#1401 |
in orbe terrum non visi
Drives: violent
No. Message me on FB if you're curious. A shop did something similar on here and I don't want people asking me about it until I've built one and proven it works.
I have E85 where there isn't E85, that's my secret.
http://www.ft86club.com/forums/showt...t=reaper+build |
| The Following 3 Users Say Thank You to Reaper For This Useful Post: |
#1402 |
TEQSPORT Brand Manager
Drives: '24 GR86 + '16 FR-S
Buttoned everything up, reinstalled the bumper and brought the car home with everything done except the splitter install. Feels good to have fresh engine and gear oil along with fresh coolant in a big ass radiator and low temp thermostat. Also washed and reoiled the K&N air filter. Running smoother than ever.
![]() I installed the support rod brackets to the crash beam and installed the downforce vanes to the bottom of the splitter. ![]() The radiator and low temp thermostat are definitely doing their jobs. I haven't hooked up my OBD2 adapter to Torque yet but the car previously always ran at the dead center of the coolant temp gauge and now it's running barely above the first notch fully warmed up. This should make a big difference on track in the middle of summer. ![]()
| The Following 3 Users Say Thank You to ATL BRZ For This Useful Post: |
#1403 |
Drives: 2013 WRB Subaru BRZ Ltd.
Hey Ian!
Did the lip spoiler come painted? I guess i wouldnt be able to get it in WRB eh?
#1405 |
NASA SpecE30 Racer
Want to elaborate? I used the Subaru recommended for all motors other than the FA20 Fuji Bond to reinstall my oil pan, and I never had any leaks.
- King Tut
Street/Track Car: 2006 Honda S2000 TT3 || Race Car: 1987 BMW 325is SpecE30 || Tow Vehicle: 2014 RAM 1500 EcoDiesel Sold Cars: 2012 BMW M3 || 2013 Subaru BRZ || 2012 Porsche Cayman R || 2009 Chevrolet Z06 || 2009 BMW M3 || 2004 BMW M3 || 2004 Nissan 350Z |
#1406 | |
NASA SpecE30 Racer
- King Tut
#1407 | |||
I'm just going off of others experiences with pressures who have fitted a sensor in the block and logged it on track. ( @Dave-ROR , @Element Tuning , @Dezoris ) I've switched to 30 weight oil to keep pressures up with the oil cooler as Dave has experimented, but aside from that I'm not even sure I'm having issues with oiling as-is, but I'm always willing to make sure it stays safe should I go FI and/or start running R Comps. More reasons baffling the lower pan seems to be moot... from another related thread: Quote:
| The Following 2 Users Say Thank You to ATL BRZ For This Useful Post: | chanomatik (01-06-2015), Hyper4mance2k (03-10-2015) |
#1408 | |
30wt is fine for NA and street tires up to about 245F. With oil cooler you should hover there near the end of 20 minute session. 40WT if you see a ton of heat, and agressive tuning or running SC. If you are setting up a car like Element tuning in competitive setting with high lateral gforce and Rcomps with higher HP you are talking custom setup. Oil WT wont be enough. Thats partly why I parted ways with car. Going from conservative to racey/competitive is too much of an investment on a street car for my tastes. (Rather start with platform with proper cooling and oiling from factory next time)
#1409 | |
![]() Are you going to say S2000? or C7 Z51? |
| The Following User Says Thank You to ATL BRZ For This Useful Post: | chanomatik (01-06-2015) |
#1410 |
NASA SpecE30 Racer
The S2000 doesn't have the greatest cooling system either. I would say the C5 Z06 is probably the answer when Miata isn't.
- King Tut
| The Following User Says Thank You to King Tut For This Useful Post: | Reaper (01-06-2015) |
#1411 | |
Gonna be unloading S2000 too. Honestly not quite sure, its either going back to Rotax (Which makes most sense for me), C7, or just some actual track toy like Atom3.
| The Following 2 Users Say Thank You to Dezoris For This Useful Post: | ATL BRZ (01-06-2015), chanomatik (01-06-2015) |
#1412 |
Installed the splitter and a pair of tow hooks that I got used from a forum member for $40
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() It works. Really well. So well in fact that the car ended up throwing a CEL on the way home for coolant temp. ![]() I cleared it and got home fine but I think I may possibly to have @moto-mike adjust minimum values in the tune files I have to keep the CEL from triggering in the future. The splitter works REALLY well. Had it up to highway speeds and the car definitely felt more planted in front. Looking forward to having it out at Road Atlanta next month. Last edited by ATL BRZ; 01-18-2015 at 11:09 PM. |
#1413 |
Drives: 13 GBS BRZ
Form follows function right here. Gorgeous!
| The Following User Says Thank You to Porcupint For This Useful Post: | ATL BRZ (01-10-2015) |
#1414 |
Drives: '22 BRZ
Good thing you don't drive up, your car would barely get up to temp
![]() Looks killer dude! I flew over Road Atlanta on Monday. So envious of it being so close to you! |
| The Following User Says Thank You to DocWalt For This Useful Post: | ATL BRZ (01-11-2015) |
| Tags |
| jdl turbo, mazworx, racecomp engineering, track build, verus engineering |
| Wnt3d's 86 - Turbo E85 Daily/Track Build | wnt3d | Member's Car Journals | 77 | 07-17-2017 03:35 PM |
| No Limit Motorsport Full Blown BRZ Build | No Limit Motorsport | Member's Car Journals | 16 | 07-08-2014 12:46 PM |
