#15 |
Drives: 2014 Subaru BRZ
I use high temp dupli color
#16 |
Drives: 2013 Ultramarine FR-S
That will also take the chrome off or at least hurt the finish. There isn't a way to reverse this modification without new headlights.
#18 |
Drives: 2013 Asphalt Fr-S
Here in AZ, we have a company called "Space Age Paint".
I had them pull the color code for my vehicle and create a gloss (Without Clearcoat) that matched the paint code (61k) of my car. @jeffsides helped me bake it at on of our tech days we did and I believe we painted 3 vehicle lights for $56 (Rounding up, $20/pair) and we still have some paint left. Probably enough for touch up, or one headlight. We applied 2 coats I believe. I chose no clear coat because the headlights are in a sealed environment (If done correctly) and because it's the same paint as on the body of a vehicle (they specialize in auto paint) I wasn't worried about the temps. As a side note, I had an HID bulb explode in the housing after paint (Faulty bulb, product replaced under warranty with compny) and the paint didn't flinch. So it's a solid way of going about it too.
| The Following User Says Thank You to Celadrielas For This Useful Post: | jeffsides (12-30-2014) |
#19 |
Drives: WRB BRZ
You could always use a film rather than paint for the same effect. I used laminx and it worked great.
#20 | |
AZ FRS 86
Pic? Sent from ARIZONA86 HQ
@AZFRS86
#21 |
I don't think this would work. The laminx goes over the lens, we are painting the chrome. The whole idea of this is to get the look without hurting headlight output. Putting a tinted overlay hurts the output, and safety at night.
#22 | |
Drives: WRB BRZ
If you want an option that doesn't block any light then this is not for you, but again, I couldn't tell the difference. |
#23 |
The Mechanic
Drives: Civic Turbo,FR-S
a flat black primer.
#24 |
Driver of FR-S 1467
Drives: 2013 scion frs 001467
rustoleum high temp gloss black + some clear adhesive promotor (forget the brand tho) got a super even finish and doesnt show any signs of wear so far
#25 |
Engineering Student
Drives: Scion FR-S 2015
what about removing
just lacquer?
There’s no time to stop for gas, we’re already late
| FR-S Headlight Reflector Blackout | DarrenDriven | DIY (Do-It-Yourself) Guides | 476 | 09-26-2020 02:39 PM |
| Modded Headlight+Taillight Swap (Blackout, carbon fiber) for your stocks! $200! | retrosmiths | Exterior Parts (Aero, Lighting, Etc.) | 16 | 04-14-2014 11:20 PM |
| Scion FRS Headlight Blackout Thread | womensecks | Cosmetic Modification (Interior/Exterior/Lighting) | 3 | 09-24-2013 08:13 PM |
| Headlight housing paint job | mariolefty1 | Cosmetic Modification (Interior/Exterior/Lighting) | 0 | 06-04-2013 09:50 PM |
| Headlight blackout help | WolfsFang | NY / NJ / CT / PA | 10 | 03-24-2013 09:23 PM |
