Old 06-28-2014, 12:04 PM   #15
paulca
Drives: Toyota GT86 Coupe Red (UK)
Originally Posted by 8 six View Post
I see what you mean, but this noise is coming from the clutch itself only when pressing it down with load on it. If I let the gas go completely before beginning the clutch pedal's journey down, there's no noise. I guess the engagement point is just so high?
I may have miss-understood you, but why would you have the accelerator applied when up-shifting after you put the clutch in? That will just cause clutch wear and increase the RPM adding more syncro wear on the shift and more clutch wear again on release.
Unless you are doing power shifts or hot shifts which will feck your clutch, the only reason to have pedal on when clutching it, is to blip on a downshift or in some big diesels to keep the rpm up as they take too long to rev back up if you change slowly.
If you let the accelerator off too soon though you'll get a forward jolt. The trick is to do both simultaneously, just as you lift off the throttle (completely), slip the clutch. You should already have the shifter "pre-loaded" in the direction of travel required so it will pop out into neutral, into the next gear, then bring the clutch back up to the bite point and apply throttle as you smoothly release the clutch.
Remember... you don't need a clutch to change gear. The syncro's work fine on their own as long as you are passing the correct RPM. Upshifts are therefore the easiest. Just lift your foot off the accelerator with a gently preload on the gear stick. As the transmission passes the "neutral" point with no load the gear will pop out. Immediately offer it to the next gear ups syncro. DO NOT FORCE IT IN! Maintain gentle pressure and as the (falling) rpm passes the correct rpm for the gear it will pop in. Then accelerate. Down shifts are the same, but you either have to rev match, or blip the rpm up above the gear and apply the same technique as upshifts.
paulca is offline   Reply With Quote
Old 11-08-2014, 11:02 PM   #16
scionfrs2014
Drives: Scion FRS
Originally Posted by VenomRush View Post
for mine it almost sounds like a horn, dont know what it is and i havn't got it checked out cuz my car is running fine at 38kmiles now
edit: it doesn't happen all the time, and it has happened from a cold start and when the engine is warm
My car has the same noise. Originally I thought the horn sound was given by someone until I went for a drive on a quiet country road recently. It does not happen all the time. Do you have an update? Many thanks.
scionfrs2014 is offline   Reply With Quote
Old 11-11-2014, 11:15 AM   #17
VenomRush
Thee O-ri-gi-na-tor
VenomRush's Avatar
i dont, but i recently gave a friend a ride and asked him about it and he had mentioned it sounded like the flywheel
VenomRush is offline   Reply With Quote
Old 01-02-2015, 03:13 PM   #18
scionfrs2014
Drives: Scion FRS
It seems that if I fully release my gas peddle before I press clutch, it will be fine. If I release my gas peddle millisecond slower when I press clutch, the horn sound may come out. Just a thought, but still not sure.
The Following User Says Thank You to scionfrs2014 For This Useful Post:
VenomRush (01-05-2015)
Old 01-02-2015, 06:16 PM   #19
Caspeed
Caspeed's Avatar
Drives: FRS-RS1, Triumph Speed Triple, Lola
Could you be hearing the shifter buzzer?
Caspeed is offline   Reply With Quote
Old 01-02-2015, 06:30 PM   #20
2much
I wanna go fast
Drives: 2013 FR-S 6MT
does it sound like a car horn? my clutch sounds like a car horn
2much is offline   Reply With Quote
Old 01-05-2015, 12:03 PM   #21
VenomRush
Thee O-ri-gi-na-tor
VenomRush's Avatar
i also realized this car is drive by wire, so there is a slight delay in when the gas is pressed compared to a car thats not drive by wire
The Following User Says Thank You to VenomRush For This Useful Post:
scionfrs2014 (01-23-2015)
Old 01-05-2015, 12:11 PM   #22
Too lazy to find the thread but some where on here is info that the "car horn / goose honk" has been linked to the throw-out bearing. If it happens all the time it is best to take it in and have it checked.
Old 01-05-2015, 01:18 PM   #23
chaoskaze
The Fail Boat
chaoskaze's Avatar
Drives: CWP S.B.
our car is drive by wire? O.o Don't feel like it to me..
The Following User Says Thank You to chaoskaze For This Useful Post:
Tcoat (01-05-2015)
Old 01-05-2015, 01:22 PM   #24
'Tis true
Old 01-05-2015, 02:06 PM   #25
2much
I wanna go fast
it's been happening since day 1. Only when everything hasn't warmed up yet. Do you think theres a long term problem or its just an annoyance? 'Cause I don't care too much about the noise
Old 01-05-2015, 02:10 PM   #26
From what I have read (I am not an expert on the subject) it can eventually lead to throw out bearing failure.
But... as long as everything seems to be working ok otherwise I would wait until closer to the warranty being up to have it fixed.
2much (01-05-2015)
Old 01-05-2015, 02:19 PM   #27
2much
I wanna go fast
how helpful. and NOT unhelpful.
Old 01-05-2015, 02:21 PM   #28
Clutch noise new to-day Skye Issues | Warranty | Recalls / TSB 16 11-19-2016 11:42 AM
noise when releasing clutch andrew5826 Issues | Warranty | Recalls / TSB 5 02-17-2014 06:41 PM
Clutch Pedal Noise Help!! ZackZ Scion FR-S / Toyota 86 GT86 General Forum 6 09-06-2013 05:35 PM
Winding Noise From Clutch Bach415 Northern California 0 06-24-2013 07:19 PM
Scraping metal noise? Gost Issues | Warranty | Recalls / TSB 0 03-14-2013 09:11 PM
