:36 AM   #9352
Young_makaveli
Drives: 2013 frs
Yeah i see
the ac was on but it would engage for only a few seconds and stop and then engage again for a few seconds and so on
Is that a good thing ?
By the way I really appreciate the feedback as I'm trying to learn as much as I can
Thanks everybody
