Old 12-28-2014, 05:05 AM   #1051
Amaya
Amaya's Avatar
Drives: 2015 Scion FR-S 6MT
Looking for some second opinions. I want to run Enkei Kojins staggered 17x8/17x9 both with +45mm offsets. I have a set of TRD springs on the way, the rest of the suspension is stock. I'm thinking about Dunlop Direzza ZII's in 245/40R17 front and 255/40R17 rear. I'm pretty sure the wheels will fit fine but I'm not completely sure about the tires.
Amaya is offline   Reply With Quote
Old 12-30-2014, 11:47 PM   #1052
Manji
Toyotas don't have boxers
Manji's Avatar
Drives: GTV86, ISF, TE27
This thread was a great help in seeing how far you can push it without going hellafail.
Manji is offline   Reply With Quote
The Following User Says Thank You to Manji For This Useful Post:
fx35s (01-04-2015)
Old 12-31-2014, 08:46 AM   #1053
Drewfellas
Drives: '15 frs Halo. must scrape
Originally Posted by texasbound972 View Post
Need some help. Want to run the widest tire possible in the rear without too much poke. I'm currently on KW V3's with a Vorschlag top hats. I also want to stick with 17" wheels. Car is currently getting a short block built by Crawford Performance and I didn't get my alignment done due to the engine blowing up the day after the coils were installed.
I hope everything turns out well.
Invidia q300-cusco front strut tower with mbc and rear strut tower- buddy club tail lights
Drewfellas is offline   Reply With Quote
Old 12-31-2014, 10:44 AM   #1054
yomny
yomny's Avatar
Drives: 2013 FRS Whiteout
They'll fit, I have same width wheels and size tires. Im running 2.5 rear camber though and am not slammed just barely a finger gap height.
GTX2867R, moto-tuned , tomei op , motiv fp , Invidia Q300 ti , Rota titan 17x9 +42 , nt555 255/40 , ST coilovers w/cascam , Hotchkis sways
yomny is offline   Reply With Quote
The Following User Says Thank You to yomny For This Useful Post:
Amaya (12-31-2014)
Old 12-31-2014, 03:52 PM   #1055
Amaya
Amaya's Avatar
Is the offset on your wheels the same? I don't want to change the camber. I just want wider tires/wheels as the stock ones look undersized. Personally I don't like the hella flush look. Thanks for your input!
Old 12-31-2014, 04:26 PM   #1056
yomny
yomny's Avatar
My wheels are +42 so I think the fitment will be spot on with your +45 actually a bit better as you won't have any issues at all running with the fenders. Looks lower from a side angle.. but as you may see the camber(2.5) is not noticeable and is far from hella stance junk.. i hate that.
Amaya (12-31-2014)
Old 12-31-2014, 05:24 PM   #1057
Amaya
Amaya's Avatar
Awesome, thank you very much. That looks almost exactly like how I want it to fit.
The Following User Says Thank You to Amaya For This Useful Post:
yomny (12-31-2014)
Old 01-04-2015, 09:04 AM   #1058
BRZ RN
BRZ RN's Avatar
Drives: Blue BRZ
Originally Posted by yohan04 View Post
Haven't took any new pictures but here's some old pictures from last winter-spring.
Enkei RPF1 18 x 9.5, +35
255-35/265-35 Federal RS-R
[/URL]
[/URL]
this is the setup that i'm aiming for very nice. although i'd wish to sport black rpfs someday.
BRZ RN is offline   Reply With Quote
The Following 2 Users Say Thank You to BRZ RN For This Useful Post:
BRZ Stefan (01-04-2015), yohan04 (01-06-2015)
Old 01-04-2015, 09:33 AM   #1059
fx35s
Drives: 2013 Subaru BRZ
How much drop from the stock height is that!?
That's the perfect on spot. My wheels are coming in (17x9 40+) and I'm thinking about Hankook Ventus V12 in 245/40/17 or 255/40/17.
I love them meaty tires!
fx35s is offline   Reply With Quote
Old 01-04-2015, 11:26 AM   #1060
AZbrz89
Drives: 14 BRZ Crystal Black Silica Limited
I want to run enkei raijins 18x9.5 all around with 255/?/? Michelin pilot super sports. I went to discount tire and the sells rep was concerned about clearing 255 in the front. I plan on getting coilovers but will I need lower control arms for the rear? If anyone could chime in, that would be great.
AZbrz89 is offline   Reply With Quote
Old 01-04-2015, 01:27 PM   #1061
Jive Turkey
the tuna, no crust.
Jive Turkey's Avatar
Drives: 2014 Hachiroku of the year
255/35/18
do not need them. what offset.
with coilovers it won't be an issue, stock struts won't clear.
Jive Turkey is offline   Reply With Quote
Old 01-04-2015, 01:45 PM   #1062
texasbound972
USMC
texasbound972's Avatar
Drives: 2013 FR-S 6-MT Raven
Who's running 18x10's and what size tire in the rear?? Pics would be awesome!
texasbound972 is offline   Reply With Quote
Old 01-04-2015, 02:44 PM   #1063
AZbrz89
@Jive Turkey thanks for chiming in, what would you recommend? I have no clue about tires and offset lol
Old 01-04-2015, 02:55 PM   #1064
BRZ Stefan
BRZ Stefan's Avatar
Drives: 2014 Subaru BRZ
The lower the offset, the more the wheel will poke outwards away from the car. The higher the offset, the closer the wheel will be to the strut. For example +20 offset gives you a good amount of poke which means if the car isn't lowered, the wheel will pass the fender and stick out. Whereas +35 or higher is what some people use with camber once the car is lowered on springs or coil overs to get that flush tuck of the wheel underneath the fender. but with wheels that wide, you will need camber to make it fit and possibly spacers. It just depends on what you're going for.
BRZ Stefan is offline   Reply With Quote
The Following User Says Thank You to BRZ Stefan For This Useful Post:
texasbound972 (01-04-2015)
Winter Tire Review Thread (Please contribute) pastuch Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 344 03-13-2024 05:49 PM
Wheel Directory: Forgestar F14 18x8.5 +38/18x9.5 +38 ScionFR-S Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 97 09-09-2015 06:32 PM
Meaty rubber on flush spoke rims? red_comet Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 16 06-14-2013 12:21 PM
Official wheel/tire fitment thread needed empower-auto Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 06-22-2012 01:40 AM
The Wheel and Tire Fitting Thread EvoFanatic Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 03-15-2012 03:05 PM
