Old 01-03-2015, 04:08 PM   #15
Xinshadow
Drives: 2013 Scion FR-S Ultramarine
Originally Posted by Jman1759 View Post
Honestly I have done what you are listing and its just not worth it. You are going to spend 50-75% of the cost for a used supercharger kit and get 20% of the power. Save your money up and buy a used supercharger kit. You can get them on here with everything you need for less than $4k pretty regularly.
Why not do both? I did all the mods the OP suggested and more in preparation for supercharging next year when the car is paid off. The factory header is still pretty weaksauce, and better flow is even more important with FI. In the meantime, I get to enjoy having about 200WHP on tap, which is pretty fun in such a light weight car. As long as he doesn't do a full intake/strut brace ect, these mods should work fine with a SC down the road.
Current mods: OFT Stage 2 (w/93 oct), OFH, Perrin Resonated catback, DSS Aluminum Driveshaft, Perrin drop-in filter, Avo silicone inlet, Mishimoto catch can, Grimmspeed MCB, Perrin crank pulley, Nameless overpipe/downpipe combo, DBA slotted rotors, Ferrodo brake pads, goodrich SS brake lines, DOT5 synthetic brake fluid.
Xinshadow is offline   Reply With Quote
Old 01-03-2015, 04:13 PM   #16
Cop
Cop's Avatar
Drives: 2013 FRS
Originally Posted by speeddemon View Post
First post on the forum! I don't even have my FRS yet, waiting on my current car to run out of life (so I'm driving it a little harder than I should admittedly) but I am already anxious to start my mod projects. I want to have some fun DIY bolt on stuff and feel a noticable difference in power to feel as if something was accomplished but do not want to spend a forture (ie going FI).
I have read alot on this forum and it seems like for the bang for your buck, I should start with headers; most likely Tomei. For some increased sound and flow I was thinking about just doing the axle back. At the same time as the headers I would go with a OFT stage 2 tune and a drop in filter probably HKS.
How does this plan of action sound to the guys out there who have been there done that?
Sounds like you've done some research already, welcome to the forum . I've done what you've listed as far as mods go with a few additions (see my sig for a list) and can give you my thoughts. I can tell you that while those mods make a noticeable improvement over stock, if you ever want to go FI you might as well just save for that. Best bang for your buck is probably 1. OFT, 2. header, 3. intake IMO. I've used two filters in the past (Blitz and K&N) but have switched over to the GrimmSpeed intake which is a nice upgrade. I would hold back on the exhaust until after you get the header, no real performance benefit from just getting a catback and it might be pretty loud depending on which exhaust you go with.
This is a really good point. Amateur question here..there is a cat in the headers and downpipe on the stock exhaust? If that's the case if you go to catless headers then it will throw a code is that right? If you do have catless headers will you still be alright with emissions testing? I know you are NJ and I'm PA so i'm not sure the differences in the law specifics.
If you have the OFT tune you will not get a CEL.
Cop is offline   Reply With Quote
The Following User Says Thank You to Cop For This Useful Post:
Kuri (01-20-2015)
Old 01-03-2015, 09:32 PM   #17
jflogerzi
jflogerzi's Avatar
Op your mods are the best bang for your buck for bolt ons for power. Nothing else is need. Welcome. Its refreshing to see someone did some research before posting.
2013 Series 10 FRS #553
Old 01-03-2015, 10:27 PM   #18
weederr33
Airborne at your service
weederr33's Avatar
Drives: '17 BRZ Series.Yellow
I like where you're going. Sounds like a thought out process! Welcome!
Old 01-04-2015, 10:47 PM   #19
Choob
Choob's Avatar
Drives: 2013 Firestorm MT, 2004 Celica Gt
I did everything op just posted im running a OFT Stage 2 tune and have tomei uel and overpipe full invidia exhaust and hks drop in filter. The OFT is the simple most effective mod you can do, if you want to get your hands dirty I would get an exhaust and install
Choob is offline   Reply With Quote
Old 01-05-2015, 11:51 AM   #20
speeddemon
Drives: Scion frs
I don't know how to "thank" people on this forum yet lol, but I appreciate all the input. It sounds like I am on the right track!
speeddemon is offline   Reply With Quote
Old 01-05-2015, 12:32 PM   #21
RobertPaulson
Hisnamewasrobertpaulson
RobertPaulson's Avatar
Drives: 2017 Golf R
Why ??
For NA guys with basic mods they represent good value. You get probably 90% plus of possible gains for far less cost and hassle, especially for people not located near a reputable tune shop.
Even for FI , Ecutek/OFT ect guys are offering OTS tunes for FI kits
Every car is going to be a bit different because of mods, ambient weather conditions and some other factors. a OTS tunes hopes to be able to cover all this but the reality is they just can't, OTS tunes are also notorious at just leaning the car out to make more power and can cause issues and ruin drive-ability.
I had someone local to me test out OFT and after 2 weeks he returned it, he said his car drove worse, got a CEL for running lean and the minimal power increase wasn't worth it.
This is your life and it's ending one minute at a time.
