Sam Strano
Old 01-06-2015, 06:37 PM   #2017
renfield90
The Stig's German cousin
Originally Posted by AustinTX View Post
I stuffed a small chunk of foam in the hole at the floorboard to shut it up - definitely falls under 'comfort and convenience'.
Protest! A car's annoyance factor is part of its competitive makeup, obvs.
Old 01-06-2015, 06:43 PM   #2018
AustinTX
Pawn in game of life
AustinTX's Avatar
Drives: 19 STX BRZzz
Shock talk - Thoughts on the non-remote 2-way MCS's? They're $1000 cheaper than the remote canister ones.
Autocross nut
AustinTX is offline   Reply With Quote
Old 01-06-2015, 06:55 PM   #2019
bslate3
Drives: 2015 CWP BRZ
Originally Posted by SeanRTR View Post
I have called and confirmed that these wheels are in stock and ready to ship at Buddy Club USA: in both White and Gunmetal
The red outline stripe wheels are not in stock.
17x7
5x100
+48mm
18lbs each
These are a great option for stock class if you haven't bought wheels yet, and don't want to spend the coin for RPF-1's, that seem to bend easily (I've bent 4/8 Enkei's that I have)
send me a PM and I can hook you up with a vendor to buy these through for a great price, and also a vendor that supports the FT86 forum/community.
BC01-SF177048510-G
BC01-SF177048510-W
So they no longer carry the 17x7 +42? That's the one I really wanted to get. Plus I actually like the black with red stripe. Reminds me of Time Attack wheels.
bslate3 is offline   Reply With Quote
Old 01-06-2015, 09:50 PM   #2020
bimmer635csi
bimmer635csi's Avatar
Drives: 2013 Cayenne turbo
If you have the ability to tune the dampers, the remote canisters give you a gas pressure adjustment that the non-remotes don't seem to have.
I wouldn't know what to do with that as an adjustment, so I'd opt for the non-remotes personally.
bimmer635csi is offline   Reply With Quote
Old 01-07-2015, 07:42 AM   #2021
OkieSnuffBox
Drives: '23 BRZ Limited
Good stuff.
And if you order directly from Maxcy, he will setup a custom spring rate/valving profile for no extra cost vs buying them from somewhere like Vorshlag.
Old 01-07-2015, 10:50 AM   #2022
qoncept
qoncept's Avatar
Here's a question.. If I have absolutely no ability to tune dampers (after 15 years of autox and reading), is there any reason at all for me to replace my struts?
In my WRX I had a handful of different setups and finally used STi takeoffs, which were the cheapest and made me the fastest. I'm not sure many of you will "get it" but handling is a complete mystery to me. In the BRZ I can't put a finger on what I think the car should be/is/isn't/feels/want/whatever. My best guess at the moment is that it oversteers on turn-in and pushes midcorner but I couldn't swear by that.
qoncept is offline   Reply With Quote
Old 01-07-2015, 10:57 AM   #2023
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
high end dampers make the car feel more connected and inspire confidence.
they absorb the road imperfections instead of transferring it to your backside
if there is a bump or some sort of element which upsets the car, you will traditionally have two types of drivers, those that will adjust their entry to minimize the upset, and those that get ready for the car to get upset and then control whatever happens next
then you have guys with dialed in suspension who will just drive over that bump and not even realize it's there.
Old 01-07-2015, 11:21 AM   #2024
qoncept
qoncept's Avatar
I assume "high end dampers" means something better than Konis..? I probably won't be buying struts any time soon.
Old 01-07-2015, 11:25 AM   #2025
chucky12012
Drives: 2013 Asphalt Scion FR-S
Originally Posted by Arigh View Post
I'm going to be on ZII's for the foreseeable future, as I DD on my autocross tires. I don't want to DD a 245 tire, and have heard less positive things about the rain performance of RS3's.
I will be going with 235/40 Star Specs too. I just have never come around on the RS3's personally.
chucky12012 is offline   Reply With Quote
The Following User Says Thank You to chucky12012 For This Useful Post:
Shark_Bait88 (01-07-2015)
Old 01-07-2015, 11:33 AM   #2026
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
yes
remember that dampers are a wear/tear item. You should budget a replacement at some point anyway, might as well make it an investment. (unless you plan to sell the car then just get something like KYB GR2 lol)
The Following User Says Thank You to 7thgear For This Useful Post:
qoncept (01-07-2015)
Old 01-07-2015, 01:21 PM   #2027
VADERR
Completely Lost
VADERR's Avatar
Drives: 2015 CBS BRZ Limited
So do people normally run the B6 or B8?
VADERR is offline   Reply With Quote
Old 01-07-2015, 01:35 PM   #2028
bholliday
Drives: 2022 BRZ Premium
I believe B8's have lower spring perches than stock for use with lowering springs, so would not be legal for stock without modifications to raise the spring mounting point.
bholliday is offline   Reply With Quote
The Following User Says Thank You to bholliday For This Useful Post:
VADERR (01-07-2015)
Old 01-07-2015, 02:10 PM   #2029
bholliday
Originally Posted by cdrazic93 View Post
the replacement performance dampers are very limited, as just Koni and Bilstein make them. The B6 vs B8 is literally only a difference in spring height you wish to use (damping is the same). Even that is subject to debate, with the B6's being cheaper, I'd go with those. IF you prefer adjustable dampers, than Koni no brainer.
There is some additional discussion of the Bilstein B6 and B8 in the thread referenced above. I am considering revalving Bilstein B6's for my car for CS. However, I am also still considering STX
Old 01-07-2015, 02:18 PM   #2030
G_Ride
G_Ride's Avatar
Drives: Some kind of Subaru
Where I used to live I had the RS3 V2 and had a codriver. My codriver and I liked the tire. Since I moved somewhere a little colder, has more rain, and I don't have a codriver I'll probably go with the star specs for this season. I may wait to see what other new tires become available as well.
G_Ride is offline   Reply With Quote
The Following User Says Thank You to G_Ride For This Useful Post:
Cinco De Mayo SCCA SOLO Ryeong86 NY / NJ / CT / PA 0 04-23-2013 05:22 PM
Koni Sports in SCCA SOLO Ryeong86 Tracking / Autocross / HPDE / Drifting 4 04-22-2013 12:58 PM
2013 Preliminary SCCA SOLO and PRO SOLO National Schedule Scooby South Tracking / Autocross / HPDE / Drifting 13 12-05-2012 08:08 AM
Houston SCCA Solo #9 - 5 FRS, 1 BRZ hankster Tracking / Autocross / HPDE / Drifting 0 10-09-2012 01:35 PM
SCCA Solo Car Class for the FR-S/BRZ? MrVito Scion FR-S / Toyota 86 GT86 General Forum 31 06-15-2012 10:03 AM
