Old 07-20-2014, 11:41 PM   #113
BenArmstrong
BenArmstrong's Avatar
Drives: White GTS, Vortech, Aero kit
Add me in too if you like.
Build Thread here: http://www.ft86club.com/forums/showthread.php?t=30502
Engine:
Vortech Supercharger Kit
Perrin Lightweight Crank Pulley
Perrin Engine Oil Cooler
AVO Air/Oil Separator
Exhaust:
HKS Equal Length, Catted Header
HKS Catless, Stainless Front Pipe
HKS Spec-L System
Perrin Overpipe
Getting a new tune this week so will get back to you with dyno results
BenArmstrong is offline   Reply With Quote
The Following User Says Thank You to BenArmstrong For This Useful Post:
reyruiz191 (07-21-2014)
Old 11-23-2014, 07:00 PM   #114
Jetbill
Drives: 2013 FRS, 2014 BMW 335 M-Sport
Anyone running a conservative E85 tune with a Vortech kit on the standard pulley?
Maybe 30% mix of E85 with some conservative timing increases...
I could imagine if you were logging monitoring fuel trims were acceptable.
Ultimately I'd like to go E85 with upgrading fuel pump, injectors and an inline ECA but I'm looking to do it in stages. It appears the net cost of adding these components will be about $2k.
Anyone have any recommendations or suggestions it would be much appreciated. Currently running full bolt-ons that is tracked for the most part at autox and a DE about every other month.
Jetbill is offline   Reply With Quote
Old 11-25-2014, 10:43 AM   #115
kiichiro
corolla specs/GTR looks
Drives: ooh oooh pretty tail lights
You can DE the e85 and oe vortech all day, its safe as can be, even the 3.33 on a bone stock car is just fine
SOLD THEM BOTH
Hers: 2007 987S
Mine: 2012 991S
That was fun, thanks Hachi
kiichiro is offline   Reply With Quote
Old 11-25-2014, 01:53 PM   #116
Jetbill
Appreciate the feedback.
So you have had good experience with running 100% E85 in the tank on the stock fuel system FI @ more than 10psi?
Old 11-25-2014, 03:49 PM   #117
kiichiro
all day long man, on oe fuel pump and oe injection, I run either 100% gas or 100% e85 or can even run 100% 100octane, and can running the secret sauce tune Perrin made me, i can run any fuel with any pulley, 2.87 to 3.6 without a reflash
I ran the last two days at the track on 100% e85 whih for me was about 77% here in AZ
car made so much power I am slipping my ACT clutch
problem I run into is belt life running the smaller pulley
but I can run full on corn juice and play all day long on the bigger pulleys
SOLD THEM BOTH
Hers: 2007 987S
Mine: 2012 991S
Old 01-04-2015, 05:54 PM   #118
Jman1759
Builder
Drives: 2014 BRZ - World Rally Blue
Hi guys, getting ready to install my kit. I purchased it used from a reputable vendor but the air filter cover doesn't seem to stay on very securely. Has anyone changed out those turn nob deals for something more secure? Surprised I cant find anything in the threads.
Jman1759 is offline   Reply With Quote
Old 01-04-2015, 07:01 PM   #119
Foobar
SLO NO MO
Foobar's Avatar
@charged86 replaced his, but he's moved on to a different platform I believe. None of his pictures are still hosted on the original links he provided.
Originally Posted by charged86 View Post
I pulled out my thumb/ wing fasteners installed new 1/4 speed clip fasteners and chrome plated button heard Allen screw fasteners they hold lid much tighter and look effing sweet. available at LOWES Motorsports. Major thing that bugged me those mickey mouse grandpa wing nuts. first time I saw the kit months ago.
In any case, mine appear to be loose, but they've never given me a problem and have kept the filter on for almost 2 years now.
The Following User Says Thank You to Foobar For This Useful Post:
Jman1759 (01-04-2015)
Old 01-04-2015, 08:17 PM   #120
DJCarbine
Thupercharged
DJCarbine's Avatar
I remember tweaking the nut portion so that the fasteners fit more secure, previous to that sometimes they would vibrate out of position
2013 FRS
Vortech V3 11psi
Revworks UEL - PLM Overpipe - MOTIV catted frontpipe - Invidia Q300
2019 Series.Grey STI - Stage1+ SF
DJCarbine is offline   Reply With Quote
The Following User Says Thank You to DJCarbine For This Useful Post:
Old 01-05-2015, 02:06 PM   #121
charged86
charged86's Avatar
No i had a identity theft issue had to close alot of accounts I am now JDL turbo haven't tuned it yet
INSTAGRAM @Rcf_700 www.youtube.com/boostindub
Old 01-05-2015, 03:04 PM   #122
alexand3r
Custom User Title
alexand3r's Avatar
Drives: Spaceship
I put some extra foam around the perimeter of the door. Closes firmly now.
This stuff:
[ame="http://www.amazon.com/gp/product/B00005202U/ref=oh_aui_detailpage_o03_s00?ie=UTF8&psc=1"]Amazon - Low Density Foam[/ame]
I use it to take care of rattles throughout the car as well.
alexand3r is offline   Reply With Quote
The Following User Says Thank You to alexand3r For This Useful Post:
Jman1759 (01-06-2015)
Old 01-06-2015, 01:02 AM   #123
Jman1759
Builder
This stuff:
Already planning to do something similar, thanks
Old 01-06-2015, 01:08 PM   #124
aquaman
aquaman's Avatar
So from what it sounds is on stock internals and 91 octane with the 3.25in pulley you're going to get about 260-270 WHP? What is the limits of the stock internals? What other SC supporting mods should be done to get the most out of it?
aquaman is offline   Reply With Quote
Old 01-06-2015, 03:40 PM   #125
Foobar
SLO NO MO
Foobar's Avatar
I'd add aftermarket headers as well. As for your second queation, I think we are still learning what power levels the stock internals are good for.
Old 01-06-2015, 10:19 PM   #126
Jman1759
Builder
Hey fellas, I have read your warnings and prepped for my Vortech kit. I have upgraded the radiator, clamped all the hoses, installed catch cans, installed the check valve, and am ready for install this weekend. A couple questions from my reading:
1) some have said they no longer use the AC to reduce stress on the belt. Is this overkill? I live in the PNW and the air is always wet, I am always using the defroster with the AC. Thoughts?
2) some have mentioned this belt also will struggle under regular downshifting. I am a daily driver, no track. Should I start learning how to de-celerate with no downshifting and just invest in extra brake pads? Thoughts?
STX Rules and Setup Questions Scooby South Tracking / Autocross / HPDE / Drifting 3914 07-18-2023 04:16 AM
Questions and Discussion on Vortech Supercharging Systems Brian@Vortech Forced Induction 1462 01-27-2017 02:05 PM
Vortech Offical Owner Thread cjsporl1996 Forced Induction 2 03-27-2014 12:50 AM
Who to tune Vortech setup? pheoxs Forced Induction 18 02-20-2014 02:58 AM
Sprintex or Vortech, which setup has more potential? Turbowned Forced Induction 328 09-14-2013 11:09 AM