RobertPaulson is offline   Reply With Quote
The Following 2 Users Say Thank You to RobertPaulson For This Useful Post:
DarkSunrise (01-05-2015), Kuri (01-20-2015)
Old 01-05-2015, 12:32 PM   #22
Koa
Originally Posted by RobertPaulson View Post
i would never recommend an off the shelf tune for anyone.
The off the shelf OFT 91 oct UEL stg 2 v2.xx + OFH + Grimmspeed Intake, for me, has:
- no knock
- LTFT's floating around 1-1.5% in closed loop, 0% in open
- AFRs in the appropriate scale that match command afr
- Very smooth response, operation
Don't know why you're so dead set against OTS tunes for bolt on NA, or even some mild FI applications... but I've been running OTS and slightly tweaked OTS tunes across platforms for years since opensource became popular for the subaru EJ series engines onto this one... with very nice results. I know YMMV but it's consistent feedback that OTS tunes satisfy a majority of users' needs even considering environmental and set-up differences.
Your friend's experience with OFT is an odd one. What mods was he running? E85? Why so lean, when the OTS OFT tunes by and large run on the rich side?
Old 01-05-2015, 12:40 PM   #23
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
Huh? This is far from the truth.
Shiv@Openflash is offline   Reply With Quote
Old 01-05-2015, 01:08 PM   #24
Xinshadow
Years ago with less reputable tuners (think TempleofVtec) this was true, but these days not so much.
Weather does seem to be a weird sticking point for people in regard to tunes, as if using the OFT also means you have to lop off your thermostat and pray to Vin Diesel that winter temps don't blow the welds on your intake.
As someone who is now in his 2nd year in below zero weather with OFT stage 2, I can tell you that the car runs better in the cold and the hot than it ever did on the factory tune. Smoother, more stable AFRs and no knock correction.
That said I might contact Shiv for a custom tune this summer, but that's only because I think there's a little more power on the table, not because the car isn't running like a champ.
Old 01-05-2015, 03:59 PM   #25
tennisfreak
Drives: 2018 BMW M240i
Here is a thread with someone running an off the shelf tune and having dead spots in the pedal and afr readings way out of whack: http://www.ft86club.com/forums/showthread.php?t=80091
Old 01-05-2015, 04:12 PM   #26
Xinshadow
With what looks like improper MAF scaling just paging through the thread, so I wouldn't jump to attribute it to an OTS tune. Not saying it's not possible, but with 100s (1000s?) of people running these tunes with very very few issues, it's not likely.
Old 01-06-2015, 06:42 AM   #27
steve99
Drives: FT86
If the mods you have match the mods the OTS tune caters for then the differences are minimal if who ever tuned the OTS map did a good job.
The ECU compensates for differences in air temperature, coolant temp, atmospheric pressure (altitude) ect using sensors in the car and programming and tables in ECU. this does not change tuned or untuned
Tuners adjust the tables that adjust the amount of compensation but I don't believe anyone adjusts the way the ECU program uses these tables ie re-writes the actual program instructions.
That OTS tunes "just lean out and offer minimal power increase" is just plain incorrect. 20-30 tables for ignition timing intake/exhaust timings, direct/port injection timing, fueling, maf scaling ect are adjusted in OTS tunes I have seen from Ecutek OFT Cosworth ect.
I would bet your friend that had drivability issues and got a CEL for runnig to lean with an OTS tune had an aftermaket intake not suited to the tune they ran (ie maf scaling would have been incorrect),or an exhaust/intake leak.
Obviously OTS tunes need to be matched to the mods your running on your car and the fuel your using else you going to have problems.
On NA cars the differences are not that great, on FI cars the difference is likely a bit bigger.
On a stock NA car its not like the OTS tune get you 10whp and the dyno tuned car get 30whp.
Its not just the OFT guys doing OTS maps the Ecutek guys are into them in a big way as well.
I have seen OTS tuned cars outperform dyno tuned cars, its more to do with the skill of the tuner.
Sure in the end the individually dynoed car should outperform the OTS tuned car given an equally skilled tuner, but on an NA car the difference can be small but the cost difference quite large.
In the end if your prepared to pay the extra money to get the extra gain then great.
But OTS tunes do represent value when used correctly.
Old 01-06-2015, 06:53 AM   #28
steve99
Drives: FT86
Mate if you read his post he is running a Perrin 3" big maf intake. on a tune designed for a stock intake.
He tried copying in the Perrin supplied scaling and its obviously not correct, he just needs to log and scale his maf correctly.
This would be exactly the same effect if you got your individually dyno tuned car and change the intake from stock to a perrin 3" intake its not going to work either.
The Following 2 Users Say Thank You to steve99 For This Useful Post:
GotBRZ1691 (01-09-2015), tennisfreak (01-06-2015)
hey new here, what mods have you done so far ?? missbrz Scion FR-S / Toyota 86 GT86 General Forum 34 12-25-2013 09:15 PM
4 Mods for under $400... go! Willis85 Scion FR-S / Toyota 86 GT86 General Forum 46 12-10-2013 12:47 AM
What were your first mods? Nourdmrolnmt1 BRZ First-Gen (2012+) — General Topics 42 04-01-2013 02:16 AM
Best Mods for the BRZ TheShiftingChef Engine, Exhaust, Transmission 34 09-08-2012 11:01 PM
